Z axis is off by .010" over 1/2"
- Roland2161
28 Jan 2019 02:20 #125001
by Roland2161
Z axis is off by .010" over 1/2" was created by Roland2161
Hi all,
So after reading a bunch I am stuck. My Z axis seems to be off exactly the same every time. Using a dial indicator I go to move .500, and it will only move .490. Then when it goes back to 0 it has moved an extra .001, every time. It keeps moving along. So it shifts as it repeats the same path. It will always travel .490", but it will always gain a .001 on one end and lose it on the other. I imagine its an step tuning issue. Any direction someone can point me in would be great. I do not know where I need to go to fix this.
I did not build this machine nor am I that experienced in linuxcnc past reading the manual, I purchased it to get a home shop running, and am using it as my learning tool so I can build my own machines. I am currently a novice learning as I go. Thanks for the understanding. Thank you.
- Leon82
- Thank you received: 79
28 Jan 2019 03:01 - 28 Jan 2019 03:04 #125005
by Leon82
Replied by Leon82 on topic Z axis is off by .010" over 1/2"
You can go into step config and look at the pitch of the axis screw. 5 rev per inch for example. If it's a metric screw like 5mm make sure the rev per inch goes out a bunch of decmial places. Exit without saving and Discard changes when you exit as it can overwrite some configurations done after
In the ini its listed as scale I believe. You can play with the value
In the ini see if they have a line backlash=.000. here you can adjust your backlash comp.
There should be a folder for your machine with about 10 files in it.
Last edit: 28 Jan 2019 03:04 by Leon82.
- Thank you received: 1470
28 Jan 2019 03:19 #125011
Replied by Todd Zuercher on topic Z axis is off by .010" over 1/2"
Loosing steps is the most likely of suspects. First you should look up the specifications for the step timings for your stepper drives. Then I would suggest setting them to 150-200% of the minimums specified. The next thing is to do a reality check on the acceleration limits in your configuration, and set them to something reasonable if they are too high.
Lost steps isn't the only possibility though. some kind of mechanical slippage is also possible. Check to be sure there couldn't be a coupling or pulley slipping anywhere.
- Thank you received: 4648
29 Jan 2019 22:34 #125215
Is the error proportional? Is 0.25" actually 0.245? 0.75 = 0.735?
If so then it looks like a simple scaling error. 5 TPI leadscrew and 5mm leadscrew are about the right error to account for this.
(0.5" / 5.08" * 5mm = 0.492..)
Replied by andypugh on topic Z axis is off by .010" over 1/2"
So after reading a bunch I am stuck. My Z axis seems to be off exactly the same every time. Using a dial indicator I go to move .500, and it will only move .490. .
- Roland2161
30 Jan 2019 00:40 #125232
by Roland2161
Andy,
Yes the error is proportional. I moved it a 1/4'' and it was off .005. Moved it a half inch and it was off almost exactly .492. and .75 was mor like .738 ish, but I have a half thousandth of backlash. Not sure if it is accounted for.
How would I fix this? What menu would I go in? Or where about's in the manual? I uploaded a picture of the servo tune. I think the acceleration might be to much? And it's missing a step as well?
Thank you.
Replied by Roland2161 on topic Z axis is off by .010" over 1/2"
Andy,
Thank you.
- Thank you received: 5308
30 Jan 2019 01:02 #125234
Replied by PCW on topic Z axis is off by .010" over 1/2"
You could try setting your step_scale to -20320
Also you acceleration is very quick (1.25/37.5 = 1/30 second to full speed)
you might need to reduce this also
30 Jan 2019 01:08 #125235
Yes, -20000 sounds like an assumed 5tpi on a metric machine and 20x microstepping (or gear ratio)
It is far more likely that ball screws are 5mm pitch, so that -20320 is the number.
Though, it has to be said, that 5tpi ball screws exist, I had exactly the opposite problem when I changed the ball screw on my milling machine Y axis. There is a very compact 16mm ball screw with a 5tpi pitch from Gten.
- Roland2161
04 Feb 2019 23:15 #125703
by Roland2161
Thank you all for the advice, I finally got back to the machine and presto, -20320 was the magic number. I ended up lowering the acceleration to 19 and that also solved the missing step issue.
Now what is happening is that it moves .002 further than commanded everytime I move. So from 0 to .250 it moves .252. Then from 0 to .750 it moves .752. What could be causing this? I do have .0005" of back lash. could that be causing this?
- Leon82
04 Feb 2019 23:29 #125704
by Leon82
The tolerance of the ballscrew depending on class may affect it.
You could tweak the scaling a little bit. Also you can go all out and map the screw for errors. But I have only read about it. Not sure how you would executive it
- Leon82
04 Feb 2019 23:31 - 04 Feb 2019 23:37 #125705
by Leon82
Also, perhaps fast descelleration could sent the "mass" of the table to load on the opposite side of the play in the screw
I'm not really sure why I quoted myself
Last edit: 04 Feb 2019 23:37 by Leon82.
Moderators: piasdom
Time to create page: 0.350 seconds
