Yes, it's a delay before measurement and reply.I see, the tunable delayed reply is good!
In fact what is needed is a delayed "measurement-and-reply" not just reply, so the data used by the PID routine is as fresh as possible.
Things might get complicated managing different delays when several boards are connected, unless ring-virtual-topology is used as you suggested...
Regards,
Fernando
I actually started with the enc28j60 board that I had before progressing to the fastest ethernet enabled chip that Microchip had.Do you have any particular reason for the selection of PIC? I assume because it was the one on the demo kit?
I'm thinking of a servo interface instead of steppers, which requires more hardware (D/A, encoder tracking) but I like the approach you've taken.
Doug
Once the hardware and software are stable and tested. Everything is still in alpha-stage. I haven't hooked it up to a real machine yet; the only connection it had is to my scope.Can I buy a board?
