7i77 -> Huanyang
10 years 1 month ago #80753 by andypugh
Replied by andypugh on topic 7i77 -> Huanyang
My VFDs come on with the main power. And stay on if the machine is on.
Estop kills their power feed, but otherwise I trust them to only turn the spindle when enabled.
10 years 1 month ago - 10 years 1 month ago #80755 by cmtunnel
Replied by cmtunnel on topic 7i77 -> Huanyang
Ok I'm assuming now that I can run a wire from tb5 ena5+ to the forward pin on the vfd?? Also, I am guessing the driver that is mentioned is not needed for this method??
Last edit: 10 years 1 month ago by cmtunnel.
10 years 1 month ago #80770 by cmtunnel
A single SPDT relay can be used this way:
7I77 ENA5- to GND
7I77 ENA5+ to relay common
relay NC to FOR
relay NO to REV
relay coil to 7I77 output (DIR)
using the fwd only for a cnc router. can I do: 7i77 ena5+ to FOR, 7i77 ground to DCM
7i77 AOUT5 to V1, 7i77 ground to ACM
10 years 1 month ago #80771 by PCW
Replied by PCW on topic 7i77 -> Huanyang
Almost but you need to connect DCM to ena5- instead of 7I77 GND
(The enaN outputs are isolated)
10 years 1 month ago #80773 by cmtunnel
moving on to the config.....I largely copied the configs attached above but it's not working yet. could someone take a peek please.
10 years 1 month ago #80774 by PCW
There are several bugs in that (old) version of pncconf
net spindle-vel-cmd-abs => hm2_5i25.0.7i77.0.1.analogout5 !!!! wrong
SB
net spindle-vel-cmd-rpm-abs => hm2_5i25.0.7i77.0.1.analogout5
net machine-is-enabled => hm2_5i25.0.7i77.0.1.spinena !!!! OWW
SB
net spindle-on <= motion.spindle-on => hm2_5i25.0.7i77.0.1.spinena
Moderators: PCW, jmelson
Time to create page: 0.290 seconds
