still cant get the toolchanger buttons in the UI to work. here is what I have
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.4
Machine configuration directory is '/home/user/linuxcnc/configs/Emco1'
Machine configuration file is 'Emco1.ini'
INIFILE=/home/user/linuxcnc/configs/Emco1/Emco1.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./Emco1.hal
Found file(REL): ./custom.hal
Running HAL shutdown script
Killing task linuxcncsvr, PID=6004
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: Hardware address: 00:60:1b:10:40:71
hm2_eth: discovered 7I76E-16
hm2/hm2_7i76e.0: Smart Serial Firmware Version 43
Board hm2_7i76e.0.7i76.0.0 Hardware Mode 0 = standard
Board hm2_7i76e.0.7i76.0.0 Software Mode 0 = io_spin
Board hm2_7i76e.0.7i76.0.0 Software Mode 1 = io_ana_spin
Board hm2_7i76e.0.7i76.0.0 Software Mode 2 = io_enc_ana_spin_fv
hm2/hm2_7i76e.0: 51 I/O Pins used:
hm2/hm2_7i76e.0: IO Pin 000 (P1-01): StepGen #0, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 001 (P1-14): StepGen #0, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 002 (P1-02): StepGen #1, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 003 (P1-15): StepGen #1, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 004 (P1-03): StepGen #2, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 005 (P1-16): StepGen #2, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 006 (P1-04): StepGen #3, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 007 (P1-17): StepGen #3, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 008 (P1-05): StepGen #4, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 009 (P1-06): StepGen #4, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 010 (P1-07): Smart Serial Interface #0, pin TxData0 (Output)
hm2/hm2_7i76e.0: IO Pin 011 (P1-08): Smart Serial Interface #0, pin RxData0 (Input)
hm2/hm2_7i76e.0: IO Pin 012 (P1-09): IOPort
hm2/hm2_7i76e.0: IO Pin 013 (P1-10): IOPort
hm2/hm2_7i76e.0: IO Pin 014 (P1-11): Encoder #0, pin Index (Input)
hm2/hm2_7i76e.0: IO Pin 015 (P1-12): Encoder #0, pin B (Input)
hm2/hm2_7i76e.0: IO Pin 016 (P1-13): Encoder #0, pin A (Input)
hm2/hm2_7i76e.0: IO Pin 017 (P2-01): IOPort
hm2/hm2_7i76e.0: IO Pin 018 (P2-14): IOPort
hm2/hm2_7i76e.0: IO Pin 019 (P2-02): IOPort
hm2/hm2_7i76e.0: IO Pin 020 (P2-15): IOPort
hm2/hm2_7i76e.0: IO Pin 021 (P2-03): IOPort
hm2/hm2_7i76e.0: IO Pin 022 (P2-16): IOPort
hm2/hm2_7i76e.0: IO Pin 023 (P2-04): IOPort
hm2/hm2_7i76e.0: IO Pin 024 (P2-17): IOPort
hm2/hm2_7i76e.0: IO Pin 025 (P2-05): IOPort
hm2/hm2_7i76e.0: IO Pin 026 (P2-06): IOPort
hm2/hm2_7i76e.0: IO Pin 027 (P2-07): IOPort
hm2/hm2_7i76e.0: IO Pin 028 (P2-08): IOPort
hm2/hm2_7i76e.0: IO Pin 029 (P2-09): IOPort
hm2/hm2_7i76e.0: IO Pin 030 (P2-10): IOPort
hm2/hm2_7i76e.0: IO Pin 031 (P2-11): IOPort
hm2/hm2_7i76e.0: IO Pin 032 (P2-12): IOPort
hm2/hm2_7i76e.0: IO Pin 033 (P2-13): IOPort
hm2/hm2_7i76e.0: IO Pin 034 (P3-01): IOPort
hm2/hm2_7i76e.0: IO Pin 035 (P3-14): IOPort
hm2/hm2_7i76e.0: IO Pin 036 (P3-02): IOPort
hm2/hm2_7i76e.0: IO Pin 037 (P3-15): IOPort
hm2/hm2_7i76e.0: IO Pin 038 (P3-03): IOPort
hm2/hm2_7i76e.0: IO Pin 039 (P3-16): IOPort
hm2/hm2_7i76e.0: IO Pin 040 (P3-04): IOPort
hm2/hm2_7i76e.0: IO Pin 041 (P3-17): IOPort
hm2/hm2_7i76e.0: IO Pin 042 (P3-05): IOPort
hm2/hm2_7i76e.0: IO Pin 043 (P3-06): IOPort
hm2/hm2_7i76e.0: IO Pin 044 (P3-07): IOPort
hm2/hm2_7i76e.0: IO Pin 045 (P3-08): IOPort
hm2/hm2_7i76e.0: IO Pin 046 (P3-09): IOPort
hm2/hm2_7i76e.0: IO Pin 047 (P3-10): IOPort
hm2/hm2_7i76e.0: IO Pin 048 (P3-11): IOPort
hm2/hm2_7i76e.0: IO Pin 049 (P3-12): IOPort
hm2/hm2_7i76e.0: IO Pin 050 (P3-13): IOPort
hm2/hm2_7i76e.0: registered
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
Debug file information:
Note: Using POSIX realtime
Waiting for component 'hm2_eth' to become ready...............................
./custom.hal:13: Pin 'halui.mdi-command-00' does not exist
6004
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.2.0-4-rt-686-pae (debian-kernel@lists.debian.org) (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT RT Debian 3.2.81-1
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f000 (usable)
[ 0.000000] BIOS-e820: 000000000009f000 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000003f690000 (usable)
[ 0.000000] BIOS-e820: 000000003f690000 - 000000003f6e0000 (reserved)
[ 0.000000] BIOS-e820: 000000003f6e0000 - 000000003f6e3000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000003f6e3000 - 000000003f6f0000 (ACPI data)
[ 0.000000] BIOS-e820: 000000003f6f0000 - 000000003f700000 (reserved)
[ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.5 present.
