Rearranging pin assignment on mesa 5i25
  • sirop
  • sirop's Avatar Topic Author
  • Elite Member
  • Elite Member
28 Oct 2015 19:13 #64392 by sirop
Replied by sirop on topic Rearranging pin assignment on mesa 5i25
I posted my VHD file to gist:
gist.github.com/sirop/dd4a8b7c3f7af1953913
You probably mean this line:
(QcountTag,		x"02",	ClockLowTag,	x"01",	QcounterAddr&PadT,			QCounterNumRegs,		x"00",	QCounterMPBitMask),
According to tom-itx.no-ip.biz:81/~webpage/emc/xilinx...14_install_index.php these members are:
'TAG, VERSION, CLOCK, INSTANCES, BASE ADDRESS, NUMBER OF REGISTERS, STRIDES, MPBITMASK'
As I understand, I have only one Encoder instance.
Yes, we'll probably have only one Encoder as we'll have additionally a magnetic position sensor connected into MESA card through SSI.
28 Oct 2015 19:24 #64394 by PCW
Replied by PCW on topic Rearranging pin assignment on mesa 5i25
Yes sorry I misread the ID information the first time
So this may in fact be a hostmot2 driver bug since I dont think there
has ever been a configuration with just one encoder module
As I said adding a second encoder on the P2 I/O connector is harmless
if the pins are just used as GPIO.
I will see if i can duplicate this bug with a 1 encoder setup and if its a real bug, get it fixed
The following user(s) said Thank You: sirop
  • sirop
  • Elite Member
  • Elite Member
29 Oct 2015 19:30 #64445 by sirop
I followed your advice and added a second encoder as you said that only one encoder is too unusual.
But I still see two position pins -- now for each of the two encoders.
Output from mesaflash --device 5i25 --readhmid > myconfig.txt : gist.github.com/sirop/5dc11f91d109bb96d897
My new pinout VHD file: gist.github.com/sirop/2ff83efb44e513be7dbb
halcmd: show pin
Component Pins:
  Comp   Inst Type  Dir         Value  Name                             Epsilon         Flags
    74        s32   OUT             0  hm2_5i25.0.encoder.00.count                      0
    74        s32   OUT             0  hm2_5i25.0.encoder.00.count-la                   0
    74        bit   I/O         FALSE  hm2_5i25.0.encoder.00.index-en                   0
    74        bit   OUT          TRUE  hm2_5i25.0.encoder.00.input-a                    0
    74        bit   OUT          TRUE  hm2_5i25.0.encoder.00.input-b                    0
    74        bit   OUT         FALSE  hm2_5i25.0.encoder.00.input-in                   0
    74        bit   IN          FALSE  hm2_5i25.0.encoder.00.latch-en                   0
    74        bit   IN          FALSE  hm2_5i25.0.encoder.00.latch-po                   0
    74        float OUT             0  hm2_5i25.0.encoder.00.position   0.000010        0
    74        bit   OUT         FALSE  hm2_5i25.0.encoder.00.quad-err                   0
    74        bit   IN          FALSE  hm2_5i25.0.encoder.00.quad-err                   0
    74        s32   OUT             0  hm2_5i25.0.encoder.00.rawcount                   0
    74        s32   OUT             0  hm2_5i25.0.encoder.00.rawlatch                   0
    74        bit   IN          FALSE  hm2_5i25.0.encoder.00.reset                      0
    74        float OUT             0  hm2_5i25.0.encoder.00.velocity   0.000010        0
    74        s32   OUT             0  hm2_5i25.0.encoder.01.count                      0
    74        s32   OUT             0  hm2_5i25.0.encoder.01.count-la                   0
    74        bit   I/O         FALSE  hm2_5i25.0.encoder.01.index-en                   0
    74        bit   OUT         FALSE  hm2_5i25.0.encoder.01.input-a                    0
    74        bit   OUT         FALSE  hm2_5i25.0.encoder.01.input-b                    0
    74        bit   OUT          TRUE  hm2_5i25.0.encoder.01.input-in                   0
    74        bit   IN          FALSE  hm2_5i25.0.encoder.01.latch-en                   0
    74        bit   IN          FALSE  hm2_5i25.0.encoder.01.latch-po                   0
    74        float OUT             0  hm2_5i25.0.encoder.01.position   0.000010        0
    74        bit   OUT         FALSE  hm2_5i25.0.encoder.01.quad-err                   0
29 Oct 2015 21:18 - 29 Oct 2015 21:24 #64453 by PCW
Look carefully (I didn't at first), you will see that the names
are truncated, the first pin is:
but the second is
hm2_5i25.0.encoder.00.position-latched
Why your output is truncated I dont know, heres what I got with
halcmd show pin | grep encoder.00.position
25 float OUT 0 hm2_7i76e.0.encoder.00.position
25 float OUT 0 hm2_7i76e.0.encoder.00.position-latched
Last edit: 29 Oct 2015 21:24 by PCW.
  • sirop
  • Elite Member
  • Elite Member
29 Oct 2015 21:26 #64454 by sirop
Yes, you are right.
Got it also with line completion:
halcmd: getp hm2_5i25.0.encoder.01.position
hm2_5i25.0.encoder.01.position          hm2_5i25.0.encoder.01.position-latched
Moderators: PCW, jmelson
Time to create page: 0.229 seconds
