RT-8p8c - An ethernet based interface for LinuxCNC
14 years 1 month ago #24319 by kinsa
jmelson wrote:
One thing that could help is to have the motion interface set
the timing of the sample, and the LinuxCNC thread could
be started on receipt of the message. That way, there'd
only be one message each way per servo cycle, and the
timing jitter could be very small.
There is a variable reply delay that can be configured to precisely match the hal thread's period so that a message is already in RTnet's buffer before the read thread starts.
The hal driver is currently using two threads, read and write. I'll try to merge the two next.
There are still some issues regarding unloading the module, RTnet doesn't close properly.
cncbasher wrote:
any pcb boards available ?
Assembled boards? No, not yet.
Initial development was done using a Chipkit Max32 with ethernet shield. The other alternative is the PIC32 ethernet starter kit.
14 years 1 month ago #24322 by bigalex
Hello gents.
To have CNC hardware modules connected via Ethernet card should be very interesting.
Also because of the future availability of the PCI Slots on the mother board card.
One option could be to implement a driver for one of the commercial deterministic protocol like Ethercat, Ethernet Powerlink ... .
Another option could be to have external hardware module like this www.ajaxcnc.com/mach3-cnc-control-systems/ .
bigalex :blink:
14 years 1 month ago #24338 by cncbasher
no i was just looking for the pcb on it's own , iv'e not looked at the chipkit Max32 as yet
14 years 1 month ago #24340 by kinsa
Email me your address and I'll send you one.
14 years 1 month ago #24397 by fmederos
So you are not enabling RTnet's TDMA discipline?
Seems not to be needed as the board does not talk unless asked, you may just daisy-chain several of these without collisions...
I wonder how would you manage the 100uSec ask-reply delay if you were to implement a closed-loop. You would ask on one iteration of the rt-thread and use the reply on the following itaration?
Regards,
Fernando
14 years 1 month ago #24399 by kinsa
I'm not using TDMA. There's just a single "user" in this case.
Or have the board serve as a gateway to other devices so that there will be no network contention.
Start the sequence with a TX then RX with the initial read value discarded. Then adjust the reply delay such that by the time the READ thread starts a reply is already waiting.
[WRITE THREAD] TX -> reply delay -> RX [READ THREAD] --> Process --> [WRITE THREAD] TX -> delay -> RX [READ THREAD] --> ...
Regards,
GP
Moderators: PCW, jmelson
Time to create page: 0.458 seconds
