Mesa 4i65 does not response
- hardware_crash
29 Dec 2013 02:53 #42127
by hardware_crash
Mesa 4i65 does not response was created by hardware_crash
Hey guys,
I have installed a 5i71 with Extern PCIE cable connected to the Mesa 4i73 with Mesa 4i65 on it.
When i load the the SVST8 firmware in linuxcnc i get an error message:
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/linuxcnc/hm2_pci.ko' : -1 Input/output error
The leds CR1 and CR3 on the 4i65 are lighting up red.
Maybe somebody knows this problem ?
Do I have the wrong firmware ?
Sincerely yours
Lukas
Sincerely yours
Lukas
- Thank you received: 5221
29 Dec 2013 03:15 #42129
Replied by PCW on topic Mesa 4i65 does not response
Is the 4I73s Link OK light illuminated? (CR6)
can you do a:
lspci > pci.txt
and post pci.txt here
can you do a:
lspci > pci.txt
- hardware_crash
28 Apr 2014 03:18 #46384
by hardware_crash
Replied by hardware_crash on topic Mesa 4i65 does not response
So I had some time to check a few things.
The Output of lspci is:
I tried the 4i65 with another pc and an 6i71 insted of the 5i71 and it worked properly .
So I think theres anything with the 5i71 ..
I also tried with the new ubuntu 12.04 precise and also with the 2.6pre but that doesnt change anything on the error.
the link to the 4i65 is ok.
The Error output is as following:
00:00.0 Host bridge: Intel Corporation Atom Processor D4xx/D5xx/N4xx/N5xx DMI Bridge (rev 02)
00:02.0 VGA compatible controller: Intel Corporation Atom Processor D4xx/D5xx/N4xx/N5xx Integrated Graphics Controller (rev 02)
00:1b.0 Audio device: Intel Corporation NM10/ICH7 Family High Definition Audio Controller (rev 01)
00:1c.0 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 1 (rev 01)
00:1c.1 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 2 (rev 01)
00:1c.2 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 3 (rev 01)
00:1c.3 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 4 (rev 01)
00:1d.0 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #1 (rev 01)
00:1d.1 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #2 (rev 01)
00:1d.2 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #3 (rev 01)
00:1d.3 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #4 (rev 01)
00:1d.7 USB controller: Intel Corporation NM10/ICH7 Family USB2 EHCI Controller (rev 01)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e1)
00:1f.0 ISA bridge: Intel Corporation NM10 Family LPC Controller (rev 01)
00:1f.2 IDE interface: Intel Corporation NM10/ICH7 Family SATA Controller [IDE mode] (rev 01)
00:1f.3 SMBus: Intel Corporation NM10/ICH7 Family SMBus Controller (rev 01)
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 06)
05:00.0 PCI bridge: PLX Technology, Inc. PEX8112 x1 Lane PCI Express-to-PCI Bridge (rev aa)
06:00.0 PCI bridge: PLX Technology, Inc. PEX8112 x1 Lane PCI Express-to-PCI Bridge (rev aa)
07:00.0 Bridge: PLX Technology, Inc. PCI9030 32-bit 33MHz PCI <-> IOBus Bridge
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4.55-rtai-2/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.6.0-pre1-27-g2374e3e
Machine configuration directory is '/home/cncuser/linuxcnc/configs/by_interface.mesa.hm2-stepper'
Machine configuration file is '4i65.ini'
INIFILE=/home/cncuser/linuxcnc/configs/by_interface.mesa.hm2-stepper/4i65.ini
PARAMETER_FILE=hm2-stepper.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Killing task linuxcncsvr, PID=3175
Debug file information:
insmod: error inserting '/usr/realtime-3.4.55-rtai-2/modules/linuxcnc/hm2_pci.ko': -1 Input/output error
hm2-stepper.hal:41: exit value: 1
hm2-stepper.hal:41: insmod failed, returned -1
See the output of 'dmesg' for more information.
3175
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
Linux version 3.4.55-rtai-2 (root@precise-x86) (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #1 SMP PREEMPT Sun Dec 15 23:40:48 MST 2013
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000008f000 (usable)
BIOS-e820: 000000000008f000 - 0000000000090000 (reserved)
BIOS-e820: 0000000000090000 - 000000000009ec00 (usable)
BIOS-e820: 000000000009ec00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000007ee97000 (usable)
BIOS-e820: 000000007ee97000 - 000000007eebf000 (reserved)
BIOS-e820: 000000007eebf000 - 000000007ef47000 (usable)
BIOS-e820: 000000007ef47000 - 000000007efbf000 (ACPI NVS)
BIOS-e820: 000000007efbf000 - 000000007eff1000 (usable)
BIOS-e820: 000000007eff1000 - 000000007efff000 (ACPI data)
BIOS-e820: 000000007efff000 - 000000007f000000 (usable)
BIOS-e820: 000000007f000000 - 0000000080000000 (reserved)
BIOS-e820: 00000000f8000000 - 00000000fc000000 (reserved)
BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved)
Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
SMBIOS 2.5 present.
DMI: /D525MW, BIOS MWPNT10N.86A.0126.2012.0517.1400 05/17/2012
e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
last_pfn = 0x7f000 max_arch_pfn = 0x100000
MTRR default type: uncachable
MTRR fixed ranges enabled:
00000-9FFFF write-back
A0000-BFFFF uncachable
C0000-DFFFF write-protect
E0000-FFFFF uncachable
MTRR variable ranges enabled:
0 base 000000000 mask F80000000 write-back
1 base 07F000000 mask FFF000000 uncachable
2 base 0FFFF0000 mask FFFFF0000 write-protect
3 base 0FFF10000 mask FFFFF0000 write-protect
4 base 0FFF20000 mask FFFFF0000 write-protect
5 disabled
6 disabled
x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
found SMP MP-table at [c00fbe70] fbe70
initial memory mapped : 0 - 01c00000
Base memory trampoline at [c009d000] 9d000 size 4096
init_memory_mapping: 0000000000000000-00000000377fe000
0000000000 - 0000400000 page 4k
0000400000 - 0037400000 page 2M
0037400000 - 00377fe000 page 4k
kernel direct mapping tables up to 0x377fdfff @ [mem 0x01bf8000-0x01bfffff]
RAMDISK: 36684000 - 3733a000
ACPI: RSDP 000f2380 00024 (v02 INTEL )
ACPI: XSDT 7effe120 0004C (v01 INTEL D525MW 0000007E 01000013)
ACPI: FACP 7effd000 000F4 (v03 INTEL D525MW 0000007E MSFT 0100000D)
ACPI: DSDT 7eff9000 03796 (v01 INTEL D525MW 0000007E MSFT 0100000D)
ACPI: FACS 7ef87000 00040
ACPI: APIC 7eff8000 00084 (v02 INTEL D525MW 0000007E MSFT 0100000D)
ACPI: MCFG 7eff7000 0003C (v01 INTEL D525MW 0000007E MSFT 0100000D)
ACPI: HPET 7eff6000 00038 (v01 INTEL D525MW 0000007E MSFT 0100000D)
ACPI: SSDT 7eff2000 0377C (v01 INTEL D525MW 0000007E MSFT 0100000D)
ACPI: Local APIC address 0xfee00000
1144MB HIGHMEM available.
