RT-8p8c - An ethernet based interface for LinuxCNC
14 years 1 month ago #24445 by bigalex
Amazing !!! :woohoo:
I was waiting for this kind of solution .
Also because it is a market trend to use ethernet connection to "remote" the hardware components of a CNC outside the PC mother board.
Do you know if it is possible to have on the same ethernet port the protocol/driver for an 7i80 and Modbus TCP/IP at the same time ?
bigalex :blink:
14 years 1 month ago #24460 by PCW
Well maybe....
The real time packets would have to wait occasionally for a time determined by the longest Modbus TCP/IP packets.
This might be acceptable if the Motherboard has a GigE port and the Modbus TCP/IP and
RT links do not share a 100BT " bottleneck"
But in general its probably best to dedicate a NIC to the RT link
14 years 1 month ago #24490 by bigalex
Thank you so much PCW.
I hope the firmware for the HostMot2 inside LinuxCNC will be available soon.
bigalex :blink:
14 years 1 month ago #24497 by fmederos
In fact RTnet implements measures to prevent "interferences" like realtime packets unpredictably waiting for non-realtime TCP traffic packets to go through.
Sure it would make no magic but RTnet should ensure that realtime packets get predictable access to the network when using it's media-access discipline.
I'm not sure of the benefits of this feature on a CNC machine, but it is there...
Regards,
Fernando
14 years 1 month ago #24498 by PCW
Yes, but that requires RTnet devices at all endpoints so it can tunnel TCPIP or other traffic through a TDM slice, if you have any regular random TCPIP traffic (like the Modbus TCPIP mentioned above) you will have to wait as it does not follow the TDM line access discipline
14 years 1 week ago #25786 by kinsa
Hello Guys,
Just an update, I have now connected it to my MF70 mill and the control of X, Y and Z axes seems to be working.
Full tests will take some time since my mill conversion is not yet finished.
There is still one issue that I'm still trying to solve, the code/module misses at least one reply packet within a 24 hr period.
Also, module_helper needs to be modified to handle loading of rtnet modules so that a normal user can run the linuxcnc command. Currently I'm using sudo to bypass this issue.
Regards,
GPO
Moderators: PCW, jmelson
Time to create page: 0.099 seconds
