7i76E + THCad 10V
10 years 4 months ago #76312 by OPS
Replied by OPS on topic 7i76E + THCad 10V
Thanks, for the update - I'm going to play with it today. Am I right that VFS parameter in bipolar mode is 10V too?
10 years 4 months ago #76317 by PCW
Replied by PCW on topic 7i76E + THCad 10V
The VFS scaling remains the same but the range becomes -5 to +5 V because of the offset
How are you using the THCAD?
If its for a a plasma torch height control, bipolar mode is wrong and you should set the jumper to unipolar mode
10 years 1 month ago #80412 by OPS
Now I'm using in usual manner in unipolar mode on standard scale factors, works like a charm. One thing which slight annoying me it's jamping frequency due to lack of sync between 7i76e board and the THCAD, but this is not big issue.
10 years 1 month ago - 10 years 1 month ago #80414 by OPS
Guys, I'm using thc.comp along with the THCAD board. Recently my system started missing right position on Z coordinate. Initially it was rare issue, but now it's totally nightmare. Is it known issue? Need to fix it fast.
I have several times analysed my touchoff (attached) and didn't find anything what could result something related to z coordinate disorder. Here is g code snippet from my ngc file:
G0
X723.3253 Y874.3354
G0 Z20.000
o<touchoff> call [3.800] [0.4] [1] [3810] (Touchoff and start cutting) --> the parameters meaning: [pierce height] [pierce delay] [cut heigh] [speed torch will move from pierce height ot cut height]
G3 X724.2329 Y876.8905 I-2.2776 J2.2478 F2286.0
X723.2955 Y878.8608 I-3.1852 J-0.3073 F2640.0
X721.6077 Y877.4663 I-0.2679 J-1.3945
G1 Y870.9663 F2640
G3 X724.4477 Y870.9663 I1.4200 J0.0000 F2640.0
G1 Y877.4663 F2640
G3 X723.2955 Y878.8608 I-1.4200 J0.0000 F2640.0
M5 (Torch Off)
<---- error happens at this moment
G0 Z30.000 <--- as result real position of cutter is either too high or too low
as result when it does the next probing it either trigger before it reach Z20 or it can't reach matherial in touchoff because Z is limited with 0
I'm preatty sure it caused by the logic of work of thc.comp, maybe interfere with a way I'm using it or maybe caused by latency spikes.
I'm preatty stuck and preparing to rewrite thc.comp in a way to breack the exclusive control over z axis in this component by release z axis feedback to the system. Feel it will be not so easy to do, so if you think I can manage this more simple way lete me know..
Last edit: 10 years 1 month ago by OPS.
10 years 1 month ago #80507 by BigJohnT
Replied by BigJohnT on topic 7i76E + THCad 10V
I've been using thcad component with the first thcad card for a few years in fact I cobbled the thc component up. I've never had any issues. If you have large latency or electrical issues I could see how the thc component could act up. If you can improve the thc component great. But I'd look elsewhere first.
JT
10 years 1 month ago - 10 years 1 month ago #80514 by Rick G
Replied by Rick G on topic 7i76E + THCad 10V
If I recall correctly any offset the thc applies while the torch is cutting is removed when the torch is turned off and the z axis is commanded to move up. So when the torch is first turned off and some height correction had been applied to Z during the cut the Z position will be off by that correction. It will not be corrected until the Z axis moves a sufficient amount up to remove it.
Couple things to try...
Increase the raise height of Z after the cut to allow more movement to remove the offset.
M5 (Torch Off) <---- error happens at this moment G0 Z30.000 <--- as result real position of cutter is either too high or too low
If your machine has more Z travel
M5 (Torch Off) <---- error happens at this moment G0 Z60.000 <--- Or whatever is safe for your machine and conditions
If the raise height cannot be increased perhaps add an extra movement to take up the correction.
M5 (Torch Off) <---- error happens at this moment G0 Z30.000 <--- as result real position of cutter is either too high or too low G0 Z20.000 G0 Z30.000
The slats on my machine are a bit far apart and when working on light metal which might be warped I find it might be better to be able to probe below Z0.
In my case I prefer to make these moves at a slower rate so I use G1 instead of G0.
Rick G
Last edit: 10 years 1 month ago by Rick G.
The following user(s) said Thank You: BigJohnT
Moderators: PCW, jmelson
Time to create page: 0.317 seconds