887MB LOWMEM available.
mapped low ram: 0 - 377fe000
Zone PFN ranges:
DMA 0x00000010 -> 0x00001000
Normal 0x00001000 -> 0x000377fe
HighMem 0x000377fe -> 0x0007f000
Movable zone start PFN for each node
Early memory PFN ranges
0: 0x00000010 -> 0x0000008f
0: 0x00000090 -> 0x0000009e
0: 0x00000100 -> 0x0007ee97
0: 0x0007eebf -> 0x0007ef47
0: 0x0007efbf -> 0x0007eff1
0: 0x0007efff -> 0x0007f000
On node 0 totalpages: 519903
free_area_init_node: node 0, pgdat c160d9c0, node_mem_map f56a4200
DMA zone: 32 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 3949 pages, LIFO batch:0
Normal zone: 1744 pages used for memmap
Normal zone: 221486 pages, LIFO batch:31
HighMem zone: 2289 pages used for memmap
HighMem zone: 290403 pages, LIFO batch:31
Using APIC driver default
ACPI: PM-Timer IO Port: 0x408
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
ACPI: LAPIC (acpi_id[0x03] lapic_id[0x02] enabled)
ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled)
ACPI: LAPIC_NMI (acpi_id[0x01] high level lint[0x1])
ACPI: LAPIC_NMI (acpi_id[0x02] high level lint[0x1])
ACPI: LAPIC_NMI (acpi_id[0x03] high level lint[0x1])
ACPI: LAPIC_NMI (acpi_id[0x04] high level lint[0x1])
ACPI: IOAPIC (id[0x08] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
ACPI: IRQ9 used by override.
Using ACPI (MADT) for SMP configuration information
ACPI: HPET id: 0x8086a201 base: 0xfed00000
SMP: Allowing 4 CPUs, 0 hotplug CPUs
nr_irqs_gsi: 40
Allocating PCI resources starting at 80000000 (gap: 80000000:78000000)
setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
PERCPU: Embedded 17 pages/cpu @f77ad000 s47552 r0 d22080 u69632
pcpu-alloc: s47552 r0 d22080 u69632 alloc=17*4096
pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 515838
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4.55-rtai-2 root=UUID=947fa73e-fc06-49d1-945c-1c1ce37b8361 ro nomodeset vt.handoff=7
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Initializing CPU#0
Initializing HighMem for node 0 (000377fe:0007f000)
Memory: 2041820k/2080768k available (4612k kernel code, 37792k reserved, 1613k data, 544k init, 1170768k highmem)
virtual kernel memory layout:
fixmap : 0xfff18000 - 0xfffff000 ( 924 kB)
pkmap : 0xff800000 - 0xffc00000 (4096 kB)
vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
.init : 0xc1615000 - 0xc169d000 ( 544 kB)
.data : 0xc148113d - 0xc1614580 (1613 kB)
.text : 0xc1000000 - 0xc148113d (4612 kB)
Checking if this processor honours the WP bit even in supervisor mode...Ok.
SLUB: Genslabs=15, HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Preemptible hierarchical RCU implementation.
Dump stacks of tasks blocking RCU-preempt GP.
NR_IRQS:2304 nr_irqs:712 16
CPU 0 irqstacks, hard=f5008000 soft=f500a000
Extended CMOS year: 2000
Interrupt pipeline (release #3)
Console: colour dummy device 80x25
console [tty0] enabled
hpet clockevent registered
Fast TSC calibration using PIT
Detected 1800.184 MHz processor.
Calibrating delay loop (skipped), value calculated using timer frequency.. 3600.36 BogoMIPS (lpj=1800184)
pid_max: default: 32768 minimum: 301
Security Framework initialized
AppArmor: AppArmor initialized
Mount-cache hash table entries: 512
CPU: Physical Processor ID: 0
CPU: Processor Core ID: 0
mce: CPU supports 5 MCE banks
CPU0: Thermal monitoring enabled (TM1)
Freeing SMP alternatives: 20k freed
ACPI: Core revision 20120320
Enabling APIC mode: Flat. Using 1 I/O APICs
..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
CPU0: Intel(R) Atom(TM) CPU D525 @ 1.80GHz stepping 0a
Performance Events: PEBS fmt0+, 8-deep LBR, Atom events, Intel PMU driver.
... version: 3
... bit width: 40
... generic registers: 2
... value mask: 000000ffffffffff
... max period: 000000007fffffff
... fixed-purpose events: 3
... event mask: 0000000700000003
CPU 1 irqstacks, hard=f5070000 soft=f5072000
Booting Node 0, Processors #1
Initializing CPU#1
CPU 2 irqstacks, hard=f507c000 soft=f507e000
#2
Initializing CPU#2
CPU 3 irqstacks, hard=f508c000 soft=f508e000
#3 Ok.
