HOW TO PICK A MOTION CONTROL BOARD
- Thank you received: 5291
06 Aug 2012 15:29 #22912
Replied by PCW on topic Re:HOW TO PICK A MOTION CONTROL BOARD
Looks like 2 enables, "controller release" and "pulse release"
These both have to be driven to +5 ..+30V relative to gnd to enable the drive
(there are 2 pulse release inputs but these are 'Ored" together so either will do)
- rwallace0921
07 Aug 2012 04:47 #22928
by rwallace0921
Replied by rwallace0921 on topic Re:HOW TO PICK A MOTION CONTROL BOARD
I see the pulse release and the controller release, but here is my problem. The connection for the pulse release in the manual has a letter designator of "IF" for the connection. There is no "IF" on the terminal block of the 3 TRM 2 board. There is a "JF", is that the same as the "IF" ? I'm guessing it's the same.
So here is what I'll try tomorrow after work, let me know if this sounds correct. I'll connect a +5V...+30V signal and touch the "RF" terminal on the board with it and another to the "JF" terminal. Theoretically that should enable the drive so I can move it with a +/- 10V signal. Only I'm not sure where on the drive terminal block to apply that +/- 10V signal that's suppose to run the motor. Maybe I can just put that voltage in the connector where it was plugged into the Anilam Controller, I have the pin-out information. That sound like it would work?
07 Aug 2012 05:16 - 07 Aug 2012 05:17 #22930
Looks like this to me:
1 JF
2 JF
3 RF
4 GND
5 TACH -
6 TACH +
7 GND
8 ANALOG IN -
9 ANALOG IN + (1)
10 ANALOG IN + (2)
Where JF and RF are the enables, and you would put your analog test voltage between analog - and analog+ (1) (with analog - tied to GND)
1 JF
2 JF
3 RF
4 GND
5 TACH -
6 TACH +
7 GND
8 ANALOG IN -
9 ANALOG IN + (1)
10 ANALOG IN + (2)
Last edit: 07 Aug 2012 05:17 by PCW. Reason: sp
- rwallace0921
09 Aug 2012 20:50 #23005
by rwallace0921
I couldn't write anything yesterday about trying to connect my servo drive, but I did try the connections you suggested, nothing seemed to work. Not sure if I did it correctly, so I need to know if what I tried is what you're thinking. I made a quick picture in PDF of what I tried so you can see it and tell me if I made the connections correctly.
Thanks for the help,
Richard
Richard
09 Aug 2012 23:55 #23009
OK that looks right, does the Gestart! LED light up? (and ready relay close the servo ready contacts?)
- rwallace0921
10 Aug 2012 00:15 #23010
by rwallace0921
No, I don't see any LED lighting up at all.
10 Aug 2012 00:29 - 10 Aug 2012 00:35 #23011
Do you have main power? Are the +-15V (on L6) OK?
watch out for the 220VAC on L6
Last edit: 10 Aug 2012 00:35 by PCW. Reason: safety
- rwallace0921
10 Aug 2012 00:46 #23012
by rwallace0921
I think I have main Power. I'm going to have to check into the +- 15V on L6. I'll get back to you on that one.
- rwallace0921
10 Aug 2012 02:01 #23014
by rwallace0921
I checked and I do have main power, if that is the 220VAC on L6 (terminal 1 & 3). Also there are no wires on the +-15V on L6 so it doesn't look like anything is connected.
10 Aug 2012 02:59 #23015
There may be nothing connected to L6 but the +-15V go to the main drive card so L6 is just a convenient place to measure them . The drive manual states that if these voltages are out of tolerance you will not get the Getstart LED or servo ready so they need to be checked
Time to create page: 0.071 seconds
