Mesa 6i25 not working?
10 months 6 days ago #340534 by PCW
Replied by PCW on topic Mesa 6i25 not working?
Does LinuxCNC see the card?
10 months 6 days ago #340536 by sorokin_pro
Replied by sorokin_pro on topic Mesa 6i25 not working?
This is the part I did not figure out for now.
I tried loading the configuration from PnCconf, but LinuxCNC crashed because some timer was not found. I commented out two lines in the .ini file, and LinuxCNC launched, but I do not know where I can see if it found the card.
Should I just try running some G-code?
This is my first time with MESA and LinuxCNC, but I have experience with industrial CNC machines, 3D printers, Linux, software development, and electronics.
10 months 6 days ago #340538 by tommylight
Replied by tommylight on topic Mesa 6i25 not working?
The config generated by PncConf, edit the .hal file with a text editor (not libreoffice) and omit or delete the line containing DPLL timer, savem start the config again.
10 months 6 days ago #340543 by PCW
If you launch LinuxCNC from the command line, you will get a list as the hardware is discovered
which should help with debugging
The timer issue is possibly  that the installed firmware lacks a DPLL timer
(and pncconf always puts DPLL timer boilerplate in the hal file)
 You can work around this by deleting (or commenting out)  any lines that
mention "dpll" in the hal file
10 months 6 days ago - 10 months 6 days ago #340545 by sorokin_pro
Looks like LinuxCNC detects the board:
user@denc:~$ linuxcnc LINUXCNC - 2.9.7 Machine configuration directory is '/home/user/linuxcnc/configs/BenchtopX5' Machine configuration file is 'BenchtopX5.ini' Starting LinuxCNC... linuxcnc TPMOD=tpmod HOMEMOD=homemod EMCMOT=motmod Note: Using POSIX realtime Found file(REL): ./BenchtopX5.hal hm2: loading Mesa HostMot2 driver version 0.15 hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7 hm2_pci: discovered 5i25 at 0000:02:00.0 hm2/hm2_5i25.0: Low Level init 0.15 hm2/hm2_5i25.0: Smart Serial Firmware Version 43 hm2/hm2_5i25.0: 34 I/O Pins used: hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output) hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output) hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output) hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output) hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #2, pin Direction (Output) hm2/hm2_5i25.0: IO Pin 005 (P3-16): StepGen #2, pin Step (Output) hm2/hm2_5i25.0: IO Pin 006 (P3-04): StepGen #3, pin Direction (Output) hm2/hm2_5i25.0: IO Pin 007 (P3-17): StepGen #3, pin Step (Output) hm2/hm2_5i25.0: IO Pin 008 (P3-05): StepGen #4, pin Direction (Output) hm2/hm2_5i25.0: IO Pin 009 (P3-06): StepGen #4, pin Step (Output) hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort hm2/hm2_5i25.0: registered hm2_5i25.0: initialized AnyIO board at 0000:02:00.0 Found file(REL): ./custom.hal link (updating variable file): No such file or directory No option 'tto_g11' in section: 'DEFAULT' No option 'show_program' in section: 'DEFAULT' No option 'show_rapids' in section: 'DEFAULT' No option 'program_alpha' in section: 'DEFAULT' No option 'show_live_plot' in section: 'DEFAULT' No option 'show_tool' in section: 'DEFAULT' No option 'show_extents' in section: 'DEFAULT' No option 'show_offsets' in section: 'DEFAULT' No option 'grid_size' in section: 'DEFAULT' No option 'show_machine_limits' in section: 'DEFAULT' No option 'show_machine_speed' in section: 'DEFAULT' No option 'show_distance_to_go' in section: 'DEFAULT' No option 'dro_large_font' in section: 'DEFAULT' No option 'block_delete' in section: 'DEFAULT' No option 'optional_stop' in section: 'DEFAULT' note: MAXV max: 25.000 units/sec 1500.000 units/min note: LJOG max: 25.000 units/sec 1500.000 units/min note: LJOG default: 6.000 units/sec 360.000 units/min note: AJOG max: 180.000 units/sec 10800.000 units/min note: AJOG default: 12.000 units/sec 720.000 units/min note: jog_order='XYZA' note: jog_invert=set()
Would be great if mesaflash also could detect it.
Last edit: 10 months 6 days ago by sorokin_pro.
10 months 6 days ago #340546 by PCW
Will mesaflash recognize the card after LinuxCNC has run?
(I've seen this before with some BIO's that detect the card but for some reason disable the cards memory region)
Moderators: PCW, jmelson
Time to create page: 0.075 seconds