Initializing CPU#3
Brought up 4 CPUs
Total of 4 processors activated (14401.47 BogoMIPS).
devtmpfs: initialized
EVM: security.selinux
EVM: security.SMACK64
EVM: security.capability
dummy:
NET: Registered protocol family 16
EISA bus registered
ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
ACPI: bus type pci registered
PCI: Using configuration type 1 for base access
bio: create slab <bio-0> at 0
ACPI: Added _OSI(Module Device)
ACPI: Added _OSI(Processor Device)
ACPI: Added _OSI(3.0 _SCP Extensions)
ACPI: Added _OSI(Processor Aggregator Device)
ACPI: EC: Look up EC in DSDT
[Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
ACPI: Interpreter enabled
ACPI: (supports S0 S5)
ACPI: Using IOAPIC for interrupt routing
PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3f])
pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7]
pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff]
pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff]
pci_root PNP0A03:00: host bridge window [mem 0xd0000000-0xf7ffffff]
PCI host bridge to bus 0000:00
pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
pci_bus 0000:00: root bus resource [mem 0xd0000000-0xf7ffffff]
pci 0000:00:00.0: [8086:a000] type 00 class 0x060000
pci 0000:00:02.0: [8086:a001] type 00 class 0x030000
pci 0000:00:02.0: reg 10: [mem 0xe0300000-0xe037ffff]
pci 0000:00:02.0: reg 14: [io 0x30c0-0x30c7]
pci 0000:00:02.0: reg 18: [mem 0xd0000000-0xdfffffff pref]
pci 0000:00:02.0: reg 1c: [mem 0xe0200000-0xe02fffff]
pci 0000:00:1b.0: [8086:27d8] type 00 class 0x040300
pci 0000:00:1b.0: reg 10: [mem 0xe0380000-0xe0383fff 64bit]
pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
pci 0000:00:1c.0: [8086:27d0] type 01 class 0x060400
pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
pci 0000:00:1c.1: [8086:27d2] type 01 class 0x060400
pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
pci 0000:00:1c.2: [8086:27d4] type 01 class 0x060400
pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
pci 0000:00:1c.3: [8086:27d6] type 01 class 0x060400
pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
pci 0000:00:1d.0: [8086:27c8] type 00 class 0x0c0300
pci 0000:00:1d.0: reg 20: [io 0x3080-0x309f]
pci 0000:00:1d.1: [8086:27c9] type 00 class 0x0c0300
pci 0000:00:1d.1: reg 20: [io 0x3060-0x307f]
pci 0000:00:1d.2: [8086:27ca] type 00 class 0x0c0300
pci 0000:00:1d.2: reg 20: [io 0x3040-0x305f]
pci 0000:00:1d.3: [8086:27cb] type 00 class 0x0c0300
pci 0000:00:1d.3: reg 20: [io 0x3020-0x303f]
pci 0000:00:1d.7: [8086:27cc] type 00 class 0x0c0320
pci 0000:00:1d.7: reg 10: [mem 0xe0384400-0xe03847ff]
pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
pci 0000:00:1e.0: [8086:2448] type 01 class 0x060401
pci 0000:00:1f.0: [8086:27bc] type 00 class 0x060100
pci 0000:00:1f.0: [Firmware Bug]: TigerPoint LPC.BM_STS cleared
pci 0000:00:1f.2: [8086:27c0] type 00 class 0x01018f
pci 0000:00:1f.2: reg 10: [io 0x30b8-0x30bf]
pci 0000:00:1f.2: reg 14: [io 0x30cc-0x30cf]
pci 0000:00:1f.2: reg 18: [io 0x30b0-0x30b7]
pci 0000:00:1f.2: reg 1c: [io 0x30c8-0x30cb]
pci 0000:00:1f.2: reg 20: [io 0x30a0-0x30af]
pci 0000:00:1f.2: reg 24: [mem 0xe0384000-0xe03843ff]
pci 0000:00:1f.2: PME# supported from D3hot
pci 0000:00:1f.3: [8086:27da] type 00 class 0x0c0500
pci 0000:00:1f.3: reg 20: [io 0x3000-0x301f]
pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
pci 0000:01:00.0: reg 10: [io 0x2000-0x20ff]
pci 0000:01:00.0: reg 18: [mem 0xe0004000-0xe0004fff 64bit pref]
pci 0000:01:00.0: reg 20: [mem 0xe0000000-0xe0003fff 64bit pref]
pci 0000:01:00.0: supports D1 D2
pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
pci 0000:00:1c.0: PCI bridge to [bus 01-01]
pci 0000:00:1c.0: bridge window [io 0x2000-0x2fff]
pci 0000:00:1c.0: bridge window [mem 0xe0000000-0xe00fffff 64bit pref]
pci 0000:00:1c.1: PCI bridge to [bus 02-02]
pci 0000:00:1c.2: PCI bridge to [bus 03-03]
pci 0000:00:1c.3: PCI bridge to [bus 04-04]
pci 0000:05:00.0: [10b5:8112] type 01 class 0x060400
pci 0000:05:00.0: supports D1
pci 0000:05:00.0: PME# supported from D0 D1 D3hot
pci 0000:00:1e.0: PCI bridge to [bus 05-07] (subtractive decode)
pci 0000:00:1e.0: bridge window [io 0x1000-0x1fff]
pci 0000:00:1e.0: bridge window [mem 0xe0100000-0xe01fffff]
pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
pci 0000:00:1e.0: bridge window [mem 0xd0000000-0xf7ffffff] (subtractive decode)
pci 0000:06:00.0: [10b5:8112] type 01 class 0x060400
pci 0000:06:00.0: supports D1
pci 0000:06:00.0: PME# supported from D0 D1 D3hot
pci 0000:05:00.0: PCI bridge to [bus 06-07]
pci 0000:05:00.0: bridge window [io 0x1000-0x1fff]
pci 0000:05:00.0: bridge window [mem 0xe0100000-0xe01fffff]
pci 0000:07:00.0: [10b5:9030] type 00 class 0x068000
pci 0000:07:00.0: reg 10: [mem 0xe0120000-0xe012007f]
pci 0000:07:00.0: reg 14: [io 0x1200-0x127f]
pci 0000:07:00.0: reg 18: [io 0x1100-0x11ff]
pci 0000:07:00.0: reg 1c: [io 0x1000-0x10ff]
pci 0000:07:00.0: reg 20: [mem 0xe0110000-0xe011ffff]
pci 0000:07:00.0: reg 24: [mem 0xe0100000-0xe010ffff]
pci 0000:06:00.0: PCI bridge to [bus 07-07]
pci 0000:06:00.0: bridge window [io 0x1000-0x1fff]
pci 0000:06:00.0: bridge window [mem 0xe0100000-0xe01fffff]
pci_bus 0000:00: on NUMA node 0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P32_._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX1._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX2._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX3._PRT]
pci0000:00: Unable to request _OSC control (_OSC support mask: 0x1e)
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 9 10 *11 12)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 *9 10 11 12)
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 9 10 *11 12)
ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 *9 10 11 12)
ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 9 *10 11 12)
vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
vgaarb: loaded
vgaarb: bridge control possible 0000:00:02.0
SCSI subsystem initialized
libata version 3.00 loaded.
