Mesa 5i25 and 7176 getting started
- Clive S
- Thank you received: 482
14 May 2015 18:40 #58673
by Clive S
Replied by Clive S on topic Mesa 5i25 and 7176 getting started
I am thinking of going down this route with the 5i25 and the 7i76 but I have noticed that there is a 7i76 E is this supported with linuxcnc or am I better sticking to the 7i76.
I want o run a small lathe and mill using a total of 5 axis and I don't have enough I/0 with the pp setup I have already.
Thanks Clive S
Thanks Clive S
- Thank you received: 4976
14 May 2015 19:40 - 14 May 2015 19:44 #58678
The 7i76E is supported in version 2.7. It only works with the RT-PREEMPT kernel (as far as I know) and probably counts as experimental still.
However, it can be made to work with LinuxCNC.
[Edit] Actually I need to check that
Replied by andypugh on topic Mesa 5i25 and 7176 getting started
I have noticed that there is a 7i76 E is this supported with linuxcnc or am I better sticking to the 7i76.S
Last edit: 14 May 2015 19:44 by andypugh.
- Clive S
14 May 2015 19:50 #58681
by Clive S
..Clive S
Thanks Andy I will hold off for a bit as I would prefer the E version so I will watch this space
14 May 2015 22:03 #58690
I am assured that hm2_eth supports all the Mesa Ethernet cards.
www.linuxcnc.org/docs/2.7/html/man/man9/hm2_eth.9.html
You would need the "uspace" version:
wiki.linuxcnc.org/cgi-bin/wiki.pl?Uspace
You can get the uspace version of LinuxCNC 2.7 from the buildbot:
buildbot.linuxcnc.org/
But you may have to guess the incantation. You might as well go with Master, really.
- Clive S
15 May 2015 00:35 #58695
by Clive S
Thanks again Andy, but I think the water may be a bit too deep to tread in at my level.
Clive S
15 May 2015 16:49 #58714
What OS and kernel are you currently using? (And where did it come from?)
- Clive S
15 May 2015 18:01 #58726
by Clive S
I installed from here www.linuxcnc.org/index.php/english/download 2.6 then updated with sudo apt and it brought it up to version 2.8.0
is this what you are asking?
Clive S
Clive S
15 May 2015 20:20 #58734
2.8.0 or 2.6.8 ?
2.8.0 or 2.6.8 ?
- Clive S
15 May 2015 21:09 #58740
by Clive S
This is what axis is showing: 2.8.0-pre1-598-g048366b But it did also install gmoccapy and I am switching between the two gui's ..Clive
15 May 2015 21:12 #58741
In that case you might well be almost ready-to-go with hm2_eth and the 7i76E
What does "uname -a" say?
Time to create page: 0.095 seconds
