HOW TO PICK A MOTION CONTROL BOARD
13 Aug 2012 03:39 - 13 Aug 2012 03:41 #23080 by rwallace0921
Replied by rwallace0921 on topic Re:HOW TO PICK A MOTION CONTROL BOARD
I measured L6 +-15 V with respect to 0v and they looked good. I jumped the +15V to the RF & JF terminals. I only jumped it to one because all the RF & JF's are are piggy backed together. I didn't see the LED on or anything else. Nothing smoked so I went ahead and applied the +10 vold battery to Axis on on terminal 8 & 10 and also tried 8 and 9, but nothing seemed to happen. Any more ideas, or see something I might be doing wrong?
Also, do you know if there is some sort of jumper setting or something that I need to hit so the drive can be manually driven verses waiting for the controller?
Last edit: 13 Aug 2012 03:41 by rwallace0921.
13 Aug 2012 16:14 #23092 by PCW
Replied by PCW on topic Re:HOW TO PICK A MOTION CONTROL BOARD
Well the manual says the the Gestart or servo ready LED monitors the +-15 power
but the may be something else needed or possibly a problem in the drive.
One guess would be the synchronization pulse.
Is the drive wired for external or internal synchronization?
That is, is L5 connected to? (external sync) or are there solder jumpers connecting
points SY to SY1,SY2,SY3 on the control PCB (top middle of control board layout PDF page 19)
14 Aug 2012 00:23 #23134 by rwallace0921
I'm very thankful to have your help.
L5 is not connected to anything, nor does is have a jumper on it.
If I need to send it to someone to fix the drive, do you know of someone or a company who could do it?
14 Aug 2012 00:38 #23135 by PCW
If L5 is unconnected, the point SY should connect to SY1,SY2,SY3 on the control PCB
(top middle of control board layout PDF page 19) These are the jumpers I referred to
14 Aug 2012 00:49 - 14 Aug 2012 00:59 #23136 by rwallace0921
Yes, L5 is completely empty. I know where SY1, SY2, SY3 are, but not sure where you're finding "SY".
So as soon as I find SY, can I connect it to SY1 and then jump it to Sy2 and then Sy3? So this will cause internal synchronization?
Ok, I may have found SY. On page 19, I see SY on the upper middle of the board. There is also SY1, 2, & 3 below it. Is that the one you're talking about?
Last edit: 14 Aug 2012 00:59 by rwallace0921.
14 Aug 2012 00:58 #23138 by PCW
Yes. For internal sync these should all be jumpered together
14 Aug 2012 01:00 #23139 by rwallace0921
So I should probably use a jumper and not solder therm together right... maybe that's a stupid question...:)
14 Aug 2012 01:03 #23140 by PCW
I'm am not advising that you do any changes, just trying to determine the current drive setup
(and why it may not be working)
14 Aug 2012 01:10 #23142 by rwallace0921
Alright, I'll see if those are connected together. Got to run across town anyway so I'll check it out.
14 Aug 2012 02:17 #23145 by rwallace0921
Just confirmed it, SY, SY1, SY2, SY3 are all soldered together.
Moderators: PCWjmelson
