Simple UART on Mesa 6i25 with 5i25 firmware
06 Nov 2015 23:14 #64909
Replied by andypugh on topic Simple UART on Mesa 6i25 with 5i25 firmware
Indeed, it is better to remove the call to hm2_module_is_consistent_or_complain from the uart.c driver.
would not help.It might be simplest just to comment out the "return -EINVAL" so that you get the warning but execution continues.
The following user(s) said Thank You: sirop
- Thank you received: 5326
06 Nov 2015 23:17 #64910
Replied by PCW on topic Simple UART on Mesa 6i25 with 5i25 firmware
Actually there's no problem at all unless you need to _combine_ Sserial or BSPI with the UART
It just means you need to set the proper instance stride in the vhdl file
- sirop
- Thank you received: 57
06 Nov 2015 23:21 #64911
by sirop
Is x"10" the proper instance stride if only UARTTTag and UARTRTag are needed?
Replied by sirop on topic Simple UART on Mesa 6i25 with 5i25 firmware
07 Nov 2015 01:02 #64922
Isn't that what the comment says:
InstStride1: integer := 64; -- instance stride 1 = 64 bytes = 16 x 32 bit registers !! UARTS need 0x10
-- InstStride1: integer := 16; -- instance stride 1 = 64 bytes = 16 x 32 bit registers !! UARTS need 0x10
- sirop
07 Nov 2015 04:07 #64929
by sirop
I finally understood what you meant.
As all the other pins in my case have InstStride0: integer := 4, I just comment out InstStride1: integer := 64
and use InstStride1: integer := 16 instead.
Then I do not need to edit hostmot2.c.
Just rebuilt the firmware and it worked.
Thanks.
Thanks.
- sirop
10 Nov 2015 04:25 #65058
by sirop
Hallo again.
I am looking at int hm2_uart_setup(char *name, int bitrate, rtapi_s32 tx_mode, rtapi_s32 rx_mode) .
What does this line and its comment mean:git.linuxcnc.org/gitweb?p=linuxcnc.git;a...d0908c8f5b7e9d1#l155
Ok, 1048576=2^20, so we get a buffer size for a given bitrate and clock frequency.
But is the meaning of the comment?
Is it the driver version which is meant?
Or is it also the Mesa card model which is meant?
Thanks.
buff = (rtapi_u32)((bitrate * 1048576.0)/inst->clock_freq); //20 bits in this versionOk, 1048576=2^20, so we get a buffer size for a given bitrate and clock frequency.
Thanks.
10 Nov 2015 09:48 #65063
I imagine so, It is probably based on something in the regmap file.
10 Nov 2015 16:53 #65081
The UART uses a phase accumulator for baud rate generation, this phase accumulator is 20 bits long
That means that the baud rate register value needs to be set to baudrate*2^20/Clock
(Phase accumulators are used for baud rate setting rather than the more normal programmable
dividers because I wanted high resolution baud rate sett-ability at high baud rates and programmable dividers
dont do this well)
dont do this well)
- pmcstoneinc
12 Mar 2016 21:53 #71509
by pmcstoneinc
Replied by pmcstoneinc on topic Simple UART on Mesa 6i25 with 5i25 firmware
With that being said whats the bit rate value for 3Mbps on a 7i92 (50Mhz clock low?)
(3000000 * 2^20) / 5000000 = 62914.56 ??
Let me know. Thanks.
- sirop
12 Mar 2016 22:09 #71511
by sirop
You set the baud rate [= bit rate] as you need it. UART should do up to 10 Mbit/s.
Do not forget about the start and stop bits.
Maybe, you would do better with Packet UART on that frequency?
I prepared PktUART for machinekit: see the latest commits beginning from github.com/sirop/machinekit/commit/3446d...ee7211f94f1a1a2462d5
To use them with LinuxCNC you'll only need to subsitute u8, u16 and so on with rtapi_u8, rtapiu_16 ....
as I see it.
as I see it.
Time to create page: 0.281 seconds
