Mesa 7i76e => hm2_eth: Unrecognized ethernet board
10 years 11 months ago - 10 years 11 months ago #65773 by jtc
Worked on windows version. Finally have a working configuration running.
Last edit: 10 years 11 months ago by jtc.
10 years 10 months ago #66294 by OPS
I've bought my board recently too, changed name by setname, but the board still not visible imho. I'm still getting error
Unsupported ethernet device ���������������� at 192.168.1.121
No 7I76E-16 board found :(
Could you suggest how to fix this?
Regards,
Oleg
10 years 10 months ago - 10 years 10 months ago #66297 by PCW
Did you power cycle the 7I76E after running setname?
(The card name is stored in EEPROM which is only read at power up or soft reset)
Last edit: 10 years 10 months ago by PCW.
The following user(s) said Thank You: OPS
10 years 10 months ago #66298 by OPS
YESS - that was the reason. I've just managed this and it works! Thaks for such a prompt reply!
10 years 10 months ago #66299 by OPS
Sorry for offtop (( could you also suggest a link where to get a fresh firmware and sample configs for this board? Im running it on RT_PREEMP kernel amd_64 and my current firmware version 15. Thank you in advance,
Oleg
10 years 10 months ago - 10 years 10 months ago #66301 by PCW
Unless you need a config with additional daughtercards on the expansion connectors
the installed firmware should be fine (its the latest)
freeby.mesanet.com/7i76e.zip
is a minimal hal/ini config example file set
(note if you _just_ fetched this, refetch as the version on freeby was out of date and I just now updated it)
You may need to change the IP address in the .ini file
Moderators: PCW, jmelson
