Mill Retrofit with Fanuc DC Drives
5 months 2 weeks ago #346468 by tbrasselle
I was measuring it against the compliment. I had the probe on channel A and the ground on the probe clamped to the inverse channel A. Same thing for channel B.
Viewing channel a and channel b in HALSCOPE everything looks normal. So I’d assume this isn’t actually the issue either.
5 months 2 weeks ago - 5 months 2 weeks ago #346469 by PCW
You cannot do this without two  differential probes.
Measure the A,B signals relative to ground.
But as you said I don't think this is the issue as long as the position
readout is correct.
Last edit: 5 months 2 weeks ago by PCW.
5 months 2 weeks ago #346470 by tommylight
5 months 2 weeks ago #346479 by PCW
Are the motors connected to the linear axis?
This will affect the loop stability
Can you change the velocity loop gain on the drives?
5 months 2 weeks ago #346488 by tbrasselle
I did have the motor disconnected from the ballscrew initially. I've now connected it back and the problem has not gone away. I've attached a halscope screenshot showing the current status. when i enable the drive it oscillates, starts to smooth out, then runs away.
I can adjust the velocity loop gain on the drive but i have been hesitant to do that. the drive and motor were working as is with the Fanuc controller before I disconnected them.
5 months 2 weeks ago #346491 by PCW
The runaway suggests that possibly  one of the feedback loops is reversed.
