parport observation in outport out-inverter-1 seems not to work
  • RobotMatic
  • RobotMatic's Avatar Topic Author
  • Elite Member
  • Elite Member
01 Dec 2025 15:13 #339593 by RobotMatic
2.9.7 I can't manage to start a configuration with inverted output ports.
pin 1-14-17 out-inverter-1 seems not to work
I can change state, but I can't start a setup with an inverted state
  • RobotMatic
  • Elite Member
  • Elite Member
01 Dec 2025 16:41 - 01 Dec 2025 16:51 #339596 by RobotMatic
video     That's what I did when I ran into the problem
Last edit: 01 Dec 2025 16:51 by RobotMatic.
  • RobotMatic
  • Elite Member
  • Elite Member
01 Dec 2025 19:04 #339602 by RobotMatic
I tried what you suggested, it doesn’t work, it has erratic behavior. It performs poorly in 2.8, 2.94, and 2.97, it behaves erratically in all of them, I don’t understand what’s going on
02 Dec 2025 05:46 #339621 by tommylight
What does "erratic behavior" mean, exactly and how does it show up?
  • RobotMatic
  • Elite Member
  • Elite Member
02 Dec 2025 15:47 #339648 by RobotMatic
At startup, the system,(for example the pin 1-out) does not change when an inverter is applied.
You can watch the video I uploaded in this thread to see what happens
  • RobotMatic
  • Elite Member
  • Elite Member
02 Dec 2025 15:54 #339650 by RobotMatic
I'm a bit confused, if I want to start the system with an output at 1, do I apply setp... inverter true
This should show me the output activated, but I don't see it that way; I still see it turned off. I don't know if I'm misinterpreting it or if it's not working for me, which is why I left a video showing it.
02 Dec 2025 16:07 #339652 by PCW
I think you may be misinterpreting how the invert parameter operates,
it does not change the state of the parport.0.pin-NN-out hal pin.
(It cannot as this hal pin would be driven by a hal signal)
but rather changes the physical output polarity. You cannot
detect this change in the parport.0.pin-NN-out hal pin but only by
measuring the actual parallel port hardware output pin.
The following user(s) said Thank You: RobotMatic
  • RobotMatic
  • Elite Member
  • Elite Member
02 Dec 2025 16:13 #339653 by RobotMatic
