Designing my own TB6560 AHQ driver boards...
16 Mar 2013 16:57 - 03 Apr 2013 21:30 #31494 by ScottBouch
After some great discussion over which board to buy, my conclusion has been to make my own driver boards.
Keeping cost as low as possible is my main aim, so I will reuse and recycle wherever possible.
Planning on one board per stepper motor (ease of repair) but sharing a common heatsink and power supply. I'll also be designing a spindle speed controller too. The whole assembly will fit inside my computer case for neatness, steppers, spindle drive, and power will connect at the rear of the PC.
I've bought 4x TB6560AHQ IC's off Ebay for just less than £10.00.
I have in my shed a nice selection of electronic components, and some bare PCB, which will save some more cost.
I'm designing the PCB using EAGLE PCB software, again made freely available by the nice Linux community.
A friend has a desktop CNC mill, and is willing to machine the boards for me, for a pint of beer!
Cheers, Scott
Last edit: 03 Apr 2013 21:30 by ScottBouch.
16 Mar 2013 17:01 #31495 by ScottBouch
Replied by ScottBouch on topic Designing my own TB6560 AHQ driver boards...
First Question:
Opto Isolators / Opto Couplers.
All optos have some time lag with switching on and off, some are faster than others.
I'm trying to select the best ones for the job of sitting between my drive boards and the Parallel Port.
Has anyone had any success / failure stories on which to use, or which speeds to aim for?
Cheers, Scott
16 Mar 2013 21:55 #31500 by jmelson
Replied by jmelson on topic Designing my own TB6560 AHQ driver boards...
First Question:
Cheers, Scott
I have used these:
HCPL-0201-500E fast, 20 V, SMT 516-1704-5
HCPL-063L-500E fast, 3.3V SMT
These are all surface mount, but there probably are DIP versions available. They are
both buffered, so they have a sense amp in them which improves speed.
Jon
The following user(s) said Thank You: ScottBouch
16 Mar 2013 23:25 #31501 by ScottBouch
Hi Jon,
Thanks for the useful insight, I'll look into them!
I imagine the buffer gives a sharper transient..
Thank you again, Scott
17 Mar 2013 01:10 #31502 by ScottBouch
Hi Jon,
I've just looked up the datasheets for those IC's, and they look perfect for the job! Thank you for the heads up!
Cheers, Scott
17 Mar 2013 04:37 #31506 by jmelson
Hi Jon,
Yes, it is also supposed to reduce pulse width distortion and allow the
LED to be operated at lower current. I normally run my LEDs at
about 5-6 mA and get rapid on/off of the output. I've been using
a variety of devices from the same product line for over 5 years
in my PWM servo amps with good results. I went from a 12V
logic supply and CD4000 chips to 5 V finally down to 3.3 V
in the latest model.
Oh, that reminds me, you need a good decoupling cap on the
logic supply for these or the output can glitch. That can cause
feedback, where the switching of the power transistors gets
back into the output of the optos and causes misbehavior
of the drive.
Jon
17 Mar 2013 22:14 #31513 by ScottBouch
I note the datasheet shows yhe supply rails on the PCB being identical to each other, but one on the top, and one on the bottom, is this a rule you've followed?
This layout reminds me of balanced microphone circuits.
Cheers, Scott
19 Mar 2013 18:00 #31583 by ScottBouch
Can a PC's parallel port drive a 6mA output? Should I use an op-amp buffer or transistor to drive the opto's LED?
And likewise, I must also consider the capabilities of the feedback outputs from the TB6560AHQ.
Don't want to be causing any damage...
Cheers, Scott.
19 Mar 2013 19:46 #31591 by andypugh
Replied by andypugh on topic Designing my own TB6560 AHQ driver boards...
You can pretty much count on a parport to supply 3mA and sink 15mA.
it is generally better to have 5V to the top of the opto and drive the parport pin low to turn on the opto.
19 Mar 2013 19:56 #31593 by ScottBouch
Thank you,
I've been trying to get some specs from Dell on my parallel port's capabilities.
Avoiding additional components will help to keep lags down, since I'm looking at the fast opto's that Jon recommended.
Looking forward to using the Parallel port test program and experimenting!
Thanks, Scott.
Moderators: PCWjmelson
Time to create page: 0.257 seconds
