Current turning capabilities status
13 years 8 months ago - 13 years 8 months ago #30183 by emcPT
So I attached the requested files.
I must say that I installed a fresh ubuntu, then only updated all the available packages, but not the ubuntu itself as it is recommended.
Last edit: 13 years 8 months ago by emcPT. Reason: added oncconfig
13 years 8 months ago - 13 years 8 months ago #30184 by emcPT
I can not imagine why, but I was unable to upload the pncconfig file.
13 years 8 months ago #30186 by andypugh
The problem is
"okuma.hal:107: parameter or pin 'bldc.2.drive-offset' not found"
But I have no idea at all why pncconf has inserted a bldc function in your HAL file.
Can you post the HAL file?
13 years 8 months ago #30188 by andypugh
Is it the same problem as here?
www.linuxcnc.org/index.php/english/forum...ation?start=18#30187
Deselect "brushless motor control" in PncConf.
The following user(s) said Thank You: emcPT
13 years 8 months ago #30190 by emcPT
If my motors are brushless, I could make the pncconfig x10 times more changing things that I would never changed that.
It did the trick, but I keep on wondering how many of those subtil issues I will encounter.
But ok! it is done, and I get the front end.
I will now read a bit and try to configure a spindle outputs and encoder feedback as my VFD will be here next week.
13 years 8 months ago #30202 by PCW
The brushless motor option is only for very specific configurations where LinuxCNC does the commutation. (pncconf should probably indicate this)
There is no difference in the configuration needed if standard analog brushed or brushed servos with interfaces are used
