Mesa 5i25 and 7176 getting started
15 May 2015 21:52 #58744 by Clive S
Replied by Clive S on topic Mesa 5i25 and 7176 getting started
This is what axis is showing: 2.8.0-pre1-598-g048366b But it did also install gmoccapy and I am switching between the two gui's ..Clive
In that case you might well be almost ready-to-go with hm2_eth and the 7i76E
What does "uname -a" say?
Linuxcnc-2-6 3.4-9-rtai-686-pae #1 SMP pre-empt Debian 3.4.55-4li!!! sorry a missed the last bit
So its really 2.6 and not 2.8
Clive
15 May 2015 22:01 #58745 by andypugh
Replied by andypugh on topic Mesa 5i25 and 7176 getting started
If Axis says 2.8 then it's probably true.
uname tells us the kernel version, and you are using the LinuxCNC-issued RTAI kernel.
You need to use the rt-preempt kernel with m2_eth
sudo apt-get install linux-image-rt-686-pae
If that works you can then see what uname -a says after rebooting (I don't know if you have to actively choose the new kernel after installing it)
15 May 2015 23:06 #58748 by Clive S
Andy Do you know that if I install the kernel if it will effect the gmocappy bit? I suspect not. I don't think I have read on here anybody using the E version of the 7i76 What would be the biggest advantage of using this over the 7i76 + 5i25 apart from the cable?
Thanks Clive
15 May 2015 23:31 #58749 by andypugh
I don't know if there is any advantage. I am certainly not pushing you in that direction. I thought you wanted to use the 7i76E.
15 May 2015 23:37 #58750 by Clive S
Andy Yes I didn't think you was trying to push me in any direction and I do thank you for your time and efforts you continually put into the forum.
I suppose I was wondering if the pci verses the Ethernet would make any difference to the latency of the system etc.
Clive
15 May 2015 23:40 #58751 by andypugh
hm2_eth only works with the rt-preempt kernel which has worse latency than the RTAI kernel.
That doesn't really matter for the Mesa cards, though.
If you want a proven setup that thousands of people are using and that is well understood then go for the 5i25/7i76 option.
16 May 2015 05:00 #58753 by Clive S
Well we have gone round the loop and its been interesting, but as you say follow the crowd at least any questions that I may have to ask will have been done already. Thanks again Clive
19 May 2015 04:04 #58834 by amhfabs
Replied by amhfabs on topic Mesa 5i25 and 7176 getting started
Do any of you guys know how to use an MPG with the 7i76? I can't see that the manual says anything about it?
I read from another post about setting the board to software "mode 2" but I have no idea how to do this? Something about changing a line in the driver config to sserial_port_0=2000xxxx?? Where do I find this? I'm currently just playing around with PNCconfig as the code side of things in HAL is a bit daunting at the moment....
19 May 2015 04:07 - 19 May 2015 04:07 #58836 by andypugh
It's in the HAL file.
Oh Dear :-)
Actually it might well be read in to the HAL file from the INI file in your config. Is the INI file less daunting?
Last edit: 19 May 2015 04:07 by andypugh.
19 May 2015 04:14 #58837 by amhfabs
Ok, I found it in my HAL file,
So I just change this line? then what happens?
Moderators: PCWjmelson
Time to create page: 0.093 seconds
