Mesa 5i20 + 7i37 + 7i52S + 7i33 possible ?
- hardware_crash
15 Jun 2013 01:04 #35644
by hardware_crash
Replied by hardware_crash on topic Mesa 5i20 + 7i37 + 7i52S + 7i33 possible ?
At the moment it shows up with this:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.2
Machine configuration directory is '/home/user/linuxcnc/configs/my_LinuxCNC_machine'
Machine configuration file is 'my_LinuxCNC_machine.ini'
INIFILE=/home/user/linuxcnc/configs/my_LinuxCNC_machine/my_LinuxCNC_machine.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Running HAL shutdown script
Killing task linuxcncsvr, PID=9055
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
my_LinuxCNC_machine.hal:10: parameter or pin 'hm2_5i20.0.pwmgen.pwm_frequency' not found
9055
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 5526.243308] I-pipe: Domain RTAI registered.
[ 5526.243318] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 5526.243321] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 5526.243327] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 5526.243330] PIPELINE layers:
[ 5526.243334] f9732e20 9ac15d93 RTAI 200
[ 5526.243337] c085cb20 0 Linux 100
[ 5526.271292] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 5526.271414] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 5526.271420] RTAI[sched]: hard timer type/freq = APIC/8332339(Hz); default timing: periodic; linear timed lists.
[ 5526.271424] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1733042000 hz.
[ 5526.271427] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 5526.271518] RTAI[usi]: enabled.
[ 5526.341570] RTAI[math]: loaded.
[ 5526.429871] hm2: loading Mesa HostMot2 driver version 0.15
[ 5526.433686] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 5526.433720] hm2_pci: discovered 5i20 at 0000:01:03.0
[ 5526.433782] hm2_5i20.0: firmware: requesting hm2/5i20/svsta_6_7i52s.bit
[ 5526.578002] hm2/hm2_5i20.0: Smart Serial Firmware Version 42
[ 5526.585059] hm2/hm2_5i20.0: 72 I/O Pins used:
[ 5526.585064] hm2/hm2_5i20.0: IO Pin 000 (P2-01): IOPort
[ 5526.585067] hm2/hm2_5i20.0: IO Pin 001 (P2-03): IOPort
[ 5526.585070] hm2/hm2_5i20.0: IO Pin 002 (P2-05): IOPort
[ 5526.585073] hm2/hm2_5i20.0: IO Pin 003 (P2-07): IOPort
[ 5526.585076] hm2/hm2_5i20.0: IO Pin 004 (P2-09): IOPort
[ 5526.585079] hm2/hm2_5i20.0: IO Pin 005 (P2-11): IOPort
[ 5526.585082] hm2/hm2_5i20.0: IO Pin 006 (P2-13): IOPort
[ 5526.585087] hm2/hm2_5i20.0: IO Pin 007 (P2-15): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 5526.585091] hm2/hm2_5i20.0: IO Pin 008 (P2-17): Muxed Encoder #0, pin Muxed A (Input)
[ 5526.585095] hm2/hm2_5i20.0: IO Pin 009 (P2-19): Muxed Encoder #0, pin Muxed B (Input)
[ 5526.585100] hm2/hm2_5i20.0: IO Pin 010 (P2-21): Muxed Encoder #0, pin Muxed Index (Input)
[ 5526.585104] hm2/hm2_5i20.0: IO Pin 011 (P2-23): Muxed Encoder #1, pin Muxed A (Input)
[ 5526.585108] hm2/hm2_5i20.0: IO Pin 012 (P2-25): Muxed Encoder #1, pin Muxed B (Input)
[ 5526.585112] hm2/hm2_5i20.0: IO Pin 013 (P2-27): Muxed Encoder #1, pin Muxed Index (Input)
[ 5526.585116] hm2/hm2_5i20.0: IO Pin 014 (P2-29): Muxed Encoder #2, pin Muxed A (Input)
[ 5526.585120] hm2/hm2_5i20.0: IO Pin 015 (P2-31): Muxed Encoder #2, pin Muxed B (Input)
[ 5526.585125] hm2/hm2_5i20.0: IO Pin 016 (P2-33): Muxed Encoder #2, pin Muxed Index (Input)
[ 5526.585128] hm2/hm2_5i20.0: IO Pin 017 (P2-35): IOPort
[ 5526.585131] hm2/hm2_5i20.0: IO Pin 018 (P2-37): IOPort
[ 5526.585134] hm2/hm2_5i20.0: IO Pin 019 (P2-39): IOPort
[ 5526.585137] hm2/hm2_5i20.0: IO Pin 020 (P2-41): IOPort
[ 5526.585140] hm2/hm2_5i20.0: IO Pin 021 (P2-43): IOPort
[ 5526.585143] hm2/hm2_5i20.0: IO Pin 022 (P2-45): IOPort
[ 5526.585146] hm2/hm2_5i20.0: IO Pin 023 (P2-47): IOPort
[ 5526.585149] hm2/hm2_5i20.0: IO Pin 024 (P3-01): IOPort
