Mazak QT20 Automatic tool changer
3 years 7 months ago #267006 by tommylight
3 years 7 months ago #267017 by dctrytsman
The other topic was specifically created for creating a new component for a Mazak tool changer that smc.collins is working on .At the moment I am trying to get carousel component to work with the machine and I didn't want to mix this with that topic .
3 years 7 months ago #267033 by tommylight
Ok, let us know when or if we should change the tittle to better describe it.
3 years 7 months ago #267081 by dctrytsman
You are right ,the topics are misleading .I'm not sure how to change it myself, but feel free to change it to what you think is appropriate .
3 years 7 months ago #267082 by andypugh
When I run M06 T08 the turret just keeps turning and never find T08 .
I think I can guess the problem. What bit-pattern is T8? I suspect that it is seen as zero and rejected.
If it is all-false can you confirm that that pattern is only seen at T8 and not in-between positions?
The following user(s) said Thank You: dctrytsman
3 years 7 months ago #267145 by dctrytsman
You are right ,The bit pattern for T8 is all zeros. The bit pattern does not change in between positions ,it goes directly from one to another .How can I get it to work with all zeros ?
Time to create page: 0.445 seconds