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
PCI: Using ACPI for IRQ routing
PCI: pci_cache_line_size set to 64 bytes
reserve RAM buffer: 000000000008f000 - 000000000008ffff
reserve RAM buffer: 000000000009ec00 - 000000000009ffff
reserve RAM buffer: 000000007ee97000 - 000000007fffffff
reserve RAM buffer: 000000007ef47000 - 000000007fffffff
reserve RAM buffer: 000000007eff1000 - 000000007fffffff
reserve RAM buffer: 000000007f000000 - 000000007fffffff
NetLabel: Initializing
NetLabel: domain hash size = 128
NetLabel: protocols = UNLABELED CIPSOv4
NetLabel: unlabeled traffic allowed by default
HPET: 3 timers in total, 0 timers will be used for per-cpu timer
hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
hpet0: 3 comparators, 64-bit 14.318180 MHz counter
Switching to clocksource hpet
AppArmor: AppArmor Filesystem Enabled
pnp: PnP ACPI init
ACPI: bus type pnp registered
pnp 00:00: [bus 00-3f]
pnp 00:00: [io 0x0cf8-0x0cff]
pnp 00:00: [io 0x0000-0x0cf7 window]
pnp 00:00: [io 0x0d00-0xffff window]
pnp 00:00: [mem 0x000a0000-0x000bffff window]
pnp 00:00: [mem 0xd0000000-0xf7ffffff window]
pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active)
pnp 00:01: [mem 0xf8000000-0xfbffffff]
pnp 00:01: [mem 0xfed14000-0xfed17fff]
pnp 00:01: [mem 0xfed18000-0xfed18fff]
pnp 00:01: [mem 0xfed19000-0xfed19fff]
pnp 00:01: [mem 0xfed1c000-0xfed1ffff]
pnp 00:01: [mem 0x000c0000-0x000dffff]
pnp 00:01: [mem 0x000e0000-0x000fffff]
pnp 00:01: [mem 0xfff00000-0xffffffff]
system 00:01: [mem 0xf8000000-0xfbffffff] has been reserved
system 00:01: [mem 0xfed14000-0xfed17fff] has been reserved
system 00:01: [mem 0xfed18000-0xfed18fff] has been reserved
system 00:01: [mem 0xfed19000-0xfed19fff] has been reserved
system 00:01: [mem 0xfed1c000-0xfed1ffff] has been reserved
system 00:01: [mem 0x000c0000-0x000dffff] could not be reserved
system 00:01: [mem 0x000e0000-0x000fffff] could not be reserved
system 00:01: [mem 0xfff00000-0xffffffff] has been reserved
system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
pnp 00:02: [io 0x0000-0x000f]
pnp 00:02: [io 0x0081-0x0083]
pnp 00:02: [io 0x0087]
pnp 00:02: [io 0x0089-0x008b]
pnp 00:02: [io 0x008f]
pnp 00:02: [io 0x00c0-0x00df]
pnp 00:02: [dma 4]
pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
pnp 00:03: [io 0x0070-0x0071]
pnp 00:03: [io 0x0074-0x0077]
pnp 00:03: [irq 8]
pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
pnp 00:04: [io 0x00f0]
pnp 00:04: [irq 13]
pnp 00:04: Plug and Play ACPI device, IDs PNP0c04 (active)
pnp 00:05: [io 0x0061]
pnp 00:05: Plug and Play ACPI device, IDs PNP0800 (active)
pnp 00:06: [io 0x0500-0x053f]
pnp 00:06: [io 0x0400-0x047f]
pnp 00:06: [io 0x0092]
pnp 00:06: [io 0x0680-0x06ff]
pnp 00:06: [io 0x0010-0x001f]
pnp 00:06: [io 0x0072-0x0073]
pnp 00:06: [io 0x0080]
pnp 00:06: [io 0x0084-0x0086]
pnp 00:06: [io 0x0088]
pnp 00:06: [io 0x008c-0x008e]
pnp 00:06: [io 0x0090-0x009f]
pnp 00:06: [io 0x0295-0x0296]
system 00:06: [io 0x0500-0x053f] has been reserved
system 00:06: [io 0x0400-0x047f] has been reserved
system 00:06: [io 0x0680-0x06ff] has been reserved
system 00:06: [io 0x0295-0x0296] has been reserved
system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
pnp 00:07: [io 0x0060]
pnp 00:07: [io 0x0064]
system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
pnp 00:08: [io 0x0378-0x037f]
pnp 00:08: [irq 7]
pnp 00:08: Plug and Play ACPI device, IDs PNP0400 (active)
pnp 00:09: [io 0x03f8-0x03ff]
pnp 00:09: [irq 4]
pnp 00:09: Plug and Play ACPI device, IDs PNP0501 (active)
pnp 00:0a: [io 0x02f8-0x02ff]
pnp 00:0a: [irq 3]
pnp 00:0a: Plug and Play ACPI device, IDs PNP0501 (active)
pnp 00:0b: [mem 0xfec00000-0xfec000ff]
pnp 00:0b: Plug and Play ACPI device, IDs PNP0003 (active)
pnp 00:0c: [mem 0xfed00000-0xfed03fff]
pnp 00:0c: Plug and Play ACPI device, IDs PNP0103 (active)
pnp: PnP ACPI: found 13 devices
ACPI: ACPI bus type pnp unregistered
PnPBIOS: Disabled by ACPI PNP
pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 01-01] add_size 400000
pci 0000:00:1c.1: bridge window [io 0x1000-0x0fff] to [bus 02-02] add_size 1000
pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02-02] add_size 200000
pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff] to [bus 02-02] add_size 200000
