thinking Mesa 5i25, but which daughter card(s)?
05 Feb 2013 23:09 #29648 by j_e_f_f_williams
thinking Mesa 5i25, but which daughter card(s)? was created by j_e_f_f_williams
Hello,
Converting a 3-axis mill (8x30 table mini-Bridgeport type) to CNC from manual. Have servo motors and working on adding USDigital encoders to them (single ended). To test the motors I have been using some controllers I have that work with them (basic H-bridge controllers) and an Ardrino to send PWM. The controllers take 2 PWM signals for forward & reverse. Not a PWM & direction.
Thinking of using Mesa 5i25 card in my computer control the system.
The question: which daughter card to support encoders with PWM up/down.
7i77 seems popular for servo config but it's a +/- 10V analog board vs PWM. I think I read people using 7i76 as PWM + direction (instead of Step + direction) but that too doesn't help with the dual PWM output and the 7i76 has no encoder inputs
Can I configure pins directly on the 5i25 to do what I want and just isolate the card with a 7i75 breakout board?
Another option I guess is I obtain some controllers that take PWM & direction, if there is a better card combination?
Thanks, Jeff
05 Feb 2013 23:25 #29649 by PCW
Probably a 7I85S would be the best 5I25 daughtercard for a PWM/encoder setup.
The 7I85S has 4 Step/Dir or PWM/DIr 5V differential output pairs and
4 TTL / Differential encoder inputs so can support 4 axis. It also has one RS-422 port
for I/O expansion
You can use a 7I75 as well but it will have 3.3V signal levels
Note that the HostMot2 PWM generator can do Up/Down mode as well as PWM/Dir
Up/Down mode is mode 2
man hostmot2
The following user(s) said Thank You: j_e_f_f_williams
06 Feb 2013 02:17 #29662 by j_e_f_f_williams
Replied by j_e_f_f_williams on topic thinking Mesa 5i25, but which daughter card(s)?
Thanks, I only noticed the RS-422 output options of the non-S version of the card so missed that option.
I also need:
- I/O ports for e-stop, limits etc
- 0-10V output to control spindle
- encoder inputs for manual job encoders for axis
So I believe I could use a 7i77 on the other 5i25 port to provide more encoder inputs and +/-10V outputs. 7i77 might be overkill for my needs but when I tried to get the required in/out from RS-422 cards it was more $ anyhow.
If anyone sees an error in my thinking please let me know
Thanks, Jeff
06 Feb 2013 02:58 #29667 by PCW
I would use a 5I25/7I85S/7I84. This would give you 4 encoder inputs
(plus 2 more MPG inputs on the 7I84 if needed) 16 outputs and 32 inputs
you could add a PWM-voltage converter for the Spindle (SPINX1)
16 Feb 2013 22:31 #30191 by j_e_f_f_williams
Hello,
I have my cards. quick easy service!
Is it correct that my only option is to roll my own HAL config for the 5i25 + 7i85S combo?
PncConf isn't an option as I can't seem to find the XML and PIN files that have a firmware setting which include 7i85S. Interestingly I found if I included the 5i25 directory but no XML/PIN files in it I could continue PncConfig a certain amount and everything looked correct BUT I couldn't save the config as I got PncConfig confused.
I was thinking one of the reasons to use Mesa boards was the easier start-up config as you could use PncConf but I guess that is only for certain combinations.
Thanks, Jeff
16 Feb 2013 23:40 - 16 Feb 2013 23:43 #30192 by shayloco
Hello,
I'm in the same position: 5i25 + 7i85S + 7i78 cards.
Hope someone has an XML file for the 7i85S otherwise will be slogging it out with the config files.
-Larry
Last edit: 16 Feb 2013 23:43 by shayloco. Reason: typo, should have been 7178 not 7176
17 Feb 2013 00:53 #30195 by shayloco
I just wrote an XML file for the 7i85S_7i78 and pncconf appears to recognize it.
I'll do a little testing and then post it and a 7i85S XML file.
-Larry
17 Feb 2013 18:31 #30214 by shayloco
I posted the 7i85S.xml file over in the Pncconf section of the forum.
www.linuxcnc.org/index.php/italian/forum...183-mesa-5i25--7i85s
-Larry
01 May 2013 05:10 - 01 May 2013 05:12 #33468 by bogie6040
Replied by bogie6040 on topic thinking Mesa 5i25, but which daughter card(s)?
Hope this is the right place to post this....
I have a setup at work I'm trying to get going - it is 3 BLDC servos driven from some dedicated hardware for them, using a Vishay Si9979 controllers.
I purchased the 5i25 / 7i85S / 7i84 combo that PCW recommended earlier.... The only XML file posted for the 7i85S does not seem to work for me as I need PWM and DIR outputs. I planned on using the 7i84 for servo enable, limit switches and machine control (E-stop, etc.)
Is there a file somewhere for this set up or can someone point me to the information to write an XML file??
Last edit: 01 May 2013 05:12 by bogie6040.
01 May 2013 06:02 #33469 by PCW
in www.mesanet.com/software/parallel/5i25.zip
/configs/hostmot2/7i85spx2.xml should be close
Moderators: PCWjmelson
Time to create page: 0.096 seconds
