- Thank you received: 2177
Classicladder TCP setup ?
4 years 1 month ago - 4 years 1 month ago #252324
Replied by Aciera on topic Classicladder TCP setup ?
I don't really know. Are you getting any information (errors) in the terminal?
Also if you use the default port 9502 do you see anything on wireshark at all?
edit:
Can you post your clp file?
edit:
Last edit: 4 years 1 month ago by Aciera.
- HansU
4 years 1 month ago #252327
by HansU
Replied by HansU on topic Classicladder TCP setup ?
Just to throw it in here, only in case you haven't heard of it before.
There is a component called MB2HAL, which also allows you to connect to Modbus-TCP devices.
linuxcnc.org/docs/2.9/html/drivers/mb2hal.html
If you are using Classicladder only for Modbus you can consider using this. Or to test the connection to ensure the hardware is connected properly.
- grzesiekzxr
4 years 1 month ago #252633
by grzesiekzxr
Replied by grzesiekzxr on topic Classicladder TCP setup ?
Thank you, I know and use Mb2hal is a great soft.
If I find time for further tests, I will let you know what has worked.
Time to create page: 0.645 seconds