pci 0000:00:1c.2: bridge window [io 0x1000-0x0fff] to [bus 03-03] add_size 1000
pci 0000:00:1c.2: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03-03] add_size 200000
pci 0000:00:1c.2: bridge window [mem 0x00100000-0x000fffff] to [bus 03-03] add_size 200000
pci 0000:00:1c.3: bridge window [io 0x1000-0x0fff] to [bus 04-04] add_size 1000
pci 0000:00:1c.3: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 04-04] add_size 200000
pci 0000:00:1c.3: bridge window [mem 0x00100000-0x000fffff] to [bus 04-04] add_size 200000
pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x000fffff] get_res_add_size add_size 400000
pci 0000:00:1c.1: res[14]=[mem 0x00100000-0x000fffff] get_res_add_size add_size 200000
pci 0000:00:1c.1: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
pci 0000:00:1c.2: res[14]=[mem 0x00100000-0x000fffff] get_res_add_size add_size 200000
pci 0000:00:1c.2: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
pci 0000:00:1c.3: res[14]=[mem 0x00100000-0x000fffff] get_res_add_size add_size 200000
pci 0000:00:1c.3: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
pci 0000:00:1c.1: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
pci 0000:00:1c.2: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
pci 0000:00:1c.3: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
pci 0000:00:1c.0: BAR 14: assigned [mem 0xe0400000-0xe07fffff]
pci 0000:00:1c.1: BAR 14: assigned [mem 0xe0800000-0xe09fffff]
pci 0000:00:1c.1: BAR 15: assigned [mem 0xe0a00000-0xe0bfffff 64bit pref]
pci 0000:00:1c.2: BAR 14: assigned [mem 0xe0c00000-0xe0dfffff]
pci 0000:00:1c.2: BAR 15: assigned [mem 0xe0e00000-0xe0ffffff 64bit pref]
pci 0000:00:1c.3: BAR 14: assigned [mem 0xe1000000-0xe11fffff]
pci 0000:00:1c.3: BAR 15: assigned [mem 0xe1200000-0xe13fffff 64bit pref]
pci 0000:00:1c.1: BAR 13: assigned [io 0x4000-0x4fff]
pci 0000:00:1c.2: BAR 13: assigned [io 0x5000-0x5fff]
pci 0000:00:1c.3: BAR 13: assigned [io 0x6000-0x6fff]
pci 0000:00:1c.0: bridge window [mem 0xe0400000-0xe07fffff]
pci 0000:00:1c.1: bridge window [io 0x4000-0x4fff]
pci 0000:00:1c.1: bridge window [mem 0xe0800000-0xe09fffff]
pci 0000:00:1c.1: bridge window [mem 0xe0a00000-0xe0bfffff 64bit pref]
pci 0000:00:1c.2: bridge window [io 0x5000-0x5fff]
pci 0000:00:1c.2: bridge window [mem 0xe0c00000-0xe0dfffff]
pci 0000:00:1c.2: bridge window [mem 0xe0e00000-0xe0ffffff 64bit pref]
pci 0000:00:1c.3: bridge window [io 0x6000-0x6fff]
pci 0000:00:1c.3: bridge window [mem 0xe1000000-0xe11fffff]
pci 0000:00:1c.3: bridge window [mem 0xe1200000-0xe13fffff 64bit pref]
pci 0000:00:1c.1: enabling device (0000 -> 0003)
pci 0000:00:1c.2: enabling device (0000 -> 0003)
pci 0000:00:1c.3: enabling device (0000 -> 0003)
pci 0000:00:1e.0: setting latency timer to 64
pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
pci_bus 0000:00: resource 7 [mem 0xd0000000-0xf7ffffff]
pci_bus 0000:01: resource 0 [io 0x2000-0x2fff]
pci_bus 0000:01: resource 1 [mem 0xe0400000-0xe07fffff]
pci_bus 0000:01: resource 2 [mem 0xe0000000-0xe00fffff 64bit pref]
pci_bus 0000:02: resource 0 [io 0x4000-0x4fff]
pci_bus 0000:02: resource 1 [mem 0xe0800000-0xe09fffff]
pci_bus 0000:02: resource 2 [mem 0xe0a00000-0xe0bfffff 64bit pref]
pci_bus 0000:03: resource 0 [io 0x5000-0x5fff]
pci_bus 0000:03: resource 1 [mem 0xe0c00000-0xe0dfffff]
pci_bus 0000:03: resource 2 [mem 0xe0e00000-0xe0ffffff 64bit pref]
pci_bus 0000:04: resource 0 [io 0x6000-0x6fff]
pci_bus 0000:04: resource 1 [mem 0xe1000000-0xe11fffff]
pci_bus 0000:04: resource 2 [mem 0xe1200000-0xe13fffff 64bit pref]
pci_bus 0000:05: resource 0 [io 0x1000-0x1fff]
pci_bus 0000:05: resource 1 [mem 0xe0100000-0xe01fffff]
pci_bus 0000:05: resource 4 [io 0x0000-0x0cf7]
pci_bus 0000:05: resource 5 [io 0x0d00-0xffff]
pci_bus 0000:05: resource 6 [mem 0x000a0000-0x000bffff]
pci_bus 0000:05: resource 7 [mem 0xd0000000-0xf7ffffff]
pci_bus 0000:06: resource 0 [io 0x1000-0x1fff]
pci_bus 0000:06: resource 1 [mem 0xe0100000-0xe01fffff]
pci_bus 0000:07: resource 0 [io 0x1000-0x1fff]
pci_bus 0000:07: resource 1 [mem 0xe0100000-0xe01fffff]
NET: Registered protocol family 2
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP: reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
pci 0000:00:02.0: Boot video device
PCI: CLS 64 bytes, default 64
Trying to unpack rootfs image as initramfs...