[ 0.000000] DMI: Dell Inc. OptiPlex FX170/ , BIOS 6.00 PG 12/13/2011
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x3f690 max_arch_pfn = 0x1000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-through
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask 0C0000000 write-back
[ 0.000000] 1 base 03F800000 mask 0FF800000 uncachable
[ 0.000000] 2 base 03F700000 mask 0FFF00000 uncachable
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [c00f4b50] f4b50
[ 0.000000] initial memory mapped : 0 - 01a00000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000379fe000
[ 0.000000] 0000000000 - 0000200000 page 4k
[ 0.000000] 0000200000 - 0037800000 page 2M
[ 0.000000] 0037800000 - 00379fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 379fe000 @ 19f9000-1a00000
[ 0.000000] RAMDISK: 36252000 - 37121000
[ 0.000000] ACPI: RSDP 0x00000000000F8C70 00014 (v00 IntelR)
[ 0.000000] ACPI: RSDT 0x000000003F6E3000 00034 (v01 IntelR AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: FACP 0x000000003F6E3080 00074 (v01 IntelR AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: DSDT 0x000000003F6E3100 032D7 (v01 INTELR AWRDACPI 00001000 MSFT 03000000)
[ 0.000000] ACPI: FACS 0x000000003F6E0000 00040
[ 0.000000] ACPI: MCFG 0x000000003F6E6480 0003C (v01 IntelR AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: APIC 0x000000003F6E6400 00068 (v01 IntelR AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: SSDT 0x000000003F6E6B20 00482 (v01 PmRef CpuPm 00003000 INTL 20050930)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 124MB HIGHMEM available.
[ 0.000000] 889MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 379fe000
[ 0.000000] low ram: 0 - 379fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000379fe
[ 0.000000] HighMem 0x000379fe -> 0x0003f690
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[2] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0003f690
[ 0.000000] On node 0 totalpages: 259615
[ 0.000000] free_area_init_node: node 0, pgdat c1415400, node_mem_map f720d200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 1748 pages used for memmap
[ 0.000000] Normal zone: 221994 pages, LIFO batch:31
[ 0.000000] HighMem zone: 250 pages used for memmap
[ 0.000000] HighMem zone: 31640 pages, LIFO batch:7
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] SMP: Allowing 2 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 3f700000 (gap: 3f700000:a0900000)
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] setup_percpu: NR_CPUS:32 nr_cpumask_bits:32 nr_cpu_ids:2 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 93 pages/cpu @f7147000 s360128 r0 d20800 u380928
[ 0.000000] pcpu-alloc: s360128 r0 d20800 u380928 alloc=93*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 257585
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-4-rt-686-pae root=UUID=ff332f66-2ec9-479a-a11e-af5e44a860e9 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] Initializing HighMem for node 0 (000379fe:0003f690)
[ 0.000000] Memory: 1007504k/1038912k available (2864k kernel code, 30956k reserved, 1346k data, 728k init, 127560k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xffd36000 - 0xfffff000 (2852 kB)
[ 0.000000] pkmap : 0xffa00000 - 0xffc00000 (2048 kB)
[ 0.000000] vmalloc : 0xf81fe000 - 0xff9fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf79fe000 ( 889 MB)
[ 0.000000] .init : 0xc141d000 - 0xc14d3000 ( 728 kB)
[ 0.000000] .data : 0xc12cc220 - 0xc141ca80 (1346 kB)
[ 0.000000] .text : 0xc1000000 - 0xc12cc220 (2864 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:2304 nr_irqs:512 16
[ 0.000000] CPU 0 irqstacks, hard=f5c08000 soft=f5c0a000
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1599.918 MHz processor.
[ 0.008007] Calibrating delay loop (skipped), value calculated using timer frequency.. 3199.83 BogoMIPS (lpj=6399672)
[ 0.008025] pid_max: default: 32768 minimum: 301
[ 0.008311] Security Framework initialized
[ 0.008327] AppArmor: AppArmor disabled by boot time parameter
[ 0.008430] Mount-cache hash table entries: 512
[ 0.008961] Initializing cgroup subsys cpuacct
[ 0.008982] Initializing cgroup subsys memory
[ 0.009023] Initializing cgroup subsys devices
[ 0.009032] Initializing cgroup subsys freezer
[ 0.009041] Initializing cgroup subsys net_cls
[ 0.009052] Initializing cgroup subsys blkio
[ 0.009080] Initializing cgroup subsys perf_event
[ 0.009207] CPU: Physical Processor ID: 0
[ 0.009215] CPU: Processor Core ID: 0
[ 0.009224] mce: CPU supports 5 MCE banks
[ 0.009246] CPU0: Thermal monitoring enabled (TM1)
[ 0.009261] using mwait in idle threads.
[ 0.012490] ACPI: Core revision 20110623
[ 0.027922] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.028509] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.068222] CPU0: Intel(R) Atom(TM) CPU N270 @ 1.60GHz stepping 02
[ 0.072003] Performance Events: PEBS fmt0+, Atom events, Intel PMU driver.
[ 0.072003] ... version: 3
[ 0.072003] ... bit width: 40
[ 0.072003] ... generic registers: 2
[ 0.072003] ... value mask: 000000ffffffffff
[ 0.072003] ... max period: 000000007fffffff
[ 0.072003] ... fixed-purpose events: 3
[ 0.072003] ... event mask: 0000000700000003
[ 0.089167] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.108171] CPU 1 irqstacks, hard=f5cd2000 soft=f5cd4000
[ 0.108186] Booting Node 0, Processors #1 Ok.
