Mesa 7i49 Board configuration
04 Mar 2012 04:29 #18333 by PCW
Replied by PCW on topic Re:Mesa 7i49 Board configuration
The problem I see is that your HAL file has all the PID terms set to 0:
P = 0.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
This means that the PWM value
(from the output of the PID component)
will be 0 regardless of position error
04 Mar 2012 09:15 #18334 by cncbasher
Replied by cncbasher on topic Re:Mesa 7i49 Board configuration
even with values for P & D ( 1.0 1.0 )
there's no effort to even start the servos
  • hatch789
  • hatch789's Avatar Topic Author
  • Premium Member
  • Premium Member
04 Mar 2012 14:17 #18341 by hatch789
Replied by hatch789 on topic Re:Mesa 7i49 Board configuration
yes we changed P & D as soon as you said that before. It has had no effect. Could you take a quick look please; at the BIT file just in case there's still something wrong in there?
04 Mar 2012 15:08 #18343 by PCW
did you check the enables?
  • hatch789
  • Premium Member
  • Premium Member
04 Mar 2012 15:10 #18344 by hatch789
Yup, CNCBasher said they all look good from everything he can see.
04 Mar 2012 15:14 #18345 by PCW
Did you do this test:
To check the enables test for conductivity with an Ohmmeter between say ENA0+ (red lead) and ENA0- (black lead) These should show conductivity when LinuxCNC in ON
  • hatch789
  • Premium Member
  • Premium Member
04 Mar 2012 15:17 #18346 by hatch789
yes I have done that for both X & Y axis and it shows conductivity only in the one direction on both X & Y when I have the power on in AXIS.
Power off in AXIS and these drop to open circuit (no conductivity). But I'm not using the amps; and Friday you said these were for the amps. I'm using the Aout and ground and these are still producing 0v :(
04 Mar 2012 15:20 #18347 by PCW
what is the PWM value in hal? (depending on PID gain PWM scale and resolver these coul be very small)
  • hatch789
  • Premium Member
  • Premium Member
04 Mar 2012 16:36 #18351 by hatch789
if I had the right "PIN" that I was looking at, it was right next to the enable pins. The values were zero for both X & Y
Unless I'm not understanding your question?
04 Mar 2012 16:54 #18352 by PCW
What I was asking is in _HAL_ what is the PWM value?
Moderators: PCWjmelson
Time to create page: 0.081 seconds
