Semi-Manual Lathe
08 Jan 2014 02:24 #42452 by lelef
Replied by lelef on topic Semi-Manual Lathe
unfortunately no,
I've tryed the .INI and .HAL codes but not everithing works so I've started this new post ( tool change has worked immediately,visualization of the spindle speed after some mods, a mult2 added )
08 Jan 2014 02:28 #42453 by andypugh
Replied by andypugh on topic Semi-Manual Lathe
unfortunately no,
OK, so what doesn't work, and how does it not work?
08 Jan 2014 22:59 #42502 by lelef
the only routine that seems to do something is the drilling
in your files there is also "pyvcp_widgets.py" but Ive fuond no use of this
It mus be linked in some way?
08 Jan 2014 23:07 #42503 by andypugh
That's curious. One possibility is that you still specify the default number of analogue and digital inputs, what does your "loadrt motmod" line in the hal file say?
(This probably looks like)
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES num_aio=8 num_dio=10
Note the increased number of analogue and digital pins.
You should be able to check in Halmeter if the mdi_command pins are being set high when you press a button.
You should also be able to manually launch the subroutines from the MDI tab, to check that they get found and work.
This allows you to use "enter" to register a value in the spinboxes. Otherwise the values are not seen by the system until you press the up-down arrows.
You need to put that new version of pyvcp_widgets.py in the place of the old one on your HDD.
12 Jan 2014 01:33 #42622 by lelef
thr loadrt motmod is right
I've checked in Halmeter all the signals ,pins ecc and all seems to be ok
I've entered all the values and also moved whit the arrows,I've selected the tool and if I use turning or facing the axis makes only one movement,the go to the starting position and then nothing more.
Shurely somewhere I've make a mistake but I don't understand where
12 Jan 2014 02:34 #42623 by andypugh
The macros use feed-per-rev mode. Do you have a spindle encoder?
motion.spindle-speed-in needs to be connected and working for feed-per-rev mode
16 Jan 2014 23:30 #42876 by lelef
Yes they are connected,
Probably (I'm working on the turning mode ) reading the HAL meter data the turning.ngc waits the spindle speed to be at a set value, I've a gearbox and no inverter so the exact speed needed is never reaced and the program dosn't start.
I'm studing your gcode but I don't have found a reference for well understand how it works(the most problem is about variables)
I would like to make it more simple and step by step add the value passed in the interface to find out my error
17 Jan 2014 02:46 #42884 by andypugh
If you Halscope them, do they appear to be working?
Negative spindle speed might cause confusion, for example.
I didn't put any wait for spindle-at-speed in my G-code, but it might be in your HAL file.
The following user(s) said Thank You: lelef
17 Jan 2014 03:09 - 17 Jan 2014 03:09 #42885 by lelef
the commands in red what are for?
;Turning
O<turning> sub
(axis,hide)
G18 G7
M66 E4 L00
#5 = #5399 (Finish Z )
M66 E3 L00
#1 = #5399 (Finish X)
M66 E0 L0
#2 = #5399 (metres/min surface speed)
M66 E2 L0
#3 = #5399 (Cut / Increment )
M66 E1 L0
#4 = #5399 (Feed / Pitch)
M66 E5 L0
#6 = #5399 (Radius)
M66 E6 L0
#7 = #5399 (angle)
G92 x0 z0 (store position)
g92.2
#14 = [#5211 * 2] (starting X)
#13 = #5213 (starting Z)
g92.1
G7 ; Lathe Diameter Mode
G18 ; XZ Plane
G21 ; Metric Units
G90 ; Absolute Distance
G91.1 ; but not or arcs
G96 D1500 S#2 ; Constant Surface Speed Mode
g95 F#4 ; Feed-Per-Rev Mode
m3 ;Start Spindle
g4p1 ; Wait to reach speed
;Turning
(axis,show)
/ (debug, Turning finish dia #1 start dia #14 start length #13 finish length #5)
/ m1
O100 WHILE [#14 GT [#1+#3]]
g0 X #14
#14=[#14-#3]
G1 X #14
G1 Z [#5 + #6] X[#14 + [#13 - [#5 + #6]]*TAN[#7]]
O101 IF [#6 GT 0]
G2 Z#5 X[#14 + 2 * #6 + [#13 - [#5 + #6]]*TAN[#7]] I[#6]
O101 ELSE
G1 X[#14 + #3 + [#13 - [#5 + #6]]*TAN[#7] + 0.3]
O101 ENDIF
G0 Z[#13]
O100 ENDWHILE
G0 x#1
G1 Z [#5 + #6] X[#1 + [#13 - [#5 + #6]]*TAN[#7]]
O102 IF [#6 GT 0]
G2 Z#5 X[#1 + 2 * #6 + [#13 - [#5 + #6]]*TAN[#7]] I[#6]
O102 ELSE
G1 X[#1 + #3 + [#13 - [#5 + #6]]*TAN[#7] + 0.3]
O102 ENDIF
G0 Z #13
G0 X #1 ; For touch-off
M5
O<turning> endsub
M2
Last edit: 17 Jan 2014 03:09 by lelef.
17 Jan 2014 03:24 #42886 by andypugh
It's a G4. Just a pause (for one second)
Moderators: piasdom
Time to create page: 0.153 seconds
