halui.mdi-command-NN pins not showing up
1 year 1 month ago #334663 by xunil
I'm happy to report that building the 2.9 branch (incorporating the merged PR mentioned above) from the LinuxCNC github solved the problem - the mdi-command-NN pins show up and function as expected.  Thanks for the fix!
-Rob
1 year 1 month ago #334694 by andypugh
In that case the fix should be in the just-released 2.9.5 release. (so you probably won't have to build from source again)
