halui.mdi-command-NN pins not showing up
- Thank you received: 2176
02 Sep 2025 18:05 #334288
Replied by Aciera on topic halui.mdi-command-NN pins not showing up
We could set the first configured axis as selected:
github.com/LinuxCNC/linuxcnc/blob/master...r_intf/halui.cc#L694
could be changed to:
Seems to work in my testing.
bool first_axis = true;
for (axis_num=0; axis_num < EMCMOT_MAX_AXIS ; axis_num++) {
if ( !(axis_mask & (1 << axis_num)) ) { continue; }
char c = "xyzabcuvw"[axis_num];
retval = hal_pin_bit_newf(HAL_OUT, &(halui_data->axis_is_selected[axis_num]), comp_id, "halui.axis.%c.is-selected", c);
if (retval < 0) return retval;
retval = hal_pin_float_newf(HAL_OUT, &(halui_data->axis_pos_commanded[axis_num]), comp_id, "halui.axis.%c.pos-commanded", c);
retval = hal_pin_float_newf(HAL_OUT, &(halui_data->axis_pos_feedback[axis_num]), comp_id, "halui.axis.%c.pos-feedback", c);
retval = hal_pin_float_newf(HAL_OUT, &(halui_data->axis_pos_relative[axis_num]), comp_id, "halui.axis.%c.pos-relative", c);
if (first_axis) {
// at startup, indicate [0] item is selected:
*halui_data->joint_is_selected[0] = 1;
*halui_data->axis_is_selected[axis_num] = 1;
first_axis = false;
}Seems to work in my testing.
03 Sep 2025 06:44 #334317
The following user(s) said Thank You: tommylight, JT
03 Sep 2025 09:14 #334328
Replied by andypugh on topic halui.mdi-command-NN pins not showing up
Thanks for the fix.
It's odd that this seems to not have been seen before.
(Or maybe has just been worked around with dummy axes?)
- xunil
04 Sep 2025 19:02 #334429
by xunil
Replied by xunil on topic halui.mdi-command-NN pins not showing up
Seems like that was probably the issue. I can confirm that rearranging the axes to be ZA instead of AZ order didn't fix it. I'll try building from HEAD in the next day or two and post here to confirm that it works.
Thanks for finding that bug and fixing it! This was really holding me up so I really appreciate it.
- xunil
09 Sep 2025 00:19 #334663
by xunil
I'm happy to report that building the 2.9 branch (incorporating the merged PR mentioned above) from the LinuxCNC github solved the problem - the mdi-command-NN pins show up and function as expected. Thanks for the fix!
-Rob
-Rob
09 Sep 2025 13:11 #334694
In that case the fix should be in the just-released 2.9.5 release. (so you probably won't have to build from source again)
Time to create page: 0.177 seconds
