Current turning capabilities status
13 years 4 days ago #40356 by andypugh
emcPT wrote: What is your profession, if I may ask?
I have done a lot of jobs, I was a metallurgist straight after my PhD, then moved into structural integrity and mechanical testing, then worked on skin graft research for a little while, then became a mechanical designer, then an NVH engineer at a car company, then spent a while designing X-ray microscopes. At the moment I am back in the auto industry where I set up engine control computers. (lots of rather elaborate PID controllers).
12 years 11 months ago #40596 by jtc
Another progress another question :(
1)
Axis are running, spindle is running, toolchange is done. Not bad for now.
As the machine does automatic toolchanges (and many for each part), every time that the tool change happens, the spindle stops. I think that this is a desired feature for milling machines, but for lathes it is a waist of power and time as the spindle must brake and gain speed again.
I hope that this is easy to change/set up, but I could not find any info about this.
I must say that the toolchange is being done by a component programmed here, but the component does not ask for the spindle stop.
Thank you
12 years 11 months ago #40624 by emcPT
This is done, for example here:
so linuxcnc can support it, but we have no idea how to do it.
Who made the video? Is someone that uses this forum?
12 years 11 months ago #40627 by andypugh
jtc wrote: 1) every time that the tool change happens, the spindle stops. I think that this is a desired feature for milling machines, but for lathes it is a waist of power and time as the spindle must brake and gain speed again.
It's an INI-file option: [EMCIO] TOOL_CHANGE_WITH_SPINDLE_ON = 1
www.linuxcnc.org/docs/html/config/ini_co..._sub_emcio_section_a
12 years 8 months ago #44146 by emcPT
After almost one year...
It was worth it!
Time to create page: 0.356 seconds