[ 0.108204] smpboot cpu 1: start_ip = 9b000
[ 0.012000] Initializing CPU#1
[ 0.200194] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.204068] Brought up 2 CPUs
[ 0.204090] Total of 2 processors activated (6400.18 BogoMIPS).
[ 0.204907] devtmpfs: initialized
[ 0.205652] PM: Registering ACPI NVS region at 3f6e0000 (12288 bytes)
[ 0.209069] print_constraints: dummy:
[ 0.209577] NET: Registered protocol family 16
[ 0.210473] ACPI: bus type pci registered
[ 0.211008] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.211029] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.211041] PCI: Using MMCONFIG for extended config space
[ 0.211053] PCI: Using configuration type 1 for base access
[ 0.217143] bio: create slab <bio-0> at 0
[ 0.217143] ACPI: Added _OSI(Module Device)
[ 0.217143] ACPI: Added _OSI(Processor Device)
[ 0.217143] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.217143] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.223578] ACPI: EC: Look up EC in DSDT
[ 0.265764] ACPI: SSDT 0x000000003F6E6500 002AE (v01 PmRef Cpu0Ist 00003000 INTL 20050930)
[ 0.267088] ACPI: Dynamic OEM Table Load:
[ 0.267111] ACPI: SSDT 0x0000000000000000 002AE (v01 PmRef Cpu0Ist 00003000 INTL 20050930)
[ 0.273413] ACPI: SSDT 0x000000003F6E69C0 00152 (v01 PmRef Cpu1Ist 00003000 INTL 20050930)
[ 0.274624] ACPI: Dynamic OEM Table Load:
[ 0.274647] ACPI: SSDT 0x0000000000000000 00152 (v01 PmRef Cpu1Ist 00003000 INTL 20050930)
[ 0.276157] ACPI: Interpreter enabled
[ 0.276189] ACPI: (supports S0 S3 S4 S5)
[ 0.276412] ACPI: Using IOAPIC for interrupt routing
[ 0.314359] ACPI: No dock devices found.
[ 0.314375] HEST: Table not found.
[ 0.314398] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.314997] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.316407] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7]
[ 0.316426] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff]
[ 0.316443] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.316459] pci_root PNP0A08:00: host bridge window [mem 0x000c0000-0x000dffff]
[ 0.316475] pci_root PNP0A08:00: host bridge window [mem 0x3f750000-0xfebfffff]
[ 0.316552] pci 0000:00:00.0: [8086:27ac] type 0 class 0x000600
[ 0.316720] pci 0000:00:02.0: [8086:27ae] type 0 class 0x000300
[ 0.316761] pci 0000:00:02.0: reg 10: [mem 0xfdf00000-0xfdf7ffff]
[ 0.316787] pci 0000:00:02.0: reg 14: [io 0xff00-0xff07]
[ 0.316814] pci 0000:00:02.0: reg 18: [mem 0xd0000000-0xdfffffff pref]
[ 0.316840] pci 0000:00:02.0: reg 1c: [mem 0xfdf80000-0xfdfbffff]
[ 0.316975] pci 0000:00:02.1: [8086:27a6] type 0 class 0x000380
[ 0.317010] pci 0000:00:02.1: reg 10: [mem 0xfde80000-0xfdefffff]
[ 0.317250] pci 0000:00:1b.0: [8086:27d8] type 0 class 0x000403
[ 0.317302] pci 0000:00:1b.0: reg 10: [mem 0xfdff8000-0xfdffbfff 64bit]
[ 0.317481] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.317559] pci 0000:00:1c.0: [8086:27d0] type 1 class 0x000604
[ 0.317745] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.317845] pci 0000:00:1d.0: [8086:27c8] type 0 class 0x000c03
[ 0.317945] pci 0000:00:1d.0: reg 20: [io 0xfe00-0xfe1f]
[ 0.318044] pci 0000:00:1d.1: [8086:27c9] type 0 class 0x000c03
[ 0.318143] pci 0000:00:1d.1: reg 20: [io 0xfd00-0xfd1f]
[ 0.318252] pci 0000:00:1d.2: [8086:27ca] type 0 class 0x000c03
[ 0.318351] pci 0000:00:1d.2: reg 20: [io 0xfc00-0xfc1f]
[ 0.318448] pci 0000:00:1d.3: [8086:27cb] type 0 class 0x000c03
[ 0.318548] pci 0000:00:1d.3: reg 20: [io 0xfb00-0xfb1f]
[ 0.318675] pci 0000:00:1d.7: [8086:27cc] type 0 class 0x000c03
[ 0.318726] pci 0000:00:1d.7: reg 10: [mem 0xfdfff000-0xfdfff3ff]
[ 0.318903] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.318970] pci 0000:00:1e.0: [8086:2448] type 1 class 0x000604
[ 0.319155] pci 0000:00:1f.0: [8086:27b9] type 0 class 0x000601
[ 0.319346] pci 0000:00:1f.0: Force enabled HPET at 0xfed00000
[ 0.319377] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0280 (mask 007f)
[ 0.319395] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 2 PIO at 0290 (mask 0007)
[ 0.319505] pci 0000:00:1f.1: [8086:27df] type 0 class 0x000101
[ 0.319544] pci 0000:00:1f.1: reg 10: [io 0x0000-0x0007]
[ 0.319575] pci 0000:00:1f.1: reg 14: [io 0x0000-0x0003]
[ 0.319605] pci 0000:00:1f.1: reg 18: [io 0x0000-0x0007]
[ 0.319635] pci 0000:00:1f.1: reg 1c: [io 0x0000-0x0003]
[ 0.319666] pci 0000:00:1f.1: reg 20: [io 0xfa00-0xfa0f]
[ 0.319783] pci 0000:00:1f.3: [8086:27da] type 0 class 0x000c05
[ 0.319906] pci 0000:00:1f.3: reg 20: [io 0x0500-0x051f]
[ 0.320188] pci 0000:01:00.0: [10ec:8168] type 0 class 0x000200
[ 0.320237] pci 0000:01:00.0: reg 10: [io 0xee00-0xeeff]
[ 0.320303] pci 0000:01:00.0: reg 18: [mem 0xfdcff000-0xfdcfffff 64bit]
[ 0.320349] pci 0000:01:00.0: reg 20: [mem 0xfddfc000-0xfddfffff 64bit pref]
