parport observation in outport out-inverter-1 seems not to work
11 months 7 hours ago #339593 by RobotMatic
2.9.7 I can't manage to start a configuration with inverted output ports.
pin 1-14-17 out-inverter-1 seems not to work
I can change state, but I can't start a setup with an inverted state
11 months 5 hours ago - 11 months 5 hours ago #339596 by RobotMatic
video     That's what I did when I ran into the problem
Last edit: 11 months 5 hours ago by RobotMatic.
11 months 3 hours ago #339602 by RobotMatic
I tried what you suggested, it doesn’t work, it has erratic behavior. It performs poorly in 2.8, 2.94, and 2.97, it behaves erratically in all of them, I don’t understand what’s going on
10 months 4 weeks ago #339621 by tommylight
10 months 4 weeks ago #339648 by RobotMatic
At startup, the system,(for example the pin 1-out) does not change when an inverter is applied.
You can watch the video I uploaded in this thread to see what happens
10 months 4 weeks ago #339650 by RobotMatic
I'm a bit confused, if I want to start the system with an output at 1, do I apply setp... inverter true
This should show me the output activated, but I don't see it that way; I still see it turned off. I don't know if I'm misinterpreting it or if it's not working for me, which is why I left a video showing it.
Time to create page: 0.162 seconds
