Using classic ladder and RS485 for spindle
03 May 2023 09:39 #270570 by Julien
Hey, I am trying to set up my USB to RS485 adapter to controll my spindle.
The adapter has the following specs:
Modell Nr: SH-U10L
Standard : RS485
Haupt chip: SILICON LABS CP2102
Interface: USB Type A ,5 PIN Terminal Block
RS485 PIN: TXD+(A+), TXD-(B-)
USB 2.0; kompatibel USB 1.1
Kabel Länge: 5 Fuß/1.5M
Baud: 300bps bis 1Mbps
It can be found by terminal and I created a modbus.rules in /etc/udev/rules.d/ with following entrys:
SUBSYSTEMS=="usb",ATTRS{idVendor}=="0403",ATTRS{idProduct}=="6001",GROUP="root",MODE="0666"
SUBSYSTEM=="tty",ATTRS{idVendor}=="0403",ATTRS{idProduct}=="6001",SYMLINK+="RS485_ADAPTER"
I have created the followed entrys in my .hal:
loadrt classicladder_rt
addf classicladder.0.refresh servo-thread
loadusr -w classicladder --modmaster DM2800.clp
started ProbeBasic and saved a new DM2800.clp via classicladder. But sadly when I start classic ladder and go to the config->modbus communication it says I have to put the entry "loadusr -w classicladder --modmaster myprogram.clp" into my .hal.
17 May 2023 04:56 #271522 by andypugh
Replied by andypugh on topic Using classic ladder and RS485 for spindle
Try starting from HAL.
halrun
Or, alternatively.
halrun -I DM2800.hal
(note that I guessed the name of the HAL file, use the actual file that you created)
In either case, you can use "exit" to close the interactive HAL session,
Time to create page: 0.842 seconds