[ 0.320385] pci 0000:01:00.0: reg 30: [mem 0x00000000-0x0001ffff pref]
[ 0.320522] pci 0000:01:00.0: supports D1 D2
[ 0.320536] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.328065] pci 0000:00:1c.0: PCI bridge to [bus 01-01]
[ 0.328086] pci 0000:00:1c.0: bridge window [io 0xe000-0xefff]
[ 0.328106] pci 0000:00:1c.0: bridge window [mem 0xfdc00000-0xfdcfffff]
[ 0.328131] pci 0000:00:1c.0: bridge window [mem 0xfdd00000-0xfddfffff 64bit pref]
[ 0.328280] pci 0000:00:1e.0: PCI bridge to [bus 02-02] (subtractive decode)
[ 0.328300] pci 0000:00:1e.0: bridge window [io 0xd000-0xdfff]
[ 0.328319] pci 0000:00:1e.0: bridge window [mem 0xfdb00000-0xfdbfffff]
[ 0.328343] pci 0000:00:1e.0: bridge window [mem 0xfda00000-0xfdafffff 64bit pref]
[ 0.328362] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.328380] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.328398] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.328432] pci 0000:00:1e.0: bridge window [mem 0x000c0000-0x000dffff] (subtractive decode)
[ 0.328451] pci 0000:00:1e.0: bridge window [mem 0x3f750000-0xfebfffff] (subtractive decode)
[ 0.328491] pci_bus 0000:00: on NUMA node 0
[ 0.328515] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.330505] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX0._PRT]
[ 0.331176] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.HUB0._PRT]
[ 0.332449] pci0000:00: Requesting ACPI _OSC control (0x1d)
[ 0.332474] pci0000:00: ACPI _OSC request failed (AE_NOT_FOUND), returned control mask: 0x1d
[ 0.332487] ACPI _OSC control for PCIe not granted, disabling ASPM
[ 0.433274] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 9 10 11 12 14 *15)
[ 0.433813] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.434356] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 9 *10 11 12 14 15)
[ 0.434890] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 7 9 10 11 12 14 15)
[ 0.435424] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.435965] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.436594] ACPI: PCI Interrupt Link [LNK0] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.437138] ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 5 7 9 10 *11 12 14 15)
[ 0.437684] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.437684] vgaarb: loaded
[ 0.437684] vgaarb: bridge control possible 0000:00:02.0
[ 0.437684] PCI: Using ACPI for IRQ routing
[ 0.452321] PCI: pci_cache_line_size set to 64 bytes
[ 0.452694] reserve RAM buffer: 000000000009f000 - 000000000009ffff
[ 0.452715] reserve RAM buffer: 000000003f690000 - 000000003fffffff
[ 0.453802] hpet clockevent registered
[ 0.453827] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[ 0.453848] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.453881] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.460171] Switching to clocksource hpet
[ 0.480791] pnp: PnP ACPI init
[ 0.480901] ACPI: bus type pnp registered
[ 0.481667] pnp 00:00: [bus 00-ff]
[ 0.481687] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.481705] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.481721] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.481738] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.481755] pnp 00:00: [mem 0x000c0000-0x000dffff window]
[ 0.481773] pnp 00:00: [mem 0x3f750000-0xfebfffff window]
[ 0.482120] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.482836] pnp 00:01: [io 0x0010-0x001f]
[ 0.482854] pnp 00:01: [io 0x0022-0x003f]
[ 0.482869] pnp 00:01: [io 0x0044-0x005f]
[ 0.482884] pnp 00:01: [io 0x0062-0x0063]
[ 0.482899] pnp 00:01: [io 0x0065-0x006f]
[ 0.482914] pnp 00:01: [io 0x0074-0x007f]
[ 0.482929] pnp 00:01: [io 0x0091-0x0093]
[ 0.482944] pnp 00:01: [io 0x00a2-0x00bf]
[ 0.482959] pnp 00:01: [io 0x00e0-0x00ef]
[ 0.482974] pnp 00:01: [io 0x04d0-0x04d1]
[ 0.482989] pnp 00:01: [io 0x0280-0x02ff]
[ 0.483004] pnp 00:01: [io 0x0880-0x088f]
[ 0.483445] system 00:01: [io 0x04d0-0x04d1] has been reserved
[ 0.483468] system 00:01: [io 0x0280-0x02ff] has been reserved
[ 0.483489] system 00:01: [io 0x0880-0x088f] has been reserved
[ 0.483512] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.483655] pnp 00:02: [dma 4]
[ 0.483671] pnp 00:02: [io 0x0000-0x000f]
[ 0.483686] pnp 00:02: [io 0x0080-0x0090]
[ 0.483701] pnp 00:02: [io 0x0094-0x009f]
[ 0.483716] pnp 00:02: [io 0x00c0-0x00df]
[ 0.483959] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.484186] pnp 00:03: [io 0x0070-0x0073]
[ 0.484225] pnp 00:03: [irq 8]
[ 0.484489] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.484585] pnp 00:04: [io 0x0061]
[ 0.484833] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.484929] pnp 00:05: [io 0x00f0-0x00ff]
[ 0.484961] pnp 00:05: [irq 13]
[ 0.485212] pnp 00:05: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.485805] pnp 00:06: [io 0x0060]
