7i77 -> Huanyang
11 years 8 months ago #55734 by dracozny
Replied by dracozny on topic 7i77 -> Huanyang
stumbled across sliptonics ventures into the IRC channel and across his github page I made some changes. max speed on my spindle with this motor is 3600rpm so I made that change to the ini file using pncconf. I'm going to drag my system to the machine and see if it works.
11 years 8 months ago #55739 by dracozny
well that did nothing for me it seems
11 years 8 months ago #55740 by DaBit
Replied by DaBit on topic 7i77 -> Huanyang
Is all of this HAL file generated by pncconf?
In you HAL file I see:
net spindle-vel-cmd-abs => hm2_5i25.0.7i77.0.1.analogout5
But it has no driver.
I would change that to:
net spindle-vel-cmd-rpm-abs => hm2_5i25.0.7i77.0.1.analogout5
And then in you INI, assuming 3600rpm maximum speed when the VFD receives 10V:
[SPINDLE_9]
OUTPUT_SCALE = 3600.0
OUTPUT_MIN_LIMIT = 0.0
OUTPUT_MAX_LIMIT = 10.0
Then, you also have to start the VFD. I do see the CW/CCW pin, but not the run pin. Thus you might need something like
net spindle-on => hm2_5i25.0.7i77.0.0.output-09
and route the appropriate signal through a relay to the VFD, just like you did with the CW/CCW signal.
I do not have a HuanYang VFD anymore so I am doing it from memory: relay contact between DCM and FOR.
I actually doubt this will work flawless since as far as I can remember the forward/reverse rotation are just two separate inputs so a bit of HAL-logic would be needed. I ran mine in forward-only, reverse rotation is prettu useless on a highspeed spindle.
But this should allow forward rotation. When that works, we can tackle reverse rotation.
The following user(s) said Thank You: dracozny
11 years 8 months ago #55749 by dracozny
100% generated by pncconf.
with pd001 and 002 set to the vfd is automatically started by the enable pins on 7177. That part I know works because when I had the minimum set higher for the actual minimal voltage for the motor to start moving, as soon as I enabled the machine it started to spin just without any rpm control. I will try manually changing the code as you suggested for everything else.
I do have boring bars that require the spindle to go in reverse. I may find I need those less often with CNC but I know there are situations that call for them.
11 years 8 months ago #55750 by dracozny
I made the changes to the code you suggested. The spindle still doesn't rotate. Physically checking the analog pins with a multimeter when I hit the "+" button after enabling the direction I get a max reading of .1 volts. it will not go any higher. pressing "-" it goes back to 0v.
11 years 8 months ago #55751 by PCW
Replied by PCW on topic 7i77 -> Huanyang
This is probably what you want:
[SPINDLE_9]
OUTPUT_MAX_LIMIT = 3600.0
Moderators: PCW, jmelson
Time to create page: 0.064 seconds
