3 Servos and 1 Stepper on a 7i77 +5i25
22 Mar 2014 01:24 #45048 by Mr. Technical
Replied by Mr. Technical on topic 3 Servos and 1 Stepper on a 7i77 +5i25
Thanks Andy, that's an important thing to know about stripping out the exe bit. I changed it in GUI, and moved the mesaflash exe to the same folder as the bit file I want (5i25_7i77_7i76.bit), opened a terminal, cd to the directory that they're both in, and cut and pasted the text from the post #45032 and now get the following error:
./mesaflash: /usr/lib/libpci.so.3: version `LIBPCI_3.1' not found (required by ./mesaflash)
Mr. Technical
22 Mar 2014 01:38 #45049 by PCW
Replied by PCW on topic 3 Servos and 1 Stepper on a 7i77 +5i25
I may have got a bit too ambitious by updating mesaflash to the latest (which is fine under Ubuntu 12.04)
try this version:
freeby.mesanet.com/oldmesaflash
Or try building on your system (the source is included)
22 Mar 2014 02:01 #45051 by Mr. Technical
(Some) Joy! The old mesaflash didn't throw any errors when I ran it, but I don't think it verified that it was done correctly. Here's an excerpt from the terminal:
Syntax: mesaflash filename command
Writes config data to 5I25/6I25 EEPROM
filename - VALID FPGA configuration file.
Commands:
write - write program in 'filename' into FPGA.
verify - verify if 'filename' is properly programmed in FPGA.
info - print info about 'filename'.
detect - print info about detected board(s) ('filename' is ignored).
fmt@fmt-mill:~$ write
usage: write user [tty]
fmt@fmt-mill:~$ verify
verify: command not found
fmt@fmt-mill:~$
Getting closer...
22 Mar 2014 02:08 - 22 Mar 2014 02:20 #45052 by PCW
I think the command would be
sudo ./oldmesaflash write 5i25_7i76_7i77.bit
Or better still, build the latest mesaflash on your system
Last edit: 22 Mar 2014 02:20 by PCW.
22 Mar 2014 02:30 #45055 by Mr. Technical
Thanks Peter. I caught that too, and changed the text from your earlier post to read "sudo ./oldmesaflash write 5i25_7i76_7i77.bit" and I still wasn't able to verify it. I have no idea how to build the latest mesaflash on my system, but we're so close I can almost taste it!
Any other ideas?
Ian
22 Mar 2014 02:47 #45056 by PCW
did the write command succeed?
to build you unzip the source and type "make" in the source directory
22 Mar 2014 02:56 #45059 by Mr. Technical
I think the 'write' command worked since it didn't say otherwise. I ran it again and this is what it looked like:
fmt@fmt-mill:~$
Does the usage line imply that it wrote it?
22 Mar 2014 02:59 #45060 by PCW
I think you misunderstand the usage of the command
it would be:
sudo ./oldmesaflash write 5i25_7i77_7i76.bit
22 Mar 2014 03:04 #45061 by Mr. Technical
You're right, I did misunderstand that. Here's the complete text that I entered or that came back from the time that I opened the terminal window. Will that be enough to let you know if it worked?
fmt@fmt-mill:~$ sudo ./oldmesaflash --device 5i25 --write 5i25_7i77_7i76.bit
Commands:
fmt@fmt-mill:~$
22 Mar 2014 03:13 #45063 by PCW
did you try:
Moderators: PCWjmelson
Time to create page: 0.078 seconds
