3 Servos and 1 Stepper on a 7i77 +5i25
16 Feb 2014 00:14 #43880 by Mr. Technical
3 Servos and 1 Stepper on a 7i77 +5i25 was created by Mr. Technical
Hi Guys,
I'm working on a trivkins 4 axis mill retrofit that started as a 3 axis servo machine. No problem there, but I'd also like to add a stepper driven 4th axis. Is there a way to control that 4th axis through the 7i77 without another daughter card being added to the mix? Thanks in advance.
Mr. Technical
16 Feb 2014 01:32 #43882 by PCW
Replied by PCW on topic 3 Servos and 1 Stepper on a 7i77 +5i25
Not really but you can add a low cost parallel port breakout board to the 5I25s P2
(or just connect the P2 pins directly if you are careful...)
16 Feb 2014 01:50 #43883 by Mr. Technical
Replied by Mr. Technical on topic 3 Servos and 1 Stepper on a 7i77 +5i25
That's good news! Which parallel port breakout board would you recommend? I only need to send it step and direction signals, with minimal IO to release the brake. Encoder feedback would be a big plus.
Also, will PNCCONF be able to help configure it, or am I going to have to hand edit the HAL file?
Mr. Technical
16 Feb 2014 02:02 - 16 Feb 2014 02:03 #43884 by PCW
You will likely have to hand edit the HAL file
You will also need a custom bitfile that matches the breakout board that you choose.
If you post a link to the specs of the breakout you want to use, I will make a bitfile for it (7I77 on P3, BOB on P2) and add it to the standard pinout library.
Last edit: 16 Feb 2014 02:03 by PCW. Reason: errors
16 Feb 2014 04:21 #43887 by Mr. Technical
Thanks very much for the offer of a custom bitfile. I really like Mesa's (your?) products, so if they/you have something suitable, I would start there. Like I mentioned, I just need to send it step and direction signals, the ability to release the brake, and hopefully get encoder feedback if that's not asking too much.
Mr. Technical
25 Feb 2014 00:17 #44133 by andypugh
Replied by andypugh on topic 3 Servos and 1 Stepper on a 7i77 +5i25
You might be able to use software step generation if the required speed is low. 7i77 IO pins only update at 1kHz, so you would be looking at a max of 150 rpm from the stepper.
I think that there is a standard firmware for a 7i77 / 7i76 combo that puts stepgens on one of the headers, assuming you are able to configure the hardware to deal with where the 7i76 stepgen pins are.
25 Feb 2014 11:51 #44167 by cmorley
Replied by cmorley on topic 3 Servos and 1 Stepper on a 7i77 +5i25
yes there is a 7i77_7i76 firmware.
The step gens are on connector 2 so you could connect to the directly and not use a 7i76.
PNCconf should work fine for this as long as you don't assign anything to the 7i76"s smart serial tabs
Chris M
The following user(s) said Thank You: Mr. Technical
21 Mar 2014 09:38 #45019 by Mr. Technical
Hi Chris,
Thanks for the good information! I was able to set up the I/O connector 2 tab up with the A-axis stepgen on number 0 and then set up the A axis motor/encoder configuration page up for use with a Gecko 203V, even though I'm really using a DM542A from Longs Motor as the driver.
Since I'm using the 5i25 as the source for the second parallel port, how should I set the I/O Control Ports/Boards section of the Basic Machine Infirmation page?
I'm getting a terminated with an error when trying to run the config that I set up. I should mention that I have power applied to the 7i77 board and was able to open Linuxcnc before I started messing with the A -axis. I don't have the driver with me at the moment, so that's not hooked up. Thanks in advance!
Mr. Technical
21 Mar 2014 20:02 #45028 by andypugh
What is the error? That's generally a pretty good clue as to what the problem is.
(Normally it is described fairly clearly in the second or third section of the error dump)
21 Mar 2014 21:33 #45030 by Mr. Technical
I've attached my error file. I think the applicable information is the following:
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
FMT.hal:219: parameter or pin 'hm2_5i25.0.stepgen.00.dirsetup' not found
3418
Thanks,
Mr. Technical
Moderators: PCWjmelson
