modbus -write coils
3 years 3 weeks ago #282730
by den2313
modbus -write coils was created by den2313
Hello. How to transfer the bit (write coils 0x05) in modbus classicladder? Thank you
- Thank you received: 1480
3 years 2 weeks ago - 3 years 2 weeks ago #282919
Replied by Todd Zuercher on topic modbus -write coils
Are you using the Modbus capabilities built into Classicladder or are you using some other Modbus interface in Linuxcnc, such as Mb2hal?
If you are using the Modbus facilities built into Classicladder, on the Modbus Configuration screen, In the far right column you assign the variable number used for your write coils assignment. It must be an integer number between 0 and what ever you set as the maximum number of bits (default is 10 or 20). (I'm not sure if this number is just bits or if it is hal output bits.)
So if you configured it for 8, for example when you use coil %Q8, Classicladder will write the value for that to the modbus coil.
Last edit: 3 years 2 weeks ago by Todd Zuercher.
3 years 2 weeks ago #282926
by den2313
Replied by den2313 on topic modbus -write coils
I use the regular classicladder. When I use uint8 send and receive everything works fine ( Read x03 %W2=1 or %W2=0). But when I use "Write coil" then Linux always sends "01 05 00 00 00 00 + crc".
3 years 2 weeks ago - 3 years 2 weeks ago #282928
by den2313
I did not find examples of transmitting and receiving individual bits via modbus in linuxcnc (0x05, 0x15).
If I use "%Wx=%Qx" where Qx= 0xFF00 or Qx=0x1 - it doesn't change anything. Command 05 00 00 FF 00 crc - should set a bit in address 00 00, but this does not happen.
PS .Sorry for the spelling, I'm using googler translate
Last edit: 3 years 2 weeks ago by den2313. Reason: I added to the question
Time to create page: 0.046 seconds