[ 0.485822] pnp 00:06: [io 0x0064]
[ 0.485851] pnp 00:06: [irq 1]
[ 0.486130] pnp 00:06: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[ 0.486343] pnp 00:07: [io 0x0400-0x04bf]
[ 0.486760] system 00:07: [io 0x0400-0x04bf] could not be reserved
[ 0.486783] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.486995] pnp 00:08: [mem 0xffb80000-0xffbfffff]
[ 0.487271] pnp 00:08: Plug and Play ACPI device, IDs INT0800 (active)
[ 0.489672] pnp 00:09: [mem 0xe0000000-0xefffffff]
[ 0.490163] system 00:09: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.490188] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.491085] pnp 00:0a: [mem 0x000f0000-0x000fffff]
[ 0.491104] pnp 00:0a: [mem 0x3f6e0000-0x3f6fffff]
[ 0.491121] pnp 00:0a: [mem 0x00000000-0x0009ffff]
[ 0.491137] pnp 00:0a: [mem 0x00100000-0x3f6dffff]
[ 0.491154] pnp 00:0a: [mem 0x00000000-0xffffffffffffffff disabled]
[ 0.491171] pnp 00:0a: [mem 0xfec00000-0xfec00fff]
[ 0.491186] pnp 00:0a: [mem 0xfed13000-0xfed1dfff]
[ 0.491202] pnp 00:0a: [mem 0xfed20000-0xfed8ffff]
[ 0.491218] pnp 00:0a: [mem 0xfee00000-0xfee00fff]
[ 0.491234] pnp 00:0a: [mem 0xffb00000-0xffb7ffff]
[ 0.491250] pnp 00:0a: [mem 0xfff00000-0xffffffff]
[ 0.491266] pnp 00:0a: [mem 0x000e0000-0x000effff]
[ 0.491795] system 00:0a: [mem 0x000f0000-0x000fffff] could not be reserved
[ 0.491822] system 00:0a: [mem 0x3f6e0000-0x3f6fffff] could not be reserved
[ 0.491847] system 00:0a: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.491871] system 00:0a: [mem 0x00100000-0x3f6dffff] could not be reserved
[ 0.491897] system 00:0a: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.491918] system 00:0a: [mem 0xfed13000-0xfed1dfff] has been reserved
[ 0.491940] system 00:0a: [mem 0xfed20000-0xfed8ffff] has been reserved
[ 0.491961] system 00:0a: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.491982] system 00:0a: [mem 0xffb00000-0xffb7ffff] has been reserved
[ 0.492004] system 00:0a: [mem 0xfff00000-0xffffffff] has been reserved
[ 0.492095] system 00:0a: [mem 0x000e0000-0x000effff] has been reserved
[ 0.492120] system 00:0a: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.492171] pnp: PnP ACPI: found 11 devices
[ 0.492182] ACPI: ACPI bus type pnp unregistered
[ 0.492198] PnPBIOS: Disabled by ACPI PNP
[ 0.548392] PCI: max bus depth: 1 pci_try_num: 2
[ 0.548479] pci 0000:01:00.0: BAR 6: assigned [mem 0xfdd00000-0xfdd1ffff pref]
[ 0.548500] pci 0000:00:1c.0: PCI bridge to [bus 01-01]
[ 0.548518] pci 0000:00:1c.0: bridge window [io 0xe000-0xefff]
[ 0.548540] pci 0000:00:1c.0: bridge window [mem 0xfdc00000-0xfdcfffff]
[ 0.548560] pci 0000:00:1c.0: bridge window [mem 0xfdd00000-0xfddfffff 64bit pref]
[ 0.548585] pci 0000:00:1e.0: PCI bridge to [bus 02-02]
[ 0.548601] pci 0000:00:1e.0: bridge window [io 0xd000-0xdfff]
[ 0.548623] pci 0000:00:1e.0: bridge window [mem 0xfdb00000-0xfdbfffff]
[ 0.548643] pci 0000:00:1e.0: bridge window [mem 0xfda00000-0xfdafffff 64bit pref]
[ 0.548736] pci 0000:00:1c.0: setting latency timer to 64
[ 0.548768] pci 0000:00:1e.0: setting latency timer to 64
[ 0.548788] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.548803] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.548819] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.548834] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000dffff]
[ 0.548850] pci_bus 0000:00: resource 8 [mem 0x3f750000-0xfebfffff]
[ 0.548866] pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
[ 0.548881] pci_bus 0000:01: resource 1 [mem 0xfdc00000-0xfdcfffff]
[ 0.548897] pci_bus 0000:01: resource 2 [mem 0xfdd00000-0xfddfffff 64bit pref]
[ 0.548914] pci_bus 0000:02: resource 0 [io 0xd000-0xdfff]
[ 0.548929] pci_bus 0000:02: resource 1 [mem 0xfdb00000-0xfdbfffff]
[ 0.548945] pci_bus 0000:02: resource 2 [mem 0xfda00000-0xfdafffff 64bit pref]
[ 0.548961] pci_bus 0000:02: resource 4 [io 0x0000-0x0cf7]
[ 0.548975] pci_bus 0000:02: resource 5 [io 0x0d00-0xffff]
[ 0.548991] pci_bus 0000:02: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.549006] pci_bus 0000:02: resource 7 [mem 0x000c0000-0x000dffff]
[ 0.549022] pci_bus 0000:02: resource 8 [mem 0x3f750000-0xfebfffff]
[ 0.549459] NET: Registered protocol family 2
[ 0.563492] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.565978] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.568211] TCP bind hash table entries: 65536 (order: 8, 1835008 bytes)
[ 0.571787] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.571801] TCP reno registered
[ 0.571831] UDP hash table entries: 512 (order: 3, 32768 bytes)
[ 0.571914] UDP-Lite hash table entries: 512 (order: 3, 32768 bytes)
[ 0.572741] NET: Registered protocol family 1
[ 0.572845] pci 0000:00:02.0: Boot video device
[ 0.573373] PCI: CLS 64 bytes, default 64
[ 0.573837] Unpacking initramfs...
