conection between I/O and classic ladder
- andradela
09 May 2011 03:27 #9670
by andradela
conection between I/O and classic ladder was created by andradela
Hello guys.
How do I conect de I/O signals to use in the classic ladder?
- BigJohnT
- Thank you received: 1176
09 May 2011 16:45 #9678
by BigJohnT
Replied by BigJohnT on topic Re:conection between I/O and classic ladder
You do that in your postgui hal file, if you used stepconf it will be custom_postgui.hal.
Take a look at the examples in the Integrators Manual.
- andradela
10 May 2011 00:11 - 10 May 2011 00:22 #9687
by andradela
Replied by andradela on topic Re:conection between I/O and classic ladder
Thanks John
I have another question.
net oil-pump classicladder.0.out-00 => paraport.0.9.out
This is a M7 or M8 command right?
How I change it, instead of using pin-09-out, I use %B0 from classic ladder
Maybe like this:
net oil-pump classicladder.0.bit-00 => classicladder.0.0.bit (boolean)
This is possible?
If is not correct how is would?
Thanks.
Maybe like this:
This is possible?
Thanks.
Last edit: 10 May 2011 00:22 by andradela.
- BigJohnT
10 May 2011 00:42 #9688
by BigJohnT
No, it is just part of my oiler system.
Classicladder bits are numbered like so
classicladder.0.bit-01
classicladder.0.bit-02
- Thank you received: 2160
10 May 2011 00:53 #9689
Replied by cmorley on topic Re:conection between I/O and classic ladder
%B variable are just for internal memory. you must use %I for external inputs and %Q for external outputs.
- andradela
10 May 2011 03:15 #9690
by andradela
Ok so will it works?
#!bin/bash
halcmd setp classicladder.0.bit-00 TRUE
exit 0
#!bin/bash
exit 0
29 May 2011 02:14 #10139
sorry i didn't get back to you.
No that is not right.
The classicladder pin name would be :
classicldder.0.in-00 for inputs (%I0)
- andradela
30 May 2011 13:55 - 30 May 2011 14:08 #10184
by andradela
I would like to connect classic ladder with emc using %B that's possible?
Last edit: 30 May 2011 14:08 by andradela.
- BigJohnT
30 May 2011 19:42 #10191
by BigJohnT
No that is an internal bit used by classicladder, you have to use the I/O only.
- andradela
30 May 2011 20:43 #10195
by andradela
Ok, how do I create a M101 using classic ladder?
Time to create page: 0.375 seconds
