Current turning capabilities status
Yes, it can be done, but possibly not easily in combination with analogue voltage control for the axis servos.emcPT wrote: From the inverter manual, using a train pulse, so this may act like a servo. For example to maintain a determined speed I would have to continue to feed a position constantly far away from the current position. Does Linuxcnc have this built in?
(It's not a LinuxCNC problem, but you would need an unusual combination of interface hardware)
I would suggest not getting the in-drive position control hardware yet, and seeing how LinuxCNC-only control works first.
I will need some guidance then, but lets see what can I achieve looking on the documentation. People on my company don't look to this project as something that can be done, but I convinced my "boss" to let me try and to give me some € to spend. Lets see.
They are wrong, you are rightemcPT wrote: People on my company don't look to this project as something that can be done, but I convinced my "boss" to let me try and to give me some € to spend. Lets see.
I isn't going to be simple, but you will learn a lot on the way.
I have also run pncconfig and set up things to the best of my knowledge. I did not set up and I/O signals except the ones for the servos (X,Z,A and spindle).
I do not have any servo or any I/O signals hardwired.
Now when starting linuxcnc it will not start and the relevant (the first error) debug message is:
Can not find -sec MOT -var MOT -num 1
and a few more others, all that start with "Can not find ..."
This is probably due to a bad configuration on the pncconfig, but this is almost alien language.
My question for today would be what would be the most "clean" config that I can make just to have a spindle, because I would like to start only by having a spindle working.
A few pictures of the mesa hardware installed are attached. There was suppose to be any leds on the 7i37 ?
What can't it find? That's the critical bitemcPT wrote: Can not find -sec MOT -var MOT -num 1
and a few more others, all that start with "Can not find …
Can you post the HAL file and the error log (dmesg)
You will probably have to post the full error message (and maybe dmesg log) to
debug this
