Mesa 7i76e => hm2_eth: Unrecognized ethernet board
24 Nov 2015 16:14 - 24 Nov 2015 16:15 #65737 by PCW
Heres a Linux version of the setname program:
freeby.mesanet.com/setname
export PROTOCOL=direct
export INTERFACE=elbp16
export IPADDR=192.168.1.121
./setname 7I76E-16
setname is statically linked so should run on most linux systems
Last edit: 24 Nov 2015 16:15 by PCW. Reason: fix url
The following user(s) said Thank You: sirhc
24 Nov 2015 18:38 #65751 by sirhc
That worked for me! Thanks
  • jtc
  • jtc's Avatar Topic Author
  • Premium Member
  • Premium Member
25 Nov 2015 13:31 - 25 Nov 2015 13:31 #65773 by jtc
Worked on windows version. Finally have a working configuration running.
Last edit: 25 Nov 2015 13:31 by jtc.
03 Dec 2015 16:59 #66294 by OPS
I've bought my board recently too, changed name by setname, but the board still not visible imho. I'm still getting error
Unsupported ethernet device ���������������� at 192.168.1.121
No 7I76E-16 board found :(
Could you suggest how to fix this?
Regards,
Oleg
03 Dec 2015 17:02 - 03 Dec 2015 17:05 #66297 by PCW
Did you power cycle the 7I76E after running setname?
(The card name is stored in EEPROM which is only read at power up or soft reset)
Last edit: 03 Dec 2015 17:05 by PCW.
The following user(s) said Thank You: OPS
03 Dec 2015 17:08 #66298 by OPS
YESS - that was the reason. I've just managed this and it works! Thaks for such a prompt reply!
03 Dec 2015 17:17 #66299 by OPS
Sorry for offtop (( could you also suggest a link where to get a fresh firmware and sample configs for this board? Im running it on RT_PREEMP kernel amd_64 and my current firmware version 15. Thank you in advance,
Oleg
03 Dec 2015 17:44 - 03 Dec 2015 18:01 #66301 by PCW
Unless you need a config with additional daughtercards on the expansion connectors
the installed firmware should be fine (its the latest)
freeby.mesanet.com/7i76e.zip
is a minimal hal/ini config example file set
(note if you _just_ fetched this, refetch as the version on freeby was out of date and I just now updated it)
You may need to change the IP address in the .ini file
Last edit: 03 Dec 2015 18:01 by PCW.
07 Jun 2017 15:25 #94237 by bymccoy
How do you configure the 7i76e with daughter cards?
I have a 7i85 quad encoder on first port and plan in future to add a 7i76 on the second port.
Is this configured via firmware, onboard config or via the host software (LinuxCNC?)
Thanks!
07 Jun 2017 15:59 #94244 by PCW
You need to have firmware that matches the daughterboard set you have
for example, a 7I76E+7I85 would use 7i76e_7i76x1_7i85x1D.bit
firmware.
LinuxCNC would need to be configured to use the added encoders
Moderators: PCW, jmelson
Time to create page: 0.097 seconds
