Can i connect 7i29 to P4 connector on 5i20??
- machete
07 Oct 2011 16:52 #13760
by machete
Replied by machete on topic Re:Can i connect 7i29 to P4 connector on 5i20??
And please, if it is possible - configure handwheel for connecting to RX0 and RX1.
(its useful when making wire connections to 7i47S)
- Thank you received: 5156
08 Oct 2011 00:24 #13770
Replied by PCW on topic Re:Can i connect 7i29 to P4 connector on 5i20??
freeby.mesanet.com/machete.zip
- Thank you received: 2149
08 Oct 2011 00:28 #13771
Replied by cmorley on topic Re:Can i connect 7i29 to P4 connector on 5i20??
I think the reason the pins don;t match is because you (said you) are using firmware SVST8_4
when SVST2_4_7i47 is for the 7i47.
Peter will correct me if I'm wrong.
- machete
11 Oct 2011 13:03 #13826
by machete
PCW wrote:
Thank you very much!
But how can i add this firmware to my configuration?
I try to put this files to /lib/firmware/hm2/5i20/
but pncconf cant see them..
11 Oct 2011 13:14 - 11 Oct 2011 13:15 #13827
Until pncconf learns to read installed bitfiles, you can not use pncconf for custom bitfiles
you must get your hands dirty and edit the HAL and INI files yourself
Last edit: 11 Oct 2011 13:15 by PCW.
- machete
11 Oct 2011 14:01 #13831
by machete
PCW wrote:
OK
But in this case i have to ask you again to change P2<->P4 back... (sorry
Because now i have to write all pins for P2,3,4 by my "dirty hands" - and probably i make a lot of errors.
And if only difference will be in P3 - it will increase my chances, and common part of configuring i can make in pncconf (before editing by hands).
OK
11 Oct 2011 14:29 #13833
P3 (and the previously unsupported Spindle PWM on the 7I47) are all that should change. The servo settings should remain the same regardless of which connector the 7I29s are on. The 7I47 was unsupported before so that will not change, the only real thing that changes are GPIO pins for the 7I37
Time to create page: 0.165 seconds