[ 2.170486] Freeing initrd memory: 15164k freed
[ 2.198244] audit: initializing netlink socket (disabled)
[ 2.198314] type=2000 audit(1468441030.192:1): initialized
[ 2.256278] highmem bounce pool size: 64 pages
[ 2.256313] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 2.257499] VFS: Disk quotas dquot_6.5.2
[ 2.257784] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 2.258278] msgmni has been set to 1748
[ 2.259541] alg: No test for stdrng (krng)
[ 2.259771] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 2.259790] io scheduler noop registered
[ 2.259802] io scheduler deadline registered
[ 2.259926] io scheduler cfq registered (default)
[ 2.260710] pcieport 0000:00:1c.0: setting latency timer to 64
[ 2.260843] pcieport 0000:00:1c.0: irq 40 for MSI/MSI-X
[ 2.261472] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 2.261691] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 2.261705] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 2.264405] intel_idle: MWAIT substates: 0x20220
[ 2.264439] intel_idle: v0.4 model 0x1C
[ 2.264451] intel_idle: lapic_timer_reliable_states 0x2
[ 2.264463] Marking TSC unstable due to TSC halts in idle states deeper than C2
[ 2.264665] ERST: Table is not found!
[ 2.264676] GHES: HEST is not enabled!
[ 2.264781] isapnp: Scanning for PnP cards...
[ 2.619244] isapnp: No Plug & Play device found
[ 2.619700] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 2.765391] Linux agpgart interface v0.103
[ 2.766388] agpgart-intel 0000:00:00.0: Intel 945GME Chipset
[ 2.766704] agpgart-intel 0000:00:00.0: detected gtt size: 262144K total, 262144K mappable
[ 2.766989] agpgart-intel 0000:00:00.0: detected 8192K stolen memory
[ 2.767547] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xd0000000
[ 2.768805] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[ 2.768821] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 2.769483] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 2.770469] mousedev: PS/2 mouse device common for all mice
[ 2.770796] rtc_cmos 00:03: RTC can wake from S4
[ 2.771359] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[ 2.771608] rtc0: alarms up to one month, 242 bytes nvram, hpet irqs
[ 2.772156] cpuidle: using governor ladder
[ 2.772828] cpuidle: using governor menu
[ 2.775457] TCP cubic registered
[ 2.775813] NET: Registered protocol family 10
[ 2.782023] Mobile IPv6
[ 2.782095] NET: Registered protocol family 17
[ 2.782139] Registering the dns_resolver key type
[ 2.782306] Using IPI No-Shortcut mode
[ 2.782832] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 2.783321] PM: Hibernation image not present or could not be loaded.
[ 2.783412] registered taskstats version 1
[ 2.784813] rtc_cmos 00:03: setting system clock to 2016-07-13 20:17:11 UTC (1468441031)
[ 2.785194] Initializing network drop monitor service
[ 2.786063] Freeing unused kernel memory: 728k freed
[ 2.787568] Write protecting the kernel text: 2868k
[ 2.787889] Write protecting the kernel read-only data: 1076k
[ 2.787906] NX-protecting the kernel data: 3276k
[ 2.869543] udevd[61]: starting version 175
[ 3.091458] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 3.091679] r8169 0000:01:00.0: setting latency timer to 64
[ 3.091854] r8169 0000:01:00.0: irq 41 for MSI/MSI-X
[ 3.155366] r8169 0000:01:00.0: eth0: RTL8168d/8111d at 0xf821e000, 00:e0:c5:3d:39:d6, XID 081000c0 IRQ 41
[ 3.155399] r8169 0000:01:00.0: eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 3.162641] usbcore: registered new interface driver usbfs
[ 3.162896] usbcore: registered new interface driver hub
[ 3.178983] usbcore: registered new device driver usb
[ 3.270665] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.270977] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 3.271002] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 3.271263] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 3.271437] ehci_hcd 0000:00:1d.7: using broken periodic workaround
[ 3.271477] ehci_hcd 0000:00:1d.7: debug port 1
[ 3.282623] uhci_hcd: USB Universal Host Controller Interface driver
[ 3.284329] ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
[ 3.301199] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xfdfff000
[ 3.316164] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 3.316813] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.316843] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.316866] usb usb1: Product: EHCI Host Controller
[ 3.316884] usb usb1: Manufacturer: Linux 3.2.0-4-rt-686-pae ehci_hcd
[ 3.316905] usb usb1: SerialNumber: 0000:00:1d.7
[ 3.333116] hub 1-0:1.0: USB hub found
[ 3.333181] hub 1-0:1.0: 8 ports detected
[ 3.334270] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 3.334298] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 3.334387] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 3.341326] SCSI subsystem initialized
[ 3.353141] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000fe00
[ 3.353585] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.353612] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.353634] usb usb2: Product: UHCI Host Controller
[ 3.353653] usb usb2: Manufacturer: Linux 3.2.0-4-rt-686-pae uhci_hcd
[ 3.353673] usb usb2: SerialNumber: 0000:00:1d.0
[ 3.427326] hub 2-0:1.0: USB hub found
[ 3.427399] hub 2-0:1.0: 2 ports detected
[ 3.433901] libata version 3.00 loaded.
