New Project questions
- SRT
1 Piece 5I22
1 Piece 7I33TA
3 Pieces 7I37TA
There are 26 limit switches on this machine alone. Tool turret, swing-up tail stock, travel ect........The bottom line is I need a lot of I/O. I would like a few opinions before I order.
Thank you
- BigJohnT
- Thank you received: 1176
- SRT
- SRT
- Thank you received: 5013
That leads me to ask another question. How would I get more I/o than this set-up?
Have a look at the 7i64, 7i69, 7i70, 7i71.
These cards connect via a fast serial interface. You can connect up to 8 individual cards to a single 5i22/5i23 header (normally via a 7i44). One header full of 1x7i44 + 8x 7i64 would be 192 x 48V inputs plus 192 x 48V outputs.
You might want to try to contact Stuart Stevenson, who retrofitted this 5-axis Cincinatti. I believe that is using the Pico PPMC hardware.
- SRT
- BigJohnT
- jmelson
- Thank you received: 160
They are similar in the way EMC supports the hardware. There are different philosophiesDoes the EMC config lend itself any better to the Mesa or Pico Systems hardware? Is one any more user friendly than the other. What about support from the vendors themselves?
on the two systems. The Pico scheme is very fixed, ie. each board does it's specific
function (encoder input, analog output, digital I/O). Also, everything you need is ON
the boards, there are no cables, breakout boards, adapters, etc. needed. So, the
digital I/O board does not use external IO mounting panels, the inputs are on the
board, and there are positions for 8 solid state relays to mount directly on the board.
The Mesa way, if I can be so bold as to explain my competitor's product, is to have
one master board which can be software-configured to do almost any combination
of functions, and then you add adapter boards to set it up for specific functions.
So, I think the Mesa is a bit more flexible, but may be a bit harder to configure
due to all the possible options.
I support the PPMC users as well as I can. I'm going out to a customer's
site tomorrow to advise on first startup of the system. (I usually can't
do that due to distance, but this one is fairly close.) I only support EMC
on my hardware, I think Mesa mostly supports other motion-control
software.
And, of course, you need to take anything I say with a grain of salt, not so
much that I'm pushing my own product but maybe that it is all so familiar
to me that it seems simple. I do have some schematics online and am glad
to consult on any questions that come up.
Jon
- SRT
- BigJohnT
duh there is a list of supported cards in the FAQ on this forum...
