- Thank you received: 22
Hitachi WJ200 Setup
- lrak
5 years 11 months ago #188709
by lrak
Replied by lrak on topic Hitachi WJ200 Setup
Looks like I stumbled into this - I was under the misunderstanding that wj200 support was in linuxcnc already - looks like it was not working 2018?
If I need to fix something - is the version in the main source today, the one under construction?
Also - I am told that the cheap RS232 - to - RS485 converters steal power from RTS and CTS so you might need to set them or use an external powersupply for reliable operation - (I used to support a ROM emulator that was powered the same way).. A flaky com link can make software debugging --- ah - a bit interesting.
I would appreciate any information on the current status of the wj200_vfd component. I see the man page, but if I try to load it, I get:
wj200_vfd: dlopen: /usr/lib/linuxcnc/modules/wj200_vfd.so: cannot open shared object file: No such file or directory
- cajbr
- Thank you received: 3
5 years 11 months ago - 5 years 11 months ago #188712
by cajbr
Replied by cajbr on topic Hitachi WJ200 Setup
I've been using the WJ200 over an RS232-485 converter on a new install of 2.8. It also worked on 2.7.14 previously. I've attached my custom.hal.
BR
# Include your customized HAL commands here
# This file will not be overwritten when you run stepconf again
loadusr -W wj200_vfd
setp wj200-vfd.0.mbslaveaddr 1
net spindle-reverse wj200-vfd.0.reverse <= spindle.0.reverse
net spindle-run wj200-vfd.0.run <= spindle.0.on
net spindle-at-speed wj200-vfd.0.is-at-speed => spindle.0.at-speed
net spindle-enable wj200-vfd.0.enable motion.motion-enabled
loadrt mult2
addf mult2.0 servo-thread
setp mult2.0.in1 0.04
net command-speed mult2.0.in0 spindle.0.speed-out-abs
net vfd-speed wj200-vfd.0.commanded-frequency mult2.0.out
BR
loadrt mult2
Last edit: 5 years 11 months ago by cajbr. Reason: add hal text
The following user(s) said Thank You: lrak
- lrak
5 years 11 months ago - 5 years 11 months ago #188713
by lrak
Did you build it? Not part of
linuxcnc-uspace 1:2.8.0
linuxcnc-uspace-dev 1:2.8.0
I tested with mbpoll - but there is no component to load - I was thinking it might be broken thus not included in the deb?
I get:
I Just figured it out -- loadusr not loadrt..
I get:
Last edit: 5 years 11 months ago by lrak. Reason: found the problem
- Thank you received: 7491
5 years 11 months ago #188726
Replied by tommylight on topic Hitachi WJ200 Setup
Loadusr = user space component
Loadrt = real time component.
- lrak
5 years 11 months ago #188786
by lrak
I wonder if someone knows how to ping oro06 on this? I don't see that he has been active here for a couple of years?
I'm got it working - not satisfied -
WJ200 should not talk to the drive when it isn't powered - need a pin to drive with
iocontrol.0.user-enable-out or halui.estop.is-activated
- When physical estop happens - this drive will still run for a bit - and should stop the spindle - so send one last command to the drive and disable communications until the physical estop is out again.
Also, it should refuse to start at 0-speed.
Possibly an input for scaling the requested rpm to a frequency..
I will have to rewrite this after I get a few other bits sorted out. It looked like oro06 was working on this -he had major changes
but I don't think it compiled - last activity 2 years ago.
Some drive parameters take a reboot to change..
Looks like he was building a meter-display - and other improvements - here is HIS list in italics
a)work if a frequency range (min and max) is configured in the vfd if frequency setpoint is lower than min frequency a stop is issued
if frequency setpoint is higher than max frequency, setpoint is overwritten with max frequency.
b)stop issued when exiting
c)more registers accessible like current frequency, instant power
consumption and motor information
d)added a failure mode if registers could not be read after several attempt
e)use of 'variable' declaration to store instance variables
f)added simple log with ms timing
g)split modbus transaction in 2 groups static and dynamic
the former being read only once
h)add optionnal --verbose to loadusr command, to view in-loop live
modbus registers
i)fix possible issue when attempting to set frequency higher than 655.35 Hz
j)started a dedicated gladevcp .ui and .hal
k)added a version number
modbus registers
- Thank you received: 1480
5 years 11 months ago #188871
Replied by Todd Zuercher on topic Hitachi WJ200 Setup
I'd recommend hard wiring an estop signal to the drive and not relying on the serial connection for it.
Time to create page: 0.306 seconds
