do I need Opto isolators for General Mechatronics?
24 Nov 2015 14:04 - 24 Nov 2015 14:04 #65733 by toolmaker69
Hello,
I am putting together a micromachining center using Mitsubishi DC permanent magnet servo motors and meldar (mitsubishi) drives in a linuxcnc system, starting with four axes. To avoid loading the server up with lots of pictures, the link to info is at forum.linuxcnc.org/forum/38-general-linu...-hardware-components
I am about to order General Mechatronics GM6 card www.generalmechatronics.com/en/productdi...-motion-control-card and it looks like I would need optoisolators www.generalmechatronics.com/en/productdi...xis-optical-isolator in order to hook up the resolvers.
Is this correct? I have them all in my shopping cart, but would not order the isolators if I don't need them.
Thanks for any help.
I'm learning as I go, so please excuse my ignorance.
Last edit: 24 Nov 2015 14:04 by toolmaker69. Reason: typo
24 Nov 2015 17:16 #65742 by andypugh
If you have Resolvers, then I don't think that opto-isolators are appropriate.
Tamagawa are best known for Resolvers, but the devices on your servos seem to specify 1250 counts/turn so probably are not resolvers but encoders.
I would suggest that you ask GM for advice.
24 Nov 2015 17:30 #65743 by jmelson
Hello,
I didn't see any resolvers, but there are clearly labeled encoders on the motors.
You generally would not use optoisolators with encoders.
Jon
24 Nov 2015 18:25 #65749 by toolmaker69
Replied by toolmaker69 on topic do I need Opto isolators for General Mechatronics?
Thanks.
I will contact them tonight after work.
I didn't realize there is a difference between encoders and resolvers. I just looked it up.
24 Nov 2015 18:33 #65750 by toolmaker69
Thanks for the reply and for looking at my other post.
I checked GM's site and they mention differential and TTL encoders, though I don't understand what they are saying.
"This module can be used for isolating all the signals referred to the PC ground, and interfacing with TTL or differential output encoders."
I don't know what signals they refer to. Do the encoders need a PC ground? Or is the isolator for a different application when it comes to encoders?
Again, please understand that I'm new to this.
25 Nov 2015 12:22 #65770 by andypugh
I would suggest that you email GM, describing what motors and drives you have.
I am not familiar enough with GM products to be able to advise.
25 Nov 2015 13:57 - 25 Nov 2015 14:55 #65774 by toolmaker69
Thanks. I emailed them yesterday and received a reply this morning (NY time).
"In general, it is not necessary if your servo driver electronics are already isolated. So one isolation is important between the control electronics and the power electronics."
I now have something else to research, if the answer is not obvious. I had assumed that I would be using PWM, since that is how I have programmed robots in the past, and I saw the letters PWM in another (Japanese) manual that seemed to use the same drive. GM doesn't support PWM, only voltage or current reference.
I probably just "misspoke" when I mentioned PWM to them. Do you know if CNC's used PWM around 1987? Can you tell from the pics of the drive what kind of input it might use? Some parts of my main machine installation manual mentions voltage input, but is not too technical.
EDIT:
I found this info in the Meldas II manual.
"The transistor amplifier amplifies the power by high frequency switching according to the pulse
width modulation method for the error voltage (command voltage) by comparing the position
detector output and the calculation result output from the logic card of the control unit in regard
to the movement command."
This seems to be if one is using the built-in closed loop of the amplifier.
Then I found this page discussing linuxcnc with mitsubishi motors and meldas drives: emc-users.narkive.com/13JUHu1G/running-m...motors-with-linuxcnc
It has a reverse engineered pinout, showing it to be analog velocity input emc-users.narkive.com/13JUHu1G/running-m...-linuxcnc:i.4.1.full
I'm not sure what any of this means yet, but I guess I'll hold off on ordering the GM board for now.
Last edit: 25 Nov 2015 14:55 by toolmaker69.
25 Nov 2015 15:06 #65778 by andypugh
You probably would use the velocity closed-loop in the drive. The motor tachometers produce a voltage proportional to speed, LinuxCNC provides a voltage proportional to the requested speed, the drive attempts to match the two by PWM-modulating the motor voltage.
What is it that made you decide on the GM drives rather than the alternatives?
25 Nov 2015 15:18 #65780 by toolmaker69
Thanks for the reply.
Sorry Andy, what you said is over my head for now. I'll study it over the course of the day.
I chose the GM board because when I first started on this project, I ordered the Gigabyte GA-E350N motherboard due to its low jitter. It only has one slot, and it's PCI. The multiaxis Mesa cards seem to be for a different type of motherboard.
I edited my post above, adding some links. In the link www.cnczone.com/forums/mazak-mitsubishi-...e-help-please-2.html you are actually the last poster.
The link emc-users.narkive.com/13JUHu1G/running-m...motors-with-linuxcnc has a lot of information.
My head is swimming, but it does that sometimes.
25 Nov 2015 15:40 #65782 by toolmaker69
Okay, I think I know what you are saying.
The velocity loop goes back to the drive, bypassing linuxcnc. As in the Mazak link above, I would try to fit encoders between the motors and the tachometers, and feed the encoders back to linuxcnc.
The drive uses PWM internally to adjust output to the motor when comparing commanded signal to internal feedback signal. I hope that's correct. The Z axis already has a linear encoder, so it's only the X, Y and C axes that would need encoders.
So now I'm back looking at Mesa 5I20, with I don't know which daughter cards. Or perhaps still the GM card, using voltage output.
I need to stop and try to figure this out.
What would you recommend?
Moderators: PCW, jmelson
Time to create page: 0.704 seconds