[ 5526.585153] hm2/hm2_5i20.0: IO Pin 025 (P3-03): IOPort
[ 5526.585156] hm2/hm2_5i20.0: IO Pin 026 (P3-05): IOPort
[ 5526.585159] hm2/hm2_5i20.0: IO Pin 027 (P3-07): IOPort
[ 5526.585162] hm2/hm2_5i20.0: IO Pin 028 (P3-09): IOPort
[ 5526.585165] hm2/hm2_5i20.0: IO Pin 029 (P3-11): IOPort
[ 5526.585168] hm2/hm2_5i20.0: IO Pin 030 (P3-13): IOPort
[ 5526.585171] hm2/hm2_5i20.0: IO Pin 031 (P3-15): IOPort
[ 5526.585174] hm2/hm2_5i20.0: IO Pin 032 (P3-17): IOPort
[ 5526.585177] hm2/hm2_5i20.0: IO Pin 033 (P3-19): IOPort
[ 5526.585180] hm2/hm2_5i20.0: IO Pin 034 (P3-21): IOPort
[ 5526.585183] hm2/hm2_5i20.0: IO Pin 035 (P3-23): IOPort
[ 5526.585186] hm2/hm2_5i20.0: IO Pin 036 (P3-25): IOPort
[ 5526.585189] hm2/hm2_5i20.0: IO Pin 037 (P3-27): IOPort
[ 5526.585192] hm2/hm2_5i20.0: IO Pin 038 (P3-29): IOPort
[ 5526.585195] hm2/hm2_5i20.0: IO Pin 039 (P3-31): IOPort
[ 5526.585198] hm2/hm2_5i20.0: IO Pin 040 (P3-33): IOPort
[ 5526.585201] hm2/hm2_5i20.0: IO Pin 041 (P3-35): IOPort
[ 5526.585204] hm2/hm2_5i20.0: IO Pin 042 (P3-37): IOPort
[ 5526.585207] hm2/hm2_5i20.0: IO Pin 043 (P3-39): IOPort
[ 5526.585210] hm2/hm2_5i20.0: IO Pin 044 (P3-41): IOPort
[ 5526.585213] hm2/hm2_5i20.0: IO Pin 045 (P3-43): IOPort
[ 5526.585216] hm2/hm2_5i20.0: IO Pin 046 (P3-45): IOPort
[ 5526.585219] hm2/hm2_5i20.0: IO Pin 047 (P3-47): IOPort
[ 5526.585222] hm2/hm2_5i20.0: IO Pin 048 (P4-01): IOPort
[ 5526.585225] hm2/hm2_5i20.0: IO Pin 049 (P4-03): IOPort
[ 5526.585228] hm2/hm2_5i20.0: IO Pin 050 (P4-05): IOPort
[ 5526.585231] hm2/hm2_5i20.0: IO Pin 051 (P4-07): IOPort
[ 5526.585234] hm2/hm2_5i20.0: IO Pin 052 (P4-09): IOPort
[ 5526.585237] hm2/hm2_5i20.0: IO Pin 053 (P4-11): IOPort
[ 5526.585240] hm2/hm2_5i20.0: IO Pin 054 (P4-13): IOPort
[ 5526.585243] hm2/hm2_5i20.0: IO Pin 055 (P4-15): IOPort
[ 5526.585246] hm2/hm2_5i20.0: IO Pin 056 (P4-17): IOPort
[ 5526.585249] hm2/hm2_5i20.0: IO Pin 057 (P4-19): IOPort
[ 5526.585252] hm2/hm2_5i20.0: IO Pin 058 (P4-21): IOPort
[ 5526.585255] hm2/hm2_5i20.0: IO Pin 059 (P4-23): IOPort
[ 5526.585258] hm2/hm2_5i20.0: IO Pin 060 (P4-25): IOPort
[ 5526.585261] hm2/hm2_5i20.0: IO Pin 061 (P4-27): IOPort
[ 5526.585264] hm2/hm2_5i20.0: IO Pin 062 (P4-29): IOPort
[ 5526.585268] hm2/hm2_5i20.0: IO Pin 063 (P4-31): IOPort
[ 5526.585271] hm2/hm2_5i20.0: IO Pin 064 (P4-33): IOPort
[ 5526.585275] hm2/hm2_5i20.0: IO Pin 065 (P4-35): IOPort
[ 5526.585278] hm2/hm2_5i20.0: IO Pin 066 (P4-37): IOPort
[ 5526.585281] hm2/hm2_5i20.0: IO Pin 067 (P4-39): IOPort
[ 5526.585284] hm2/hm2_5i20.0: IO Pin 068 (P4-41): IOPort
[ 5526.585287] hm2/hm2_5i20.0: IO Pin 069 (P4-43): IOPort
[ 5526.585290] hm2/hm2_5i20.0: IO Pin 070 (P4-45): IOPort
[ 5526.585293] hm2/hm2_5i20.0: IO Pin 071 (P4-47): IOPort
[ 5526.585402] hm2/hm2_5i20.0: registered
[ 5526.585406] hm2_5i20.0: initialized AnyIO board at 0000:01:03.0
[ 5526.879928] hm2_5i20.0: dropping AnyIO board at 0000:01:03.0
[ 5526.879935] hm2/hm2_5i20.0: unregistered
[ 5526.881159] hm2_pci: driver unloaded
[ 5526.884511] hm2: unloading
[ 5526.925172] RTAI[math]: unloaded.
[ 5526.971932] SCHED releases registered named ALIEN RTGLBH
[ 5526.984270] RTAI[malloc]: unloaded.
[ 5527.084016] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 5527.086734] I-pipe: Domain RTAI unregistered.
[ 5527.086744] RTAI[hal]: unmounted.
- Thank you received: 5157
15 Jun 2013 01:06 #35645
Replied by PCW on topic Mesa 5i20 + 7i37 + 7i52S + 7i33 possible ?
Actually It does not matter too much what the error is,
since its not the correct bit file...
- hardware_crash
15 Jun 2013 01:11 #35647
by hardware_crash
OK
15 Jun 2013 03:30 #35649
if you re-fetch the zip file, its been updated
here's the md5 checksum of the bit file:
MD5 (svsta_6_7i52s.bit) = 9ed2b9a83156bf2804745cab23148486
Time to create page: 0.065 seconds
