Mesa 6i25 not working?
10 months 6 days ago #340508 by sorokin_pro
Replied by sorokin_pro on topic Mesa 6i25 not working?
I have similar problem; tried 2 PCs. On both 6i25 is disabled in UEFI and enabled in legacy mode. Tried switching between 5i25 and 6i25 modes.
But mesaflash reports that no boards are found.
Attached output of dmesg and lspci commands.
I am using latest Debian version from LinuxCNC website.
10 months 6 days ago #340509 by tommylight
Replied by tommylight on topic Mesa 6i25 not working?
From your lspci
02:00.0 DPIO module [1100]: Device [2718:5125] (rev 01) Subsystem: Device [2718:5125] Control: I/O- Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx- Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx- Interrupt: pin A routed to IRQ 11 Region 0: Memory at f7e00000 (32-bit, non-prefetchable) [size=64K]
That is the 5i25.
10 months 6 days ago #340511 by PCW
Replied by PCW on topic Mesa 6i25 not working?
The lspci report indicates the the board is accessible (as a 5I25)
Make sure that you leave the 6I25 jumpered for 5I25 mode or you will have access issues.
10 months 6 days ago #340527 by sorokin_pro
But it is 6I25, not 5I25.
Jumpers are:
W1 DOWN W2 DOWN W3 DOWN W4 UP W5 UP W7 UP W8 UP
And it reports 66MHz.
10 months 6 days ago - 10 months 6 days ago #340528 by PCW
That will likely not work, (not meet timing) you must jumper the card for 5I25 mode to use 5I25 firmware (the default)
Last edit: 10 months 6 days ago by PCW.
The following user(s) said Thank You: maxi177
10 months 6 days ago #340530 by sorokin_pro
I just switched to default jumper positions:
W1 DOWN W2 DOWN W3 UP W4 UP W5 UP W7 DOWN W8 UP
Result is still the same:
user@denc:~$ mesaflash --device 6I25 No 6I25 board found user@denc:~$ mesaflash --device 5I25 No 5I25 board found
dmesg and lspci outputs are provided.
Moderators: PCW, jmelson
Time to create page: 0.070 seconds
