LutzTD wrote: today I loaded linuxcnc debian from this link www.linuxcnc.org/linuxcnc-2.7-wheezy.iso using all of the install instructions from here
then I installed arduino from here
connected the toolerator3000 pcba and using the toolerator300.ino from here
I compiled the toolerator3000.ino and loaded the software on the arduino nano on the toolerator3000 PCBA.
now I need to run this command "sudo halcompile --INSTALL toolerator.comp" but "halcompile" comes back as command not found.
where can I get this command file?
LutzTD wrote: does that mean it executed properly?
user@linuxcnc:~/linuxcnc$ sudo halcompile --install toolerator3000.comp
gcc -Os -g -I. -I/usr/realtime-3.4-9-rtai-686-pae/include -I. -I/usr/realtime-3.4-9-rtai-686-pae/include -I/usr/include/i386-linux-gnu -U_FORTIFY_SOURCE -D_FORTIFY_SOURCE=0 -fno-math-errno -funsafe-math-optimizations -fno-rounding-math -fno-signaling-nans -fcx-limited-range -mhard-float -DRTAI=3 -fno-fast-math -mieee-fp -fno-unsafe-math-optimizations -DRTAPI -D_GNU_SOURCE -Drealtime -D__MODULE__ -I/usr/include/linuxcnc -Wframe-larger-than=2560 -URTAPI -U__MODULE__ -DULAPI -Os -o toolerator3000 /tmp/tmp59_Fcm/toolerator3000.c -Wl,-rpath,/lib -L/lib -llinuxcnchal
