Current turning capabilities status
13 years 8 months ago #30607 by andypugh
emcPT wrote: Currently I am controlling the spindle using an analog output from the 7i33 (0-10V) with direction from the 7i37.
I have an quadrature encoder 1000ppr in the spindle back with index going straight to the 7i33.
can you tell me the HAL pin names for the fwd and reverse pins on the 7i37?
13 years 8 months ago #30608 by emcPT
Here they are
# --- SPINDLE-CW ---
setp hm2_5i20.0.gpio.046.is_output true
net spindle-cw hm2_5i20.0.gpio.046.out
setp hm2_5i20.0.gpio.046.invert_output true
# --- SPINDLE-CCW ---
setp hm2_5i20.0.gpio.047.is_output true
net spindle-ccw hm2_5i20.0.gpio.047.out
setp hm2_5i20.0.gpio.047.invert_output true
13 years 8 months ago #30637 by andypugh
I am not going to get round to this today. Sorry.
I had the feeling that you wanted the C-axis working too, is that right?
13 years 8 months ago #30644 by emcPT
No problem, thank you.
I do not need the C axis at least for now. I would be happy only to know that the spindle speed is in fact controlled by the closed loop. Because if this works then I will probably buy the 15Kw inverter (now I am using a 5.5Kw with limited acceleration and deceleration for it not to trip).
Cheers.
13 years 8 months ago - 13 years 8 months ago #30649 by andypugh
I think that this is what you need for simple PID control.
I haven't checked this, (at all) so be careful.
#******************* # SPINDLE S #******************* # ---PWM Generator signals/setup--- setp hm2_5i20.0.pwmgen.03.output-type 1 setp hm2_5i20.0.pwmgen.03.scale [SPINDLE_9]OUTPUT_SCALE # ---Encoder feedback signals/setup--- setp hm2_5i20.0.encoder.03.counter-mode 0 setp hm2_5i20.0.encoder.03.filter 1 setp hm2_5i20.0.encoder.03.index-invert 0 setp hm2_5i20.0.encoder.03.index-mask 0 setp hm2_5i20.0.encoder.03.index-mask-invert 0 setp hm2_5i20.0.encoder.03.scale [SPINDLE_9]ENCODER_SCALE net spindle-revs <= hm2_5i20.0.encoder.03.position motion.spindle-revs net spindle-index-enable <=> hm2_5i20.0.encoder.03.index-enable <=>motion.spindle-index-enable net spindle-vel-fb-rps hm2_5i20.0.encoder.03.velocity => motion.spindle-speed-in #PID for spindle #Need to add FF0, PGAIN, IGAIN to your [SPINDLE_9] section #Set [SPINDLE_9]OUTPUT_SCALE to 1. That job is now done by the PID FF0 #Set FF0 to give the closest speed-match at mid-speed #then adjust P and I to suit. loadrt pid names=spindle_pid # using names= means that 2-pass HAL can work. # alternatively increment the count in the HAL file. addf spindle_pid servo-thread setp spindle_pid.Pgain [SPINDLE_9]PGAIN setp spindle_pid.Igain [SPINDLE_9]IGAIN setp spindle_pid.FF0 [SPINDLE_9]FF0 # ---setup spindle control signals--- loadrt abs count=1 addf abs.0 servo-thread # analog output net spindle-brake <= motion.spindle-brake net spindle-at-speed => motion.spindle-at-speed net spindle-vel-cmd-rps => motion.spindle-speed-out-rps => spindle_pid.command net spindle-vel-fb-rps spindle_pid.feedback net spindle-fwd abs.0.is-positive => hm2_5i20.0.gpio.046.out net spindle-rev abs.0.is-negative => hm2_5i20.0.gpio.047.out net spindle-on motion.spindle-on hm2_5i20.0.pwmgen.03.enable spindle_pid.enable net pid-out spindle_pid.output => abs.0.in net pid-abs abs.0.out => hm2_5i20.0.pwmgen.03.value # ---Setup spindle at speed signals--- loadrt near addf near.0 servo-thread net spindle-vel-cmd-rps => near.0.in1 # commanded net spindle-vel-fb => near.0.in2 # real net spindle-at-speed motion.spindle-at-speed <= near.0.out setp near.0.scale 1.2
Last edit: 13 years 8 months ago by andypugh.
The following user(s) said Thank You: emcPT
13 years 8 months ago #30668 by cmorley
I think if you look carefully, PNCconf already loaded the PID component and called it spindle.
Look at the top of the main HAL file.
I think it load it but doesn't use it. PNCconf used to allow you to use PID for the spindle then I removed it.
I tell you this cause if you use Andy's code it will error when asked to load the PID because there is already one loaded.
Just a heads up.
Chris M
Time to create page: 0.175 seconds