[ 3.439250] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 3.439279] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 3.439469] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 3.439888] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000fd00
[ 3.440280] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.440298] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.440313] usb usb3: Product: UHCI Host Controller
[ 3.440326] usb usb3: Manufacturer: Linux 3.2.0-4-rt-686-pae uhci_hcd
[ 3.440339] usb usb3: SerialNumber: 0000:00:1d.1
[ 3.452492] hub 3-0:1.0: USB hub found
[ 3.452568] hub 3-0:1.0: 2 ports detected
[ 3.453522] ata_piix 0000:00:1f.1: version 2.13
[ 3.453920] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 3.489963] scsi0 : ata_piix
[ 3.498962] scsi1 : ata_piix
[ 3.530164] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xfa00 irq 14
[ 3.530192] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xfa08 irq 15
[ 3.536614] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 3.536642] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 3.536751] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 3.538569] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000fc00
[ 3.539005] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.539031] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.539052] usb usb4: Product: UHCI Host Controller
[ 3.539071] usb usb4: Manufacturer: Linux 3.2.0-4-rt-686-pae uhci_hcd
[ 3.539091] usb usb4: SerialNumber: 0000:00:1d.2
[ 3.540770] hub 4-0:1.0: USB hub found
[ 3.540837] hub 4-0:1.0: 2 ports detected
[ 3.541881] uhci_hcd 0000:00:1d.3: setting latency timer to 64
[ 3.541908] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 3.542004] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 3.544288] ata2: port disabled--ignoring
[ 3.553575] uhci_hcd 0000:00:1d.3: irq 16, io base 0x0000fb00
[ 3.554014] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.554041] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.554064] usb usb5: Product: UHCI Host Controller
[ 3.554083] usb usb5: Manufacturer: Linux 3.2.0-4-rt-686-pae uhci_hcd
[ 3.554103] usb usb5: SerialNumber: 0000:00:1d.3
[ 3.555558] hub 5-0:1.0: USB hub found
[ 3.555623] hub 5-0:1.0: 2 ports detected
[ 3.704865] ata1.00: ATA-9: KingSpec KDM-44VS.2-008GMS, 20131216, max UDMA/133
[ 3.704894] ata1.00: 15977808 sectors, multi 0: LBA
[ 3.712654] ata1.00: configured for UDMA/100
[ 3.713282] scsi 0:0:0:0: Direct-Access ATA KingSpec KDM-44V 2013 PQ: 0 ANSI: 5
[ 3.798369] sd 0:0:0:0: [sda] 15977808 512-byte logical blocks: (8.18 GB/7.61 GiB)
[ 3.799286] sd 0:0:0:0: [sda] Write Protect is off
[ 3.799312] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 3.799540] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 3.804871] sda: sda1 sda2 < sda5 >
[ 3.807893] sd 0:0:0:0: [sda] Attached SCSI disk
[ 3.824323] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 4.052131] usb 2-1: new full-speed USB device number 2 using uhci_hcd
[ 4.234440] usb 2-1: New USB device found, idVendor=07a6, idProduct=8511
[ 4.234462] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.234477] usb 2-1: Product: USB To LAN Converter
[ 4.234490] usb 2-1: Manufacturer: ADMtek
[ 4.234502] usb 2-1: SerialNumber: 0001
[ 4.480133] usb 3-1: new full-speed USB device number 2 using uhci_hcd
[ 4.678220] usb 3-1: New USB device found, idVendor=0403, idProduct=6001
[ 4.678239] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.678255] usb 3-1: Product: ARDUINO NANO
[ 4.678267] usb 3-1: Manufacturer: Gravitech
[ 4.678279] usb 3-1: SerialNumber: 16TP0333
[ 4.924128] usb 3-2: new low-speed USB device number 3 using uhci_hcd
[ 5.107220] usb 3-2: New USB device found, idVendor=045e, idProduct=0039
[ 5.107241] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.107256] usb 3-2: Product: Microsoft IntelliMouse\xffffffc2\xffffffae\xffffffae Optical
[ 5.107270] usb 3-2: Manufacturer: Microsoft
[ 5.147572] input: Microsoft Microsoft IntelliMouse\xffffffc2\xffffffae\xffffffae Optical as /devices/pci0000:00/0000:00:1d.1/usb3/3-2/3-2:1.0/input/input1
[ 5.148604] generic-usb 0003:045E:0039.0001: input,hidraw0: USB HID v1.00 Mouse [Microsoft Microsoft IntelliMouse\xffffffc2\xffffffae\xffffffae Optical] on usb-0000:00:1d.1-2/input0
[ 5.148817] usbcore: registered new interface driver usbhid
[ 5.148836] usbhid: USB HID core driver
[ 9.159571] microcode: CPU0 sig=0x106c2, pf=0x4, revision=0x212
[ 9.182259] platform microcode: firmware: agent loaded intel-ucode/06-1c-02 into memory
[ 9.185704] microcode: CPU0 updated to revision 0x218, date = 2009-04-10
[ 9.193298] microcode: CPU1 sig=0x106c2, pf=0x4, revision=0x212
[ 9.209555] platform microcode: firmware: agent loaded intel-ucode/06-1c-02 into memory
[ 9.212981] microcode: CPU1 updated to revision 0x218, date = 2009-04-10
[ 9.220152] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 9.327877] PM: Starting manual resume from disk
[ 9.327895] PM: Hibernation image partition 8:5 present
[ 9.327907] PM: Looking for hibernation image.
