Understanding hardware stepgens
- btvpimill
- Thank you received: 3
30 Jul 2013 02:17 #37244
by btvpimill
Replied by btvpimill on topic Understanding hardware stepgens
I agree, Halscope has saved me on more than 1 occasion. But what will I expect to see if scoping say axis.N.cmd? I guess if I program a slow feed I will see the signal grow in amplitude as it "feeds" to the programmed destination? Since axis.N.cmd (I think) is the command for the next servo period, with the right feedrate it would look like a linear slope (assuming no accel/decel) to the destination.
- jmelson
- Thank you received: 159
02 Aug 2013 10:53 #37342
by jmelson
are VERY instructive in seeing how well the servo loop works. At least with our boards,
you can see the velocity and error even on an open-loop stepper system, so if there are
any anomalies in the movement, it will be quite visible.
Jon
Replied by jmelson on topic Understanding hardware stepgens
If you have an encoder in the system, then you can probably get velocity and PID error, whichI agree, Halscope has saved me on more than 1 occasion. But what will I expect to see if scoping say axis.N.cmd? I guess if I program a slow feed I will see the signal grow in amplitude as it "feeds" to the programmed destination? Since axis.N.cmd (I think) is the command for the next servo period, with the right feedrate it would look like a linear slope (assuming no accel/decel) to the destination.
Jon
Time to create page: 0.047 seconds