Freeing initrd memory: 13016k freed
audit: initializing netlink socket (disabled)
type=2000 audit(1398622053.718:1): initialized
highmem bounce pool size: 64 pages
HugeTLB registered 4 MB page size, pre-allocated 0 pages
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
fuse init (API version 7.18)
msgmni has been set to 1726
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
io scheduler noop registered (default)
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
pciehp: PCI Express Hot Plug Controller Driver version: 0.4
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
00:0a: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
Linux agpgart interface v0.103
agpgart-intel 0000:00:00.0: Intel GMA3150 Chipset
agpgart-intel 0000:00:00.0: detected gtt size: 524288K total, 262144K mappable
agpgart-intel 0000:00:00.0: detected 8192K stolen memory
agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xd0000000
brd: module loaded
loop: module loaded
ata_piix 0000:00:1f.2: version 2.13
ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
ata_piix 0000:00:1f.2: setting latency timer to 64
scsi0 : ata_piix
scsi1 : ata_piix
ata1: SATA max UDMA/133 cmd 0x30b8 ctl 0x30cc bmdma 0x30a0 irq 18
ata2: SATA max UDMA/133 cmd 0x30b0 ctl 0x30c8 bmdma 0x30a8 irq 18
Fixed MDIO Bus: probed
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
PPP generic driver version 2.4.2
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci_hcd 0000:00:1d.7: setting latency timer to 64
ehci_hcd 0000:00:1d.7: EHCI Host Controller
ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
ehci_hcd 0000:00:1d.7: using broken periodic workaround
ehci_hcd 0000:00:1d.7: debug port 1
ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
ehci_hcd 0000:00:1d.7: irq 23, io mem 0xe0384400
ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 8 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
uhci_hcd: USB Universal Host Controller Interface driver
uhci_hcd 0000:00:1d.0: setting latency timer to 64
uhci_hcd 0000:00:1d.0: UHCI Host Controller
uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
uhci_hcd 0000:00:1d.0: irq 23, io base 0x00003080
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
uhci_hcd 0000:00:1d.1: setting latency timer to 64
uhci_hcd 0000:00:1d.1: UHCI Host Controller
uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
uhci_hcd 0000:00:1d.1: irq 19, io base 0x00003060
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
uhci_hcd 0000:00:1d.2: setting latency timer to 64
uhci_hcd 0000:00:1d.2: UHCI Host Controller
uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
uhci_hcd 0000:00:1d.2: irq 18, io base 0x00003040
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
uhci_hcd 0000:00:1d.3: setting latency timer to 64
uhci_hcd 0000:00:1d.3: UHCI Host Controller
uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
uhci_hcd 0000:00:1d.3: irq 16, io base 0x00003020
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 2 ports detected
usbcore: registered new interface driver libusual
i8042: PNP: No PS/2 controller found. Probing ports directly.
serio: i8042 KBD port at 0x60,0x64 irq 1
serio: i8042 AUX port at 0x60,0x64 irq 12
mousedev: PS/2 mouse device common for all mice
rtc_cmos 00:03: RTC can wake from S4
rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
EISA: Probing bus 0 at eisa.0
EISA: Cannot allocate resource for mainboard
Cannot allocate resource for EISA slot 1
Cannot allocate resource for EISA slot 2
Cannot allocate resource for EISA slot 3
Cannot allocate resource for EISA slot 4
Cannot allocate resource for EISA slot 5
Cannot allocate resource for EISA slot 6
Cannot allocate resource for EISA slot 7
Cannot allocate resource for EISA slot 8
EISA: Detected 0 cards.
EFI Variables Facility v0.08 2004-May-17
TCP: cubic registered
NET: Registered protocol family 10
NET: Registered protocol family 17
Registering the dns_resolver key type
Using IPI Shortcut mode
registered taskstats version 1
rtc_cmos 00:03: setting system clock to 2014-04-27 18:07:34 UTC (1398622054)
BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
EDD information not available.
ata2.01: NODEV after polling detection
ata1.00: ATA-8: SATA SSD, S5FAM012, max UDMA/100
ata1.00: 62533296 sectors, multi 16: LBA48 NCQ (depth 0/32)
ata2.00: ATAPI: HL-DT-STDVD-RAM GH22NS30, 1.01, max UDMA/100
ata1.00: configured for UDMA/100
scsi 0:0:0:0: Direct-Access ATA SATA SSD S5FA PQ: 0 ANSI: 5
sd 0:0:0:0: [sda] 62533296 512-byte logical blocks: (32.0 GB/29.8 GiB)
sd 0:0:0:0: Attached scsi generic sg0 type 0
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
ata2.00: configured for UDMA/100
sda: sda1 sda2 < sda5 >
scsi 1:0:0:0: CD-ROM HL-DT-ST DVD-RAM GH22NS30 1.01 PQ: 0 ANSI: 5
sd 0:0:0:0: [sda] Attached SCSI disk
sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
cdrom: Uniform CD-ROM driver Revision: 3.20
sr 1:0:0:0: Attached scsi CD-ROM sr0
sr 1:0:0:0: Attached scsi generic sg1 type 5
Freeing unused kernel memory: 544k freed
udevd[91]: starting version 175
r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
r8169 0000:01:00.0: irq 40 for MSI/MSI-X
r8169 0000:01:00.0: eth0: RTL8168e/8111e at 0xf8040000, e8:40:f2:0a:ef:57, XID 0c200000 IRQ 40
r8169 0000:01:00.0: eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
Refined TSC clocksource calibration: 1800.063 MHz.
Switching to clocksource tsc
EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
usb 4-1: new low-speed USB device number 2 using uhci_hcd
init: ureadahead main process (230) terminated with status 5
Adding 2077692k swap on /dev/sda5. Priority:-1 extents:1 across:2077692k SS
udevd[305]: starting version 175
EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
lp: driver loaded but no devices found
usb 4-2: new low-speed USB device number 3 using uhci_hcd
input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
ACPI: Sleep Button [SLPB]
input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
ACPI: Power Button [PWRF]
[drm] Initialized drm 1.1.0 20060810
pci 0000:00:02.0: setting latency timer to 64
parport_pc 00:08: reported by Plug and Play ACPI
parport0: PC-style at 0x378, irq 7 [PCSPP]
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
lp0: using parport0 (interrupt-driven).
input: USB Keyboard as /devices/pci0000:00/0000:00:1d.2/usb4/4-1/4-1:1.0/input/input2
generic-usb 0003:04D9:1603.0001: input,hidraw0: USB HID v1.10 Keyboard [ USB Keyboard] on usb-0000:00:1d.2-1/input0
type=1400 audit(1398622055.895:2): apparmor="STATUS" operation="profile_load" name="/sbin/dhclient" pid=505 comm="apparmor_parser"
type=1400 audit(1398622055.896:3): apparmor="STATUS" operation="profile_load" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=505 comm="apparmor_parser"
type=1400 audit(1398622055.897:4): apparmor="STATUS" operation="profile_load" name="/usr/lib/connman/scripts/dhclient-script" pid=505 comm="apparmor_parser"
snd_hda_intel 0000:00:1b.0: irq 41 for MSI/MSI-X
pci 0000:00:02.0: irq 42 for MSI/MSI-X
[drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[drm] No driver support for vblank timestamp query.
[drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
microcode: CPU0 sig=0x106ca, pf=0x8, revision=0x107
coretemp coretemp.0: Using relative temperature scale!
input: USB Keyboard as /devices/pci0000:00/0000:00:1d.2/usb4/4-1/4-1:1.1/input/input3
generic-usb 0003:04D9:1603.0002: input,hidraw1: USB HID v1.10 Device [ USB Keyboard] on usb-0000:00:1d.2-1/input1
input: Logitech USB Laser Mouse as /devices/pci0000:00/0000:00:1d.2/usb4/4-2/4-2:1.0/input/input4
generic-usb 0003:046D:C069.0003: input,hidraw2: USB HID v1.10 Mouse [Logitech USB Laser Mouse] on usb-0000:00:1d.2-2/input0
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
ppdev: user-space parallel port driver
input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input5
input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
input: HDA Intel Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
type=1400 audit(1398622056.281:5): apparmor="STATUS" operation="profile_load" name="/usr/lib/cups/backend/cups-pdf" pid=659 comm="apparmor_parser"
type=1400 audit(1398622056.283:6): apparmor="STATUS" operation="profile_load" name="/usr/sbin/cupsd" pid=659 comm="apparmor_parser"
microcode: CPU1 sig=0x106ca, pf=0x8, revision=0x107
microcode: CPU2 sig=0x106ca, pf=0x8, revision=0x107
microcode: CPU3 sig=0x106ca, pf=0x8, revision=0x107
microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
init: failsafe main process (710) killed by TERM signal
init: udev-fallback-graphics main process (764) terminated with status 1
type=1400 audit(1398622056.713:7): apparmor="STATUS" operation="profile_replace" name="/sbin/dhclient" pid=803 comm="apparmor_parser"
type=1400 audit(1398622056.714:8): apparmor="STATUS" operation="profile_replace" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=803 comm="apparmor_parser"
type=1400 audit(1398622056.714:9): apparmor="STATUS" operation="profile_replace" name="/usr/lib/connman/scripts/dhclient-script" pid=803 comm="apparmor_parser"
type=1400 audit(1398622056.725:10): apparmor="STATUS" operation="profile_load" name="/usr/lib/lightdm/lightdm/lightdm-guest-session-wrapper" pid=802 comm="apparmor_parser"
r8169 0000:01:00.0: eth0: link down
ADDRCONF(NETDEV_UP): eth0: link is not ready
r8169 0000:01:00.0: eth0: link up
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
eth0: no IPv6 routers present
audit_printk_skb: 42 callbacks suppressed
type=1400 audit(1398622077.891:25): apparmor="DENIED" operation="open" parent=1 profile="/usr/lib/telepathy/mission-control-5" name="/usr/share/gvfs/remote-volume-monitors/" pid=1683 comm="mission-control" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
I-pipe: head domain RTAI registered.
RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 12502210, CLK_FREQ 1800184000, CPU_FREQ 1800184000
RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12502210, 12502210, 12232000
RTAI[malloc]: global heap size = 131072 bytes, <BSD>.
, <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
RTAI[sched]: hard timer type/freq = APIC/12502210(Hz); default timing: periodic; linear timed lists.
RTAI[sched]: Linux timer freq = 1000 (Hz), TimeBase freq = 1800184000 hz.
RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
***** WARNING: GLOBAL HEAP NEITHER SHARABLE NOR USABLE FROM USER SPACE (use the vmalloc option for RTAI malloc) *****
RTAI[math]: loaded.
RTAI[math]: unloaded.
RTAI[malloc]: unloaded.
RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
I-pipe: head domain RTAI unregistered.
RTAI[hal]: unmounted.
TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12502210, 12502210, 12212000
RTAI[math]: loaded.
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2_pci: discovered 4i65 at 0000:07:00.0
hm2/hm2_4i65.0: firmware hm2/4i65/SVST8_4.BIT not found
hm2/hm2_4i65.0: install the package containing the firmware.
hm2_4i65.0: board fails HM2 registration
hm2_pci: probe of 0000:07:00.0 failed with error -2
hm2: unloading
TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12502210, 12502210, 12129000
RTAI[math]: loaded.
hm2_4i65.0: FPGA did not reset: /INIT = 1, DONE = 1
hm2/hm2_4i65.0: failed to reset fpga, aborting hm2_register
hm2_pci: probe of 0000:07:00.0 failed with error -5
hm2: unloading
28 Apr 2014 03:26 #46385
The error is that the bitfile is not found:
hm2: unloading
- hardware_crash
05 May 2014 00:00 - 05 May 2014 00:05 #46583
by hardware_crash
Dear PCW,
The strange thing is that the package is installed in lib/firmware/hm2/4i65
I got it from here buildbot.linuxcnc.org/hm2/dists/hm2-firm.../master/binary-i386/
Isn“t that right ?
canceled with:
Isn“t that right ?
canceled with:
hm2: unloading
Last edit: 05 May 2014 00:05 by hardware_crash.
05 May 2014 00:48 #46585
OK thats a different error now. The first error was
the new error is
This could be be a couple of things none of which are very obvious from the error.
The 4I65 card was found which means at least configuration cycles were passed through the
5i71s bridge to the 4I73s bridge to the 4I65. but it appears that normal read/writes may not work
This can be a hardware issue on the Motherboard, a hardware issue on the 5I71,
or a BIOs issue on the motherboard. Difficult to tell without more poking around
can you do a lspci -vv on the system that does not work and post the results here?
the new error is
- micges
- Thank you received: 3
05 May 2014 00:50 #46586
by micges
Replied by micges on topic Mesa 4i65 does not response
Please paste output from 'lspci -vnn' command.
Also try using newest mesaflash utility from github.com/micges/mesaflash to access board. (follow README how to compile).
use command 'sudo ./mesaflash --device 4i65 --verbose' and paste output (if any).
regards,
Michael
regards,
Michael
- hardware_crash
05 May 2014 02:12 - 05 May 2014 02:18 #46588
by hardware_crash
Output of lspci:
The same configuration on an other motherboard with an 6i71 connected via PCI express works fine..