[ 9.328971] PM: Image not found (code -22)
[ 9.328984] PM: Hibernation image not present or could not be loaded.
[ 9.407339] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 10.672178] udevd[363]: starting version 175
[ 11.320493] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[ 11.320535] ACPI: Power Button [PWRB]
[ 11.323825] ACPI: Requesting acpi_cpufreq
[ 11.380748] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 11.380788] ACPI: Power Button [PWRF]
[ 11.609485] intel_rng: FWH not detected
[ 11.634129] [drm] Initialized drm 1.1.0 20060810
[ 11.689949] iTCO_vendor_support: vendor-support=0
[ 11.725538] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 11.749324] iTCO_wdt: unable to reset NO_REBOOT flag, device disabled by hardware/BIOS
[ 11.791294] leds_ss4200: no LED devices found
[ 11.822182] input: PC Speaker as /devices/platform/pcspkr/input/input4
[ 11.838551] i915 0000:00:02.0: setting latency timer to 64
[ 12.102525] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 12.102536] [drm] Driver supports precise vblank timestamp query.
[ 12.103177] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 12.303214] [drm] initialized overlay support
[ 12.306360] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 12.505966] usbcore: registered new interface driver usbserial
[ 12.506056] USB Serial support registered for generic
[ 12.506244] usbcore: registered new interface driver usbserial_generic
[ 12.506255] usbserial: USB Serial Driver core
[ 12.537531] USB Serial support registered for FTDI USB Serial Device
[ 12.537795] ftdi_sio 3-1:1.0: FTDI USB Serial Device converter detected
[ 12.538058] pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB Ethernet driver
[ 12.541963] usb 3-1: Detected FT232RL
[ 12.541974] usb 3-1: Number of endpoints 2
[ 12.541984] usb 3-1: Endpoint 1 MaxPacketSize 64
[ 12.541993] usb 3-1: Endpoint 2 MaxPacketSize 64
[ 12.542001] usb 3-1: Setting MaxPacketSize 64
[ 12.545402] usb 3-1: FTDI USB Serial Device converter now attached to ttyUSB0
[ 12.545528] usbcore: registered new interface driver ftdi_sio
[ 12.545537] ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver
[ 12.558434] pegasus 2-1:1.0: setup Pegasus II specific registers
[ 12.746323] fbcon: inteldrmfb (fb0) is primary device
[ 12.756077] pegasus 2-1:1.0: eth1, ADMtek ADM8511 "Pegasus II" USB Ethernet, 00:40:f4:ee:f9:e9
[ 12.756202] usbcore: registered new interface driver pegasus
[ 12.925360] Console: switching to colour frame buffer device 200x56
[ 12.942821] fb0: inteldrmfb frame buffer device
[ 12.942827] drm: registered panic notifier
[ 12.942846] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 12.943122] snd_hda_intel 0000:00:1b.0: irq 42 for MSI/MSI-X
[ 12.944683] snd_hda_intel 0000:00:1b.0: setting latency timer to 64
[ 14.221425] Adding 376828k swap on /dev/sda5. Priority:-1 extents:1 across:376828k SS
[ 14.315925] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 14.490944] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 14.647400] loop: module loaded
[ 17.366458] pegasus 2-1:1.0: eth1: update_eth_regs_async, status -22
[ 17.366796] pegasus 2-1:1.0: eth1: update_eth_regs_async, status -22
[ 18.028268] RPC: Registered named UNIX socket transport module.
[ 18.028277] RPC: Registered udp transport module.
[ 18.028283] RPC: Registered tcp transport module.
[ 18.028289] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 18.049680] FS-Cache: Loaded
[ 18.083795] FS-Cache: Netfs 'nfs' registered for caching
[ 18.101278] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 18.355041] r8169 0000:01:00.0: firmware: agent loaded rtl_nic/rtl8168d-1.fw into memory
[ 18.415982] r8169 0000:01:00.0: eth0: link down
[ 18.416082] r8169 0000:01:00.0: eth0: link down
[ 18.416664] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 20.050718] r8169 0000:01:00.0: eth0: link up
[ 20.051180] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 20.916985] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input5
[ 21.178261] pegasus 2-1:1.0: eth1: update_eth_regs_async, status -22
[ 21.562307] lp: driver loaded but no devices found
[ 21.614739] Bluetooth: Core ver 2.16
[ 21.615955] NET: Registered protocol family 31
[ 21.615968] Bluetooth: HCI device and connection manager initialized
[ 21.615983] Bluetooth: HCI socket layer initialized
[ 21.615993] Bluetooth: L2CAP socket layer initialized
[ 21.620170] Bluetooth: SCO socket layer initialized
[ 21.655195] ppdev: user-space parallel port driver
[ 21.695515] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 21.695525] Bluetooth: BNEP filters: protocol multicast
[ 21.714566] Bluetooth: RFCOMM TTY layer initialized
[ 21.714593] Bluetooth: RFCOMM socket layer initialized
[ 21.714600] Bluetooth: RFCOMM ver 1.11
[ 27.808109] eth1: no IPv6 routers present
[ 30.240116] eth0: no IPv6 routers present
[ 285.102345] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 290.189806] pegasus 2-1:1.0: eth1: update_eth_regs_async, status -22
[ 290.189831] pegasus 2-1:1.0: eth1: update_eth_regs_async, status -22
[ 290.189851] pegasus 2-1:1.0: eth1: update_eth_regs_async, status -22
