Which board to buy?
- ScottBouch
This is my first post, so nice to meet you!
I'm converting an old Drummond Round Bed lathe (100 years old) to CNC. I'm adding a vertical slide for milling, and possibly a rotary 4th axis in the future.
I'm trying to research the right bits to buy, for the lowest budget possible.
I'm looking for possibly 4 axis plus spindle speed control. My spindle motor is 24Vdc. I can easily set up spindle speed feedback for PID control.
Not sure on which stepper motors to go for, or drive board. I'm planning on 2:1 or 3:1 toothed belt driving the axes, so as to put less torque load on the stepper motors, and possibly get away with smaller / cheaper motors and drives.
Intended use is metal turning and milling, aluminium and mild steel.
Any guidance is very much appreciated,
Thanks, Scott
- emcPT
- Thank you received: 95
If you want a better solution, more expandable, there are several members (including me) that are using hardware from mesa. In this forum there are good support for both situations.
- ScottBouch
Thanks for your reply...
As I'm still learning, I've just googled Mesa boards and found PCI cards. Do you use these to give you an extra parallel port?
What drive circuitry do you use between the parallel port and motors?
Is there sone information somewhere on different ways to build the system?
Cheers, Scott
Thanks, Scott
- emcPT
Hi emcPT,
Me too. I am doing a retrofit in a lathe also, and I am in the start.
If you choose the mesa, then you will not have the need use the parallel port. The mesa hardware have a lot of solutions (you can plug several mesa cards on the base card) as I am also finding out. I bought the hardware from mesa, and until know I think it is good for what I am doing. I bought a 5i20 (base card) a 7i33TA and a 7i37TA and I think I made a correct choose, but please note that I am using servo drives.
I bought the 5i20 as it is probably the board that is more used = more information and more help if I need, around here (or was because I bought it 1 year ago).
- Rick G
- Thank you received: 114
www.linuxcnc.org/docs/EMC2_User_Manual.pdf
Rick G
- BigJohnT
- Thank you received: 994
Unless this is a desktop lathe steppers may not have enough power... converting manual machines usually requires changing the lead screws for ball screws.
For a basic stepper machine using Mesa hardware you need a 5i25 7i76 combo with the cable. In addition to stepper motors you need stepper drives like Gecko 203 or 251 one for each motor, a power supply for the drives 48vdc or more depending on the drive, a 24vdc power supply for the 7i76 field IO.
- Thank you received: 4648
In some ways this might seem like a heretical thing to do, but actually the Drummond might be quite a good candidate.I'm converting an old Drummond Round Bed lathe (100 years old) to CNC. I'm adding a vertical slide for milling, and possibly a rotary 4th axis in the future.
www.lathes.co.uk/drummondroundbed/
The leadscrew is completely hidden inside the bed, so is well protected, and mounting a motor on either end of the bed to drive it could be done quite neatly.
The cross slide (and proposed vertical slide) might be more difficult to motorise, they generally are.
My lathe conversion uses NEMA23 sized steppers, and they are just about big enough (turning is fine, but toolpost-drilling with anything bigger than 10mm doesn't work).
You will probably need to convert to ballscrews, which is probably easy enough for Z, but finding space for an X ballnut might take ingenuity.
www.zappautomation.co.uk/ have ballscrews at a decent price.
- ScottBouch
Thanks for the feedback so far! My Drummond RB has a 4" swing and 12" between centres.
I'm only planning on using the original leadscrew, I have another cross slide from a bigger lathe, and vertical slide from some sort of instrument.
Budget is my biggest constraint, i was considering the cheap Chinese boards on ebay. Do they work with LinuxCNC via my PC's parallel port?
I may have to stick to just 3 axis to save cost.
I'd really like to dp spindle speed control too, but I could bodge this externaly.
Cheers, scott
- ScottBouch
www.ebay.co.uk/itm/261169442869?ssPageNa...id=p3984.m1438.l2649
It is a kit including 3 motors, but these are only NEMA17's. I do plan to use a toothed belt on each motor with a 2:1 or 3:1 ratio, to help with tourque, as speed isn't of great concern. They may be too weak though..
Has anyone got experience of these boards with Linux emc2?
The board in the link also does PWM spindle speed control, and takes a PWM input back from the spindle, I assume it uses a PID loop, but not sure how you'd configure the PID settings.
The boards suggested here do seem like a really good way to do it, but the cost (as reasonable as it is) may be prohibitive to the project.
I know you get what you pay for, and I also hate to spend good money after bad, but I'm really limited on this...
Cheers, Scott
It has a kepad and screen that are probably no use to you.It is a kit including 3 motors, but these are only NEMA17's.
www.ebay.co.uk/itm/380589096106
Is cheaper and has bigger motors.
Yes. I started with one of those boards. I blew it up one time too many and upgraded to some better drives. But I learned a lot in the process.Has anyone got experience of these boards with Linux emc2?
One thing I learned (eventually) is to never, ever, disconnect the motors from a TB6560 when they are powered up. In fact don't even look directly at the motor terminals, just to be sure.
PID inside LinuxCNC/HAL is generally better. You can watch what it is doing.The board in the link also does PWM spindle speed control, and takes a PWM input back from the spindle, I assume it uses a PID loop, but not sure how you'd configure the PID settings.
