- Thank you received: 115
The finesse of classic ladder, getting started
- Becksvill
6 years 7 months ago #160348
by Becksvill
Replied by Becksvill on topic The finesse of classic ladder, getting started
Hey John I need to also design a similar circuit to control my oiler on my cnc. In my case the oiler needs to be turned on every 3 mins or so I think for 20 seconds.
Just wondering if you can expand on that example. I am just coming to grips with classic ladder now
- BigJohnT
- Thank you received: 994
6 years 7 months ago - 6 years 7 months ago #160353
by BigJohnT
Replied by BigJohnT on topic The finesse of classic ladder, getting started
Not very intuitive with no description lol.
The first rung is a self reseting timer. A TP timer the output is on until the count is reached. As soon s the count is reached the first timer resets to 0 and starts to count down again. Might not be the best way but it's what I came up with 2017.
The second rung when the output bit goes from off to on that timer starts and the output from that goes to your pump.
JT
JT
Last edit: 6 years 7 months ago by BigJohnT.
The following user(s) said Thank You: Becksvill
- Becksvill
6 years 6 months ago #162743
by Becksvill
Hey John
For some reason I am not getting notified about any replies hence the slow reply sorry.
I have been looking at the example classic ladder sim and running it and the ladder part all makes sense and is perfect for what I want. I just want to turn on a relay to power the lube pump on for 15 secs every 15 mins. and so you example is perfect.
What I am struggling with is how to actually connect the Hal pins to classic ladder. I have been reading up on HAL and watching videos especially Sam ("green machine videos") and ("estop video"). I think I understand those videos and can use Halcmd ok now. but I am still at a bit of a loss on how to connect the hal to classic ladder. It must be pretty simple lol. But the manual doesn't say anything in the examples that I could see. I think it must be so simple that they just seem to assume that people will have no trouble.
I am going to do some testing now and hopefully I work it out if so I will post back here.
- Mike_Eitel
- Thank you received: 183
6 years 6 months ago #162752
by Mike_Eitel
Replied by Mike_Eitel on topic The finesse of classic ladder, getting started
In this old #130396 is a tar.
Inside of this complete project you can find a. hal that transfers signals between CL and hal pins.
Mike
Mike
- Becksvill
6 years 6 months ago #162796
by Becksvill
thanks mike.
have you ever retrofitted a vmc toolchanger? I am looking for examples to get me started
I think i have started down the path. I can connect hal pins to classic ladder now and can change classic ladder stuff which was my first hold up. But now I have to decide how my logic will work
Andrew
Andrew
- Mike_Eitel
6 years 6 months ago #162851
by Mike_Eitel
Hi Andrew
No, i never did.
But i read here on the forum that quite a lot of others did.
I'm sure some can step in better than me.
Mike
No, i never did.
Mike
Time to create page: 0.605 seconds
