Understanding hardware stepgens
- btvpimill
- Thank you received: 3
25 May 2012 00:14 #20353
by btvpimill
Understanding hardware stepgens was created by btvpimill
I am sure this will be an easy question for you guys.
I get the power of generating steps from hardware instead of letting LinuxCNC do it, Thats not the issue for me. I am confused about how this works on a hardware level.
How does LinuxCNC tell the hardware what to generate, or how does the hardware know?
How does HAL know if the position is reached? When we use the stepgen, "feedback" is given to stepgen (I think) to let it think the loop is closed. So how does the loop close with hardware generators?
I have been pondering over this ever since I read about it, and since I have yet to come across the answer, I guess its time to ask.
- Thank you received: 5255
25 May 2012 00:37 - 25 May 2012 00:41 #20354
Replied by PCW on topic Re:Understanding hardware stepgens
The hardware stepgens work very much like LinuxCNCs software stepgen. They are basically rate generators (digitally controlled clocks or oscillators) with position feedback (a step counter) fed back to linuxCNC. The position feedback allows linuxCNC to correct for small errors due to differences in linuxCNCs and hardware timebase and delays from direction reversals. Basically the whole system is like a velocity mode servo where LinuxCNC reads the current position (step count+fractional step count) and sets the step rate every servo cycle
Last edit: 25 May 2012 00:41 by PCW. Reason: clarify
- btvpimill
25 May 2012 00:47 #20355
by btvpimill
Replied by btvpimill on topic Re:Understanding hardware stepgens
So basically CNC says -x move this fast, Y move that fast. Then the step gen reports back in the next exchange how far they went. And so forth and so on.
I was thinking CNC gave a distance to move, then maybe checked if the move was completed.
Now would the base thread be the same rate as if software gen were used? Or do we get to slow down the base thread as a result of not needing to command each step?
25 May 2012 00:54 #20356
Yes basically, with the added detail that how fast its asked to move is the current TP velocity + feedback info calculated from the current stepgen position vs LinuxCNCs TP position
No base thread is needed (well effectively the base thread is now in hardware and many MHz)
- btvpimill
25 May 2012 00:57 #20357
by btvpimill
Oh no base thread sounds really cool. The updates are done at a servo thread time then? I could see where that would REALLY free up the PC cycles!
- btvpimill
25 May 2012 01:29 #20360
by btvpimill
Just dawned on me, I guess this is how the gecko's are able to change step size on the fly? Because LinuxCNC is not counting steps, so the distance traveled is whatever the gecko reports.
I think I have learned my quota of trivial information for the day
Thank you Peter
Thank you Peter
25 May 2012 13:50 #20390
Geckos dont really change step size on the fly (its always takes 10 pulses to make a full step)
what Geckos do is "morph" between micro stepping and full stepping (with a divide by 10 prescale) by gradually changing the step motor current setpoints from sine/cosine to square waves over some speed range. This allows better torque at higher speeds where the current never reaches the setpoint peaks
- btvpimill
28 Jul 2013 06:30 #37111
by btvpimill
Replied by btvpimill on topic Understanding hardware stepgens
Back on this topic again. I am thinking about generating steps in my hardware. I think I fully understand from my side how to generate the steps. By this I mean setting up a 32 bit accumulator, and every time the 17th (or whatever) bit changes that is my step bit. then every timebase add or subtract some number up to 65535 to the accumulator. Ok, that is easy I think - now for the hard part (for me).
Exactly what is sent to my hardware? is it a number between 0 and 65535 (in this example) so really LinuxCNC is sending the "adder" if you will? if so how is this part set up in HAL file?
If not is someone willing to take my hand and lead me through this? Keep in mind I get tripped up on Jargon sometimes, I have no issue with concepts and implementing them, once I understand what I am being told.
- jmelson
- Thank you received: 159
28 Jul 2013 06:59 #37114
by jmelson
Not sure if Mesa hardware can do this, but the Pico Systems Universal Stepper Controller can be
set so any axis can count a real encoder instead of counting the steps going out. With our
Gecko Interface module, you can use Gecko 320 step-servo drives like real servos, such
as being able to E-stop and move the machine manually with LinuxCNC acting as a DRO,
then resume CNC operation without losing your position. You can do the same with steppers,
other than the drag of the motors always being present.
Otherwise, our boards do step generation and position counting pretty much the same way.
Jon
Replied by jmelson on topic Re:Understanding hardware stepgens
Jon
28 Jul 2013 07:09 - 28 Jul 2013 07:11 #37115
Hostmot2 has no built-in way to do this, but its easily done (and has been done on real machines) by setting up the axis like a servo axis and using a PID loop with encoder feedback and the PID output connected to the step generator running in velocity mode (the PID loop with only P and FF1=1)
Basically with the rate generator you have an almost perfect velocity mode servo (so only FF1 and a bit of P are needed)
Last edit: 28 Jul 2013 07:11 by PCW.
Time to create page: 0.075 seconds
