Clearpath HLFB amp.joint.delay
05 Dec 2025 21:23 #339781 by Fastfred
Clearpath HLFB amp.joint.delay was created by Fastfred
I really could use some help trying to figured out how to setup a delay for amp.joint when I enable the machine i get a instant error from joint.amp using clearpath SD HLFB  , from what ive read i need to add a delay for it.But the problem is ive tried but no luck please someone show me a confing to get me started.
File Name: custom_2025-12-05.hal
File Size:2 KB
File Name: CNC_2025-12-05.hal
File Size:13 KB
  • Moderator
  • Moderator
06 Dec 2025 01:54 #339783 by tommylight
Replied by tommylight on topic Clearpath HLFB amp.joint.delay
Try adding this
linuxcnc.org/docs/2.9/html/man/man9/timedelay.9.html
to amp.fault input pin.
06 Dec 2025 16:32 #339806 by Fastfred
Replied by Fastfred on topic Clearpath HLFB amp.joint.delay
Do I start from scratch? do you mind giving a example how to configure this . Took me awhile just to try to get this far.
06 Dec 2025 21:12 #339807 by Fastfred
My Latest config still having issue with joint 0 fail.
File Name: custom_2025-12-06.hal
File Size:1 KB
07 Dec 2025 02:39 #339811 by Aciera
Replied by Aciera on topic Clearpath HLFB amp.joint.delay
Does the amplifier actually fault and if so do you actually know why it is faulting?
07 Dec 2025 14:15 #339831 by Fastfred
I dont know if this answers your question, but when i use the machine with amp.fault comment out it works fine as soon as I enable the machine with amp.fault enabled it faults instantly I just wanted to use this feature from my understanding it could be useful.
  • Moderator
  • Moderator
07 Dec 2025 15:30 #339833 by tommylight
Did you try inverting the input ?
07 Dec 2025 15:46 - 07 Dec 2025 15:47 #339834 by djdelorie
Replied by djdelorie on topic Clearpath HLFB amp.joint.delay
I just did this for my CNC. Here are the HAL bits I used.  Amusingly, I can't find where <axis>-fault is connected, but I *do* get following errors when I hit things.  More testing required...
addf and2.3 servo-thread
addf and2.4 servo-thread
addf and2.5 servo-thread
addf and2.6 servo-thread
addf and2.7 servo-thread
addf timedelay.0 servo-thread
setp timedelay.0.on-delay 1
setp timedelay.0.off-delay 0
net machine-is-on => timedelay.0.in
net enable-faults <= timedelay.0.out
net x-enable  => hm2_7i76e.0.7i76.0.0.output-08 # TB5 leftmost output
net y-enable  => hm2_7i76e.0.7i76.0.0.output-09
net y2-enable => hm2_7i76e.0.7i76.0.0.output-10
net z-enable  => hm2_7i76e.0.7i76.0.0.output-11
net a-enable  => hm2_7i76e.0.7i76.0.0.output-12
# HLFB is true when enabled *and* following
net hlfb_x  hm2_7i76e.0.7i76.0.0.input-16-not # TB5 leftmost
net hlfb_y  hm2_7i76e.0.7i76.0.0.input-17-not
net hlfb_y2 hm2_7i76e.0.7i76.0.0.input-18-not
net hlfb_z  hm2_7i76e.0.7i76.0.0.input-19-not
net hlfb-a  hm2_7i76e.0.7i76.0.0.input-20-not
net hlfb_x        => and2.3.in0
net enable-faults => and2.3.in1
net x-fault       <= and2.3.out
net hlfb_y        => and2.4.in0
net enable-faults => and2.4.in1
net y-fault       <= and2.4.out
net hlfb_y2       => and2.5.in0
net enable-faults => and2.5.in1
net y2-fault      <= and2.5.out
net hlfb_z        => and2.6.in0
net enable-faults => and2.6.in1
net z-fault       <= and2.6.out
net hlfb_a        => and2.7.in0
net enable-faults => and2.7.in1
net a-fault       <= and2.7.out
Last edit: 07 Dec 2025 15:47 by djdelorie.
07 Dec 2025 19:14 #339844 by Fastfred
I did try reversing the input, Does my custom.hal file look correct? I get a joint 0 amplifier fault instantly its the only joint i am trying to figure out at the moment i haven't tried to add the other joints yet. Is there other ways of doing this that might be easier to add in my case ?
09 Dec 2025 08:08 #339919 by spumco
Replied by spumco on topic Clearpath HLFB amp.joint.delay
First thing to do is make sure the Clearpath's HLFB function is programmed the way you want/need.  Teknics permits a multitude of conditions which result in <some> sort of signal from HLFB, but I suggest you copy @djdelorie's setup and program the HLFB pin to be HIGH when 'enabled and following.'
Next, test the HLFB programming and your wiring to make sure LCNC is getting the HLFB signal properly.  With any amp-fault stuff commented out of HAL, start the machine.  The Clearpath should be enabled, and you should see (in halshow) the input pin which is connected to the HLFB output go HIGH (conducting).
You can also take this opportunity to estimate how long it takes the Clearpath to switch the HLFB signal from LOW to HIGH when it is enabled.  You will want this delay estimate later when configuring the amp-fault time-delay in HAL.
Once you've satisfied yourself that you have everything outside LCNC sorted, you've got a decision to make regarding the other servos' HLFB signal.
- If you want LCNC to 'know' which specific axis/motor trips, you will be using up an input pin for each motor's HLFB output signal.  You will also need a HAL configuration the same as (or similar to) @djdelorie.
- If you don't care which motors trips and just want the machine to stop when any motor trips, then you can wire the HLFB signal from all motors in a series and have a single 'amp-fault' input to LCNC.  This will reduce the number of inputs used to one, and will make the HAL configuration somewhat simpler at the expense of slightly more fussy physical wiring.
Do the tests (and HLFB programming), and think about the 'decision' I mentioned and come back here... we'll help you sort out HAL so everything works like you'd prefer.
Time to create page: 0.300 seconds