Output of mesaflash:
Subsystem: Intel Corporation Device 574d
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ >SERR- <PERR- INTx-
Latency: 0
Capabilities: <access denied>
Kernel driver in use: agpgart-intel
00:02.0 VGA compatible controller: Intel Corporation Atom Processor D4xx/D5xx/N4xx/N5xx Integrated Graphics Controller (rev 02) (prog-if 00 [VGA controller])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 41
Region 0: Memory at e0300000 (32-bit, non-prefetchable) [size=512K]
Region 1: I/O ports at 30c0 [size=8]
Region 2: Memory at d0000000 (32-bit, prefetchable) [size=256M]
Region 3: Memory at e0200000 (32-bit, non-prefetchable) [size=1M]
Expansion ROM at <unassigned> [disabled]
Kernel modules: i915
Subsystem: Intel Corporation Device d625
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 42
Region 0: Memory at e0380000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd-hda-intel
00:1c.0 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 1 (rev 01) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00002000-00002fff
Memory behind bridge: e0400000-e07fffff
Prefetchable memory behind bridge: 00000000e0000000-00000000e00fffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
BridgeCtl: Parity- SERR- NoISA+ VGA- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Kernel driver in use: pcieport
Kernel modules: shpchp
00:1c.1 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 2 (rev 01) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 00004000-00004fff
Memory behind bridge: e0800000-e09fffff
Prefetchable memory behind bridge: 00000000e0a00000-00000000e0bfffff
00:1c.2 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 3 (rev 01) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 00005000-00005fff
Memory behind bridge: e0c00000-e0dfffff
Prefetchable memory behind bridge: 00000000e0e00000-00000000e0ffffff
00:1c.3 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 4 (rev 01) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
I/O behind bridge: 00006000-00006fff
Memory behind bridge: e1000000-e11fffff
Prefetchable memory behind bridge: 00000000e1200000-00000000e13fffff
00:1d.0 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #1 (rev 01) (prog-if 00 [UHCI])
Control: I/O+ Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 23
Region 4: I/O ports at 3080 [size=32]
Kernel driver in use: uhci_hcd
00:1d.1 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #2 (rev 01) (prog-if 00 [UHCI])
Latency: 0
Interrupt: pin B routed to IRQ 19
Region 4: I/O ports at 3060 [size=32]
00:1d.2 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #3 (rev 01) (prog-if 00 [UHCI])
Latency: 0
Interrupt: pin C routed to IRQ 18
Region 4: I/O ports at 3040 [size=32]
00:1d.3 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #4 (rev 01) (prog-if 00 [UHCI])
Latency: 0
Interrupt: pin D routed to IRQ 16
Region 4: I/O ports at 3020 [size=32]
00:1d.7 USB controller: Intel Corporation NM10/ICH7 Family USB2 EHCI Controller (rev 01) (prog-if 20 [EHCI])
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Region 0: Memory at e0384400 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ehci_hcd
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e1) (prog-if 01 [Subtractive decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Latency: 0
Bus: primary=00, secondary=05, subordinate=07, sec-latency=0
I/O behind bridge: 00001000-00001fff
Memory behind bridge: e0100000-e01fffff
Secondary status: 66MHz- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
00:1f.2 IDE interface: Intel Corporation NM10/ICH7 Family SATA Controller [IDE mode] (rev 01) (prog-if 8f [Master SecP SecO PriP PriO])
Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 18
Region 0: I/O ports at 30b8 [size=8]
Region 1: I/O ports at 30cc [size=4]
Region 2: I/O ports at 30b0 [size=8]
Region 3: I/O ports at 30c8 [size=4]
Region 4: I/O ports at 30a0 [size=16]
Region 5: Memory at e0384000 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ata_piix
Control: I/O+ Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Interrupt: pin B routed to IRQ 11
Region 4: I/O ports at 3000 [size=32]
Kernel modules: i2c-i801
Interrupt: pin A routed to IRQ 40
Region 0: I/O ports at 2000 [size=256]
Region 2: Memory at e0004000 (64-bit, prefetchable) [size=4K]
Region 4: Memory at e0000000 (64-bit, prefetchable) [size=16K]
Kernel driver in use: r8169
Kernel modules: r8169
05:00.0 PCI bridge: PLX Technology, Inc. PEX8112 x1 Lane PCI Express-to-PCI Bridge (rev aa) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV+ VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz+ UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 32, Cache Line Size: 64 bytes
Bus: primary=05, secondary=06, subordinate=07, sec-latency=0
06:00.0 PCI bridge: PLX Technology, Inc. PEX8112 x1 Lane PCI Express-to-PCI Bridge (rev aa) (prog-if 00 [Normal decode])
Bus: primary=06, secondary=07, subordinate=07, sec-latency=0
Secondary status: 66MHz+ FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- <SERR- <PERR-
Subsystem: PLX Technology, Inc. Device 3132
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Interrupt: pin A routed to IRQ 20
Region 0: Memory at e0120000 (32-bit, non-prefetchable) [size=128]
Region 1: I/O ports at 1200 [size=128]
Region 2: I/O ports at 1100 [size=256]
Region 3: I/O ports at 1000 [size=256]
Region 4: Memory at e0110000 (32-bit, non-prefetchable) [size=64K]
Region 5: Memory at e0100000 (32-bit, non-prefetchable) [size=64K]
PCI device 4I65 at 0000:07:00.0 (10B5:9030)
Region 0: Memory at E0120000 [size=00000080]
Region 1: I/O at 1200 [size=0080]
Region 2: I/O at 1100 [size=0100]
Region 3: I/O at 1000 [size=0100]
Region 4: Memory at E0110000 [size=00010000]
Region 5: Memory at E0100000 [size=00010000]
Communication:
Ctrl I/O addr: 1200
Data I/O addr: 1100
Memory: E0100000
Board info:
Connectors count: 3
Pins per connector: 24
Connectors names: P1 P3 P4
FPGA type: 2s200pq208
Number of leds: 8
Last edit: 05 May 2014 02:18 by hardware_crash.
05 May 2014 02:33 - 05 May 2014 02:38 #46589
Hmm the lspci list looks OK
can you try:
sudo ./mesaflash --device 4i65 --program /lib/firmware/hm2/4i65/SVST4_8.BIT
(or some valid bit file name)
can you try:
Last edit: 05 May 2014 02:38 by PCW. Reason: --write should be --program
- hardware_crash
05 May 2014 02:50 - 05 May 2014 03:00 #46591
by hardware_crash
Worked but didnt chage anything .
Its the same error fpga does not reset ..
PS: I have the often used Intel D525MW Board .
sudo ./mesaflash --device 4i65 --program /lib/firmware/hm2/4i65/SVST8_4.BIT
Checking file... OK
File type: BIT file
Design name: work.ncd
Part name: 2s200pq208
Design date: 2013/12/14
Design time: 17:34:20
Config Length: 166980
Programming FPGA...
|WWWWWWWWWWWWWWWWWWWWW
Board FPGA programmed successfully
Last edit: 05 May 2014 03:00 by hardware_crash.
Time to create page: 0.078 seconds
